Prüfung auf korrupte ADS
hi,
dcdiag
netdiag
und ich würde mal probieren obs du mit ntbackup den systemstate sichern kannst ?
The Ntdsutil tool may fail to repair the Active Directory database (the Ntds.dit file) and generates one or more of the following errors:
Operation failed because the database was inconsistent.
Initialize jet database failed; cannot access file.
Error while performing soft recovery.
All is not lost. You can use the Esentutl.exe tool to resolve the problem.
To perform an integrity check
Start a command prompt
Type the following command (including the quotation marks), and then press ENTER: esentutl /g "path\ntds.dit"/!10240 /8 /v /x /o
where path is the path to the folder that contains the Ntds.dit db file. By default, this folder is C:\Winnt\Ntds.
To repair the database:
Type the following command (including the quotation marks), and then press ENTER: esentutl /p "path\ntds.dit" /!10240 /8 /v /x /o
Import: Delete the database log files from the Winnt/Ntds folder. Do not delete or move the Ntds.dit file.
quelle:Use Esentutl when Ntdsutil tool fails to repair the Active Directory database
lg
rossi
hi,
dcdiag
netdiag
lg
rossi
Danke! Esentutl hat mir noch in der "Sammlung" gefehlt!
