Squire 276 Geschrieben 9. März 2007 Melden Geschrieben 9. März 2007 Hallo, mal ne Frage bezüglich der Lizenzierung für den W2k3 Enterprise R2 auf einem ESX Server. Die Lizenzierungs-FAQ von VMWare sagt folgendes: Licensing related questions Q: Microsoft recently announced enhanced licensing of Windows Server 2003 Enterprise and Datacenter Editions. Are customers licensed to run multiple instances of Windows Server 2003 in VMware virtual machines on products like VMware® Server and ESX Server because of these changes? A: Yes, customers are licensed to run multiple Windows Server 2003 R2 OS instances in virtual machines on servers licensed for Windows Server 2003 RS Enterprise or Datacenter Editions. Only applies to Win2003 R2 SP1. 1. A physical server licensed for Enterprise Edition can run up to four instances of Windows Server in virtual machines on that particular server at no extra charge. 2. A physical server licensed for Datacenter Edition can run an unlimited number of Windows Server instances in virtual machines on that particular server at no additional charge. In the case of VMware Server, which installs like an application on top of the host OS, the policy for Windows Server 2003 R2 Enterprise Edition applies to four guest operating systems in addition to the host OS. Multiple Enterprise Edition licenses can be applied to the same physical machine / host (i.e. 2 licenses = 8 VMs on a physical machine). Because ESX Server (included in VMware Infrastructure 3) installs directly on hardware without a host OS, customers can pay for one Enterprise Edition license and run up to a total of four guest instances. Microsoft allows the guest OSes to be downgraded to lower versions of Win2003 Server or even Win2000 and NT. These implementations for Windows Server 2003 R2 Enterprise Edition are illustrated below. Stimmt das nun so? Ich dachte bisher immer der W2k3 R2 Ent. muss direkt auf der Hardware laufen um die 4 Lizenzen in der VM zu nutzen ... als Quellen geben die folgendes an: Microsoft references:• http://download.microsoft.com/download/6/8/9/68964284-864d-4a6d-aed9-f2c1f8f23e14/virtualization_whitepaper.doc (Oct, 2006) - see pages 24-25 on number of virtual licenses for Enterprise and Data Center Editions • Virtual Machine Technology FAQ (Sept, 2006) - see question-answer about Enterprise Edition’s 4 virtual licenses applying to VMware as the host Zitieren
Dr.Melzer 191 Geschrieben 9. März 2007 Melden Geschrieben 9. März 2007 Ich dachte bisher immer der W2k3 R2 Ent. muss direkt auf der Hardware laufen um die 4 Lizenzen in der VM zu nutzen ... Nein, das ist nicht so. Du darfst die vier Virtuellen Instanzen des W2K3 EE R2 (achtung es muss der R2 Enterprise Server sein), auh mit jeder beliebigen anderen Virtualisierungstechnologie, auf jeder beliebigen anderen non MS Plattform betreiben. Da die eine physikalische Instanz auf demselben Gerät wie die vier virtuellen laufen muss, entfällt sie einfach in dem Fall. Basis muss aber kein MS Server sein. Zitieren
Sasch 11 Geschrieben 2. April 2007 Melden Geschrieben 2. April 2007 Also dürfte ich einen Windows 2003 Standard Server R2 nicht 2x installieren - also einmal als Hostsystem und einmal in der VMware ?? Dazu bräuchte ich dann 2 Serverlizenzen ?? Wie sieht es den da mit den Cals aus ?? Zitieren
Dr.Melzer 191 Geschrieben 2. April 2007 Melden Geschrieben 2. April 2007 Also dürfte ich einen Windows 2003 Standard Server R2 nicht 2x installieren - also einmal als Hostsystem und einmal in der VMware ?? Dafür brauchst du aber zwei Lizenzen. Nur der Enterprise server darf viermal in VMs genutzt werden Dazu bräuchte ich dann 2 Serverlizenzen ?? Wie sieht es den da mit den Cals aus ?? Du brauchst dann 2 Serverlizenzen, aber nicht mehr CALs. Zitieren
