VPN Failover
Hallo Leute,
Habe 2 535 Pixen in Active-Standby konfiguriert. Zusätzlich zu den failover log-messages bekomme ich folgende log Einträge. Habe aber keinerlei VPN konfiguriert. Weiß jemand was es mit diesen Messages auf sich hat?
PIX-6-720032: (VPN-Primary) HA status callback: id=3,seq=200,grp=0,event=404,op=104,my=Standby Ready,peer=Failed.
PIX-6-720037: (VPN-Primary) HA progression callback: id=3,seq=200,grp=0,event=200,op=25,my=Just Active,peer=Failed.
PIX-6-720032: (VPN-Primary) HA status callback: id=3,seq=200,grp=0,event=401,op=0,my=Active Drain,peer=Failed.
PIX-6-720032: (VPN-Primary) HA status callback: id=3,seq=200,grp=0,event=402,op=0,my=Active Drain,peer=Failed.
PIX-6-720037: (VPN-Primary) HA progression callback: id=3,seq=200,grp=0,event=201,op=25,my=Active Drain,peer=Failed.
PIX-6-720037: (VPN-Primary) HA progression callback: id=3,seq=200,grp=0,event=202,op=25,my=Active Applying Config,peer=Failed.
PIX-6-720037: (VPN-Primary) HA progression callback: id=3,seq=200,grp=0,event=203,op=25,my=Active Config Applied,peer=Failed.
PIX-6-720037: (VPN-Primary) HA progression callback: id=3,seq=200,grp=0,event=204,op=25,my=Active,peer=Failed.
PIX-6-720032: (VPN-Primary) HA status callback: id=3,seq=200,grp=0,event=405,op=130,my=Active,peer=Failed.
lg und Danke für Hilfe
1. %PIX-6-720032: (VPN-unit) HA status callback: id=ID, seq=sequence_#, grp=group, event=event, op=operand, my=my_state, peer=peer_state.
This is an informational message generated by VPN failover subsystem when a status update is notified by the underlying failover subsystem. unitEither "Primary" or "Secondary" IDClient ID number. sequence_#Sequence number. groupGroup ID. eventCurrent event. operandCurrent operand. my_stateThe system's current state. peer_stateThe current state of the peer.
Recommended Action: None required.
Related documents- No specific documents apply to this error message.
1. %PIX-6-720037: (VPN-unit) HA progression callback: id=id,seq=sequence_number,grp=group,event=event,op=operand, my=my_state,peer=peer_state.unitEither "Primary" or "Secondary."idClient id.sequence_numberSequence number.groupGroup id.eventCurrent event.operandCurrent operand.my_stateCurrent state of the system.peer_stateCurrent state of the peer.
This is an informational message reporting the status of the current failover progression.
Sieht so aus als waere es in einer Active-Standby Umgebung per default aktiv.
Link: http://www.cisco.com/cgi-bin/Support/Errordecoder/index.cgi
