Replikationsprobleme
Hi @ all,
zwei DC auf einer Site, ein Server nicht erreichbar, keine Replikation mehr
dcdiag bringt folgenden Output:
Doing primary tests
Testing server: tttt\ SERVER7
Starting test: Replications
REPLICATION LATENCY WARNING
ERROR: Expected notification link is missing.
Source SERVER5
Replication of new changes along this path will be delayed.
This problem should self-correct on the next periodic sync.
Source SERVER5
......................... SERVER7 passed test Replications
Starting test: NCSecDesc
......................... SERVER7 passed test NCSecDesc
Starting test: NetLogons
......................... SERVER7 passed test NetLogons
Starting test: Advertising
......................... SERVER7 passed test Advertising
Starting test: KnowsOfRoleHolders
......................... SERVER7 passed test KnowsOfRoleHolders
Starting test: RidManager
......................... SERVER7 passed test RidManager
Starting test: MachineAccount
......................... SERVER7 passed test MachineAccount
Starting test: Services
......................... SERVER7 passed test Services
Starting test: ObjectsReplicated
......................... SERVER7 passed test ObjectsReplicated
Starting test: frssysvol
......................... SERVER7 passed test frssysvol
Starting test: frsevent
There are warning or error events within the last 24 hours after the
SYSVOL has been shared. Failing SYSVOL replication problems may cause
Group Policy problems.
......................... SERVER7 failed test frsevent
Starting test: kccevent
......................... SERVER7 passed test kccevent
Starting test: systemlog
An Error Event occured. EventID: 0x000003E9
Time Generated: 10/30/2006 08:10:39
(Event String could not be retrieved)
......................... SERVER7 failed test systemlog
Starting test: VerifyReferences
......................... SERVER7 passed test VerifyReferences
Running partition tests on : ForestDnsZones
Starting test: CrossRefValidation
......................... ForestDnsZones passed test CrossRefValidation
Starting test: CheckSDRefDom
......................... ForestDnsZones passed test CheckSDRefDom
Running partition tests on : DomainDnsZones
......................... DomainDnsZones passed test CrossRefValidation
......................... DomainDnsZones passed test CheckSDRefDom
Running partition tests on : Schema
......................... Schema passed test CrossRefValidation
......................... Schema passed test CheckSDRefDom
Running partition tests on : Configuration
ab hier alles i.o.!
Probiere ich morgen mal!
Ich untersuche gerade das netdiag Protokoll, da sieht alles sauber aus!
Auf dem Server läuft auch der ISA-Server, aber da habe ich nichts geändert und jetzt auch mal alles zugelassen...
Der lässt sich nicht deinstallieren, da bringt er eine Meldung von wegen ISA 2000 Verwaltungstools und Gatewaykeeper, obwohl der ISA 2004 installiert ist!
Auch das SP2 geht nicht zu installieren, bricht mit der selben Message ab!
Ping vom kaputten server geht, auf den Server eben nicht, das muss doch was firewalltechnisches sein??:confused:
Du hast ISA und DC auf einer Kiste? :suspect: Wäre nett, wenn Du das von vornherein erwähnt hättest ;)
Da musst Du an den FW-Regeln einiges zulassen (LDAP, LDAPGC uvm) und auch die ISA-System-Policy nicht ausser acht lassen. Dass Du den dann nicht pingen kannst, ist normal. Der reagiert nur auf Pings, die von Computern kommen, die im Remote Management Computerset enthalten sind.
Optimalerweise hat man allerdings den ISA auf einem Memberserver oder Stand-Alone Server laufen.
Hier mal ein Link zum Thema ISA 2000 und DC auf einer Maschine. Kannst Du ggf. auf ISA 2004 übertragen.
Installing ISA Server on a Domain Controller.
Christoph
Es gibt immer noch die Systempolicy, die den Daten-Verkehr zum und vom ISA selbst regelt. Das mit dem Remotedesktop liegt, genau wie beim Pingen, daran, dass diese® Rechner nicht im Remote-Management Computerset entalten ist.
Schau dir mal die FW-Policy an und klicke dann im Aufgabenbereich auf "Show System Policy Rules" oder "Edit System Policy". Das sind 30 Regeln, die normal nicht gelistet werden.
Christoph
