Virtual Machine (Virtual Server 2005R2) per Script sichern
ich versuche, meine VM, die unter Virtual Server 2005 R2 läuft, per Script zu sichern.
Ich habe dazu dieses Script
Back Up Microsoft Virtual Server Images
benutzt.
On Error Resume Next
Set objShell = CreateObject ("WScript.Shell")
set objFSO=CreateObject("Scripting.FileSystemObject")
Set virtualServer = CreateObject("VirtualServer.Application")
DestBackupDir = "D:\VM-Backups\"
sExCmd = "CreateVSS.cmd"
Set oFileSys = CreateObject("Scripting.FileSystemObject")
if oFileSys.FileExists(sExCmd) then oFileSys.DeleteFile(sExCmd)
set oExCmd = oFileSys.CreateTextFile(sExCmd, CopyOverwrite)
For each objVM in virtualServer.VirtualMachines
'See if vm machine is running. If so then do backup
If objVM.State = 5 then
'Save state the virtual machine
set saveTask = objVM.Save
'Loop waiting for task completion - and display status
while not saveTask.isComplete
WScript.Sleep 1000
wend
'Copy .VMC and .VSV files
MyArray = Split(objVM.File,"\")
Filename = MyArray(Ubound(MyArray))
objFSO.CopyFile objVM.File,DestBackupDir & Filename
MyArray = Split(objVM.SavedStateFilePath,"\")
objFSO.CopyFile objVM.SavedStateFilePath,DestBackupDir & Filename
End If
Next
Set objVM = Nothing
' Create Shadow copy of VM drive
oExCmd.WriteLine "vshadow.exe -script=setvar1.cmd -p d:"
oExCmd.WriteLine "call setvar1.cmd"
oExCmd.WriteLine "vshadow.exe -el=%SHADOW_ID_1%,x:"
oExCmd.Close
Result = objShell.run(sExCmd,vbMinimized, TRUE)
' Start VM machine up from saved state
'See if vm machine is Saved. If so then resume
If objVM.State = 2 then
'Start virtual machine
objVM.Startup
End If
Next
Set objVM = Nothing
WScript.Sleep 10000
If Result = 0 then
'Loop through all vm machines
'See if vm machine is running. If so copy shadow backup of vm disk drives
'Copy virtual hard disks and undo disks
For each vhd in objVM.HardDiskConnections
MyArray = Split(vhd.undoHardDisk.file,"\")
SourceName = "x" & Right(vhd.undoHardDisk.file,Len(vhd.undoHardDisk.file)-1)
wscript.echo vhd.undoHardDisk.file
wscript.echo SourceName
objFSO.CopyFile SourceName,DestBackupDir & Filename
MyArray = Split(vhd.HardDisk.file,"\")
SourceName = "x" & Right(vhd.HardDisk.file,Len(vhd.HardDisk.file)-1)
Next
End If
Next
End If
' Shutdown all shadow copy instances
oExCmd.WriteLine "Echo y | vshadow.exe -da"
oExCmd.Close
'Script ends
wscript.echo "done"
Ich habe lediglich den Backuppfad angepasst.
Nun habe ich das Problem, das zwar meine .vsv und .vmc Datein unter C:\Dokumente und Einstellungen\All Users\Dokumente\Shared Virtual Machines\..liegen und auch vom Script gesichert werden, aber meine .vhd Datei, die auf einer seperaten Festplatte mit einem ganz anderen Pfad liegt, leider nicht mitkopiert wird. "E:\VM-Drives\sbs200.vhd"
Leider kann ich kein VBS (zum Anpasssen des Backuppfads hats gerade noch gereicht).
Kann mir vielleicht jemand noch einen Tip geben, wie ich diesen Pfad in dieses Script integrieren kann.
:confused:
  • 6 Monate später...
Such die folgende Zeile im Script und änder das "d" entsprechen in dein Laufwerksbuchstaben um wo die vhd Dateien liegen !
Teil mir wenns läuft mal deine Erfahrungen mit , weil bei mir läuft es nicht automatisch, es erscheint beim Durchlaufen immer ein Fesnter was bestätigt werden muss sonst läufts nicht weiter. Die Anzahl der Fenster die erscheinen richten sich nach der Anzahl der VMs
Gruß,
Tobi
