Switche ausgelastet?
3548-2OG-Neu-sw1#show version
Cisco Internetwork Operating System Software
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)WC9, RELEASE SOFTWAR
E (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 19-Sep-03 10:01 by antonino
Image text-base: 0x00003000, data-base: 0x0034E434
ROM: Bootstrap program is C3500XL boot loader
3548-2OG-Neu-sw1 uptime is 50 weeks, 6 hours, 23 minutes
System returned to ROM by power-on
System image file is "flash:c3500xl-c3h2s-mz.120-5.WC9.bin"
cisco WS-C3548-XL (PowerPC403) processor (revision 0x01) with 16384K/1024K bytes
of memory.
Processor board ID FAB0524xxx, with hardware revision 0x00
Last reset from power-on
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:06:53:45:xx:xx
Motherboard assembly number: 73-3903-11
Power supply part number: 34-0971-01
Motherboard serial number: FAB0524xxx
Power supply serial number: APQ0504xxx
Model revision number: N0
Motherboard revision number: B0
Model number: WS-C3548-XL-EN
System serial number: FAB0524xxx
Configuration register is 0xF
CPU utilization for five seconds: 55%/9%; one minute: 52%; five minutes: 52%
PID QTy       PC Runtime (ms)    Invoked   uSecs    Stacks TTY Process
  1 Csp   1E726C        78795    6050491      13 2652/3000   0 Load Meter
  2 M*         0          115        122     942 9700/12000  1 Virtual Exec
  3 Lst   1D2D4C     18160338    3580543    5071 5740/6000   0 Check heaps
  5 Cwe   1D8064          244        470     519 5640/6000   0 Pool Manager
  8 Mwe   245358       699526    7550768      92 5464/6000   0 HC Counter Timer
  9 Lwe   259D9C     70932938  162080612     437 4936/6000   0 ARP Input
 12 Mwe   1A9B50      1942906   21797896      8910256/12000  0 Net Background
 13 Lwe   151894        24516     326335      7511460/12000  0 Logger
 14 Msp   16E644      1909144   29767550      64 5536/6000   0 TTY Background
 15 Msp   1A91B4    149923356  148828927    1007 5060/6000   0 Per-Second Jobs
 16 Hwe   1A93C4      1455261   15545917      93 5636/6000   0 Net Input
 17 Csp   1B1350       241724    6050491      39 5632/6000   0 Compute load avg
 18 Msp   1A9200      7097905     504201   14077 5628/6000   0 Per-minute Jobs
 19 Hsp   1F39AC   1298072601 3207493472     404 2120/3000   0 LED Control Proc
 20 Msp   111550    100266883   29767552    3368 1332/3000   0 Frank Aging
 21 Hsp   20FC00   1458582498 1776943041     820 3464/6000   0 Port Status Proc
 22 Mwe   23A174         2181      22222      98 5564/6000   0 VM Prune Events
  24 Msp    E8418    262165226   64385051    4071 2516/3000   0 GDS Frame Ager
 32 Msp   1F6C80   1307832886 2023835230     646 5152/6000   0 Broadcast Storm
 35 Hwe   223EE0     15029631    5411237    2777 2164/3000   0 Address Learning
 41 Mrd    E9668   1085221641  209336065    5184 5512/6000   0 Enet Aging
 42 Mrd    257B0     19171187   44344190     43210200/12000  0 IP Input
 43 Lwe   229F38    128863521    4259795   30251 2216/3000   0 Address Deletion
 44 Msp   223E70       191236    6068520      31 2628/3000   0 Address Sorting
 45 Mwe    4B674     24460636    7405816    3302 4140/6000   0 CDP Protocol
 46 Hwe    58518       987044   30262766      32 5624/6000   0 UDLD
 50 Mwe   2B9C54           16          3    5333 4008/6000   0 VLAN Manager
 53 Mst     F6DC           57        229     24810960/12000  0 TCP Timer
 54 Lwe    14038          268        320     83710892/12000  0 TCP Protocols
 57 Mwe   2EA06C        10662     378250      28 5472/6000   0 Cluster L2
 58 Mwe   2E8864       144562    3023875      47 4024/6000   0 Cluster RARP
 59 Mwe   2E1FB8      2418307    8777643     275 4344/6000   0 Cluster Base
 60 Mwe   27FBB4      1890932   47883908      39 4452/6000   0 Spanning Tree
 61 Hwe   27FD78          174          7   24857 1448/3000   0 STP Hello
 62 Hwe   27FC9C    166167484   15142985   10973 4292/6000   0 STP Queue Handle
 63 Hwe    DCD80       551299      21635   25481 4276/6000   0 Malibu STP Adjus
 72 Lwe   2AC1E4      6971933    7836268     889 1036/3000   0 Runtime diags
 73 Mwe   309890      1148969   30579940      37 5456/6000   0 NTP
 75 Lwe    65A60           53        104     50911396/12000  0 IP SNMP
es kommt darauf an. Die XL Switches sind EoL (End of Life) und ab 27.7.07 End of Support. Es wird von Cisco keine SW mehr für diese Switches entwickelt und es werden auch nicht mehr alle Bugs behoben (habe das selber miterlebt mit dem Voice Vlan Feature). Ab dem End of Support Datum werden auch keine schwerwiegenden Bugs mehr behoben.
Wenn du aber derzeit zufrieden damit bist und in näherer Zukunft kein Voip oder tolle Security Features benötigst, dann würde ich sie behalten. Die Dinger sind robust und einfach zu bedienen.
Zur CPU Load:
Das Ding hat >20% Leerlauf CPU Load. B ei den XL Switches habe ich auch bis 70%-80% keine Probleme erlebt.
#9370
Der Durchsatz ist halt einfach schlecht.
Auf einer IBM-Kiste (p4 1,5 Ghz, mit 100er Karte) habe ich mal SCP (bzw. PSCP unter XP zu ner UNIX-Kiste) gemacht. 100HD oder 100FD war gerade egal, ca. 200 KB/sec wurden nur erreicht, dabei war die Datei 4 GB gross. Unter Suse 7.2 ähnliche Werte.
Das RAID5 auf dem die Datei liegt (3x 72er Platten) ist absolut unbelastet, RAID-Controller hat 128 MB Cache und der UNIX-Rechner hat ne 3com-Gigabit-Karte.
Bei 100FD wars anfangs schneller, aber da war die Datei wohl noch auf dem Server noch im Hauptspeicher oder RAID-Controller-Cache.
