Cisco 831 - ADSL over PPPoE - Config Problem
Hallo Leute!
Ich habe jetzt die Config geändert damit man über PPPoE eine Internet verbindung aufbauen kann, aber irgenwie hab ich da was falsch gemacht und ich komm einfach nicht auf den Fehler.
Ich poste hier mal die Config!
Vieleicht hat ja wer ne idee was ich falsch habe,
vielen dank im voraus!
version 12.3
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
no service dhcp
hostname ROUTER
no logging buffered
clock timezone UTC1 1
aaa new-model
ip name-server 195.34.133.21
ip name-server 195.34.133.22
ip inspect name myfw cuseeme timeout 3600
ip inspect name myfw ftp timeout 3600
ip inspect name myfw rcmd timeout 3600
ip inspect name myfw realaudio timeout 3600
ip inspect name myfw smtp timeout 3600
ip inspect name myfw tftp timeout 30
ip inspect name myfw udp timeout 15
ip inspect name myfw tcp timeout 3600
ip inspect name myfw h323 timeout 3600
ip inspect name myfw icmp
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
interface Ethernet0
description LAN Interface intern
ip address 10.177.100.254 255.255.255.0
ip access-group LAN_in in
ip nat inside
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
hold-queue 32 in
interface Ethernet1
description WAN Internet via Inode$ETH-LAN$
no ip address
ip access-group WAN_in in
ip nat outside
ip inspect myfw out
no ip route-cache
no ip mroute-cache
duplex auto
no cdp enable
crypto map cm-cryptomap
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
interface Dialer0
ip address 62.99.165.154 255.255.255.248
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username User password 7 1234555
ppp ipcp dns request
ppp ipcp wins request
ip local pool VPN-POOL 10.177.101.1
ip local pool VPN-POOL1 10.177.101.21 10.177.101.254
ip nat translation timeout 28800
ip nat translation tcp-timeout 28800
ip nat inside source static tcp 10.177.100.4 25 interface Ethernet1 25
ip nat inside source static tcp 10.177.100.4 80 interface Ethernet1 80
ip nat inside source route-map NAT-RMAP interface Dialer0 overload
ip nat inside source static 10.177.100.4 62.99.165.155
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
no ip http secure-server
ip access-list extended LAN_in
remark Enthernet IN LAN Ethernet0
permit tcp any any
permit icmp any any
permit udp any 10.177.101.0 0.0.0.255
permit udp any any eq domain
permit udp any any eq ntp
permit udp any eq 5631 any
permit udp any eq 5632 any
permit udp any any eq isakmp
permit ahp any any
permit esp any any
deny ip any any log
ip access-list extended NAT-LIST1
remark SDM_ACL Category=18
deny ip 10.177.100.0 0.0.0.7 192.xxx.0 0.0.0.255
deny ip 10.177.100.0 0.0.0.255 host 81.xxx
deny ip 10.177.100.0 0.0.0.255 host 80xxx8
deny ip 10.177.100.0 0.0.0.255 10.10.192.0 0.0.0.255
deny ip 10.177.100.0 0.0.0.255 10.177.101.0 0.0.0.255
deny ip 10.177.100.0 0.0.0.255 192.56.14.0 0.0.0.255
permit ip 10.177.100.0 0.0.0.255 any
ip access-list extended WAN_in
remark Enthernet IN WAN Ethernet1
remark SDM_ACL Category=17
permit ahp host 81.xx host 62.99.165.154
permit esp host 81.xx host 62.99.165.154
permit udp host 81.xx host 62.99.165.154 eq isakmp
permit udp host 81.xx host 62.99.165.154 eq non500-isakmp
permit ip host 81.xx 10.177.100.0 0.0.0.255
permit ahp host 194.xx host 62.99.165.154
permit esp host 194.xx host 62.99.165.154
permit udp host 194.xx host 62.99.165.154 eq isakmp
permit udp host 194.xx host 62.99.165.154 eq non500-isakmp
permit ahp host 80.xx host 62.99.165.154
permit esp host 80.xx host 62.99.165.154
permit udp host 80.xx host 62.99.165.154 eq isakmp
permit udp host 80.xx host 62.99.165.154 eq non500-isakmp
permit ip host 80.xx 10.177.100.0 0.0.0.255
permit ip host 10.177.101.254 any
permit ip host 10.177.101.1 any
permit udp host 195.58.161.122 eq domain any
permit udp host 195.58.160.194 eq domain any
permit udp host 195.34.133.22 eq domain any
permit udp host 195.34.133.21 eq domain any
permit ahp any host 62.99.165.154
permit esp any host 62.99.165.154
permit udp any host 62.99.165.154 eq isakmp
permit udp any host 62.99.165.154 eq non500-isakmp
permit tcp any host 62.99.165.154 eq smtp
permit tcp any host 62.99.165.154 eq www
permit tcp any host 62.99.165.155 eq smtp
permit tcp any host 62.99.165.155 eq www
permit udp any eq domain any
permit udp any eq ntp any
permit icmp any any echo-reply
permit ip host 80.xx any
permit ip host 81.xx any
permit udp 10.177.101.0 0.0.0.255 host 10.177.100.1 eq domain
permit udp 10.177.101.0 0.0.0.255 host 10.177.100.1 range netbios-ns netbios-dgm
permit tcp 10.177.101.0 0.0.0.255 host 10.177.100.1
permit tcp 10.10.192.0 0.0.0.255 host 10.177.100.1 gt 1023
permit ip 10.10.192.0 0.0.0.255 10.177.100.0 0.0.0.255
permit ip 192.56.14.0 0.0.0.255 10.177.100.0 0.0.0.7
deny ip any any log
ip access-list extended dns-servers
ip access-list extended firewall
ip access-list extended group-lock
ip access-list extended idletime
ip access-list extended inacl
ip access-list extended include-local-lan
ip access-list extended key-exchange
ip access-list extended protocol
ip access-list extended save-password
ip access-list extended service
ip access-list extended timeout
ip access-list extended tunnel-password
ip access-list extended wins-servers
no cdp run
route-map NAT-RMAP permit 10
match ip address NAT-LIST1
banner login ^CC Zugang nur fuer authorisierte User, ansonst ist dies eine strafbare Handlung! ^C
line con 0
exec-timeout 120 0
no modem enable
stopbits 1
line aux 0
line vty 0 4
exec-timeout 120 0
length 0
scheduler max-task-time 5000
sntp server 192.5.41.41
sntp server 192.5.41.209
end
@rob_67
Hallo, danke für Deine Hilfe,
aber wo muß ich denn das hineinschreiben
dialer list 1 protocol ip permit
stehe ein wenig auf dem schlauch,
gehört das jetzt in eine Bestehende accesslist oder muß ich eine neue machen?
Vielen dank im Voraus!
mfg
jörg
@wordo
Danke für die Hilfe!
wenn ich das eingebe kommt folgende Meldung
ROUTER(config)#dialer list 1 protocol ip permit
% Invalid input detected at '^' marker.
Also das dacherl zeigt auf "list"
was ist denn da falsch an der Eingabe?
Danke im Voraus!
mfg
jörg
