VB Script Problem
Hallo, ich möchte in folgendes Script:
strComputer = "."
Set objWMIService = GetObject("winmgmts:" _
& "{impersonationLevel=impersonate,(Backup)}!\\" & _
strComputer & "\root\cimv2")
Set colLogFiles = objWMIService.ExecQuery _
("Select * from Win32_NTEventLogFile where LogFileName='Application'")
For Each objLogfile in colLogFiles
errBackupLog = objLogFile.BackupEventLog("c:\app.evt")
If errBackupLog <> 0 Then
Wscript.Echo "The Application event log could not be backed up."
Else
objLogFile.ClearEventLog()
End If
Next
strComputer = "."
("Select * from Win32_NTEventLogFile where LogFileName='Security'")
errBackupLog = objLogFile.BackupEventLog("c:\Sec.evt")
Else
End If
Next
strComputer = "."
("Select * from Win32_NTEventLogFile where LogFileName='System'")
errBackupLog = objLogFile.BackupEventLog("c:\Sys.evt")
Else
End If
Next
den Aufruf einer REG Datei einbinden oder noch besser, den Inhalt der REG-Datei mit dem gleichen Script abarbeiten:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Eventlog\Application]
"DisplayNameFile"=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,\
6f,00,74,00,25,00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,\
00,65,00,6c,00,73,00,2e,00,64,00,6c,00,6c,00,00,00
"DisplayNameID"=dword:00000100
"File"=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,\
00,25,00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,63,00,\
6f,00,6e,00,66,00,69,00,67,00,5c,00,41,00,70,00,70,00,45,00,76,00,65,00,6e,\
00,74,00,2e,00,45,00,76,00,74,00,00,00
"MaxSize"=dword:00080000
"PrimaryModule"="Application"
"Retention"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Eventlog\System]
"DisplayNameID"=dword:00000102
6f,00,6e,00,66,00,69,00,67,00,5c,00,53,00,79,00,73,00,45,00,76,00,65,00,6e,\
"PrimaryModule"="System"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Eventlog\Security]
6f,00,74,00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,\
"DisplayNameID"=dword:00000101
00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,63,00,\
6f,00,6e,00,66,00,69,00,67,00,5c,00,53,00,65,00,63,00,45,00,76,00,65,00,6e,\
"PrimaryModule"="Security"
thx
