Problem mit Cisco SB106 + ADSL Einwahl
Hallo Leute!
ich hab wieder mal ein Problem mit einer ADSL-Einwahl.
Hab einen neuen Cisco SB106 ADSL-Router und bekomme aber leider keine Verbindung
ins Internet.
Hab schon alles Probiert!
Hier mal meine Konfig, hab ich was übersehen?
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname fw
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
logging console critical
no aaa new-model
clock timezone PCTime 1
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
no ip source-route
ip tcp synwait-time 10
ip cef
ip domain name domain.at
ip name-server 195.34.133.21
ip name-server 195.34.133.22
no ip bootp server
ip inspect name DEFAULT100 cuseeme
ip inspect name DEFAULT100 ftp
ip inspect name DEFAULT100 h323
ip inspect name DEFAULT100 icmp
ip inspect name DEFAULT100 netshow
ip inspect name DEFAULT100 rcmd
ip inspect name DEFAULT100 realaudio
ip inspect name DEFAULT100 rtsp
ip inspect name DEFAULT100 esmtp
ip inspect name DEFAULT100 sqlnet
ip inspect name DEFAULT100 streamworks
ip inspect name DEFAULT100 tftp
ip inspect name DEFAULT100 tcp
ip inspect name DEFAULT100 udp
ip inspect name DEFAULT100 vdolive
crypto pki trustpoint TP-self-signed-1955548683
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1955548683
revocation-check none
rsakeypair TP-self-signed-1955548683
crypto pki certificate chain TP-self-signed-1955548683
certificate self-signed 01
interface Ethernet0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-Ethernet 10/100$$ES_LAN$$FW_INSIDE$
ip address 10.177.100.254 255.255.255.0
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation hdlc
ip route-cache flow
shutdown
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description $ES_WAN$$FW_OUTSIDE$
no snmp trap link-status
pvc 8/48
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Dialer0
description $FW_OUTSIDE$
ip address 62.99.165.153 255.255.255.248
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip inspect DEFAULT100 out
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxx@inode.at
ppp chap password 7 xxx
ppp pap sent-username xxx@inode.at password 7 xxx
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static tcp 10.177.100.4 80 interface Dialer0 80
ip nat inside source static tcp 10.177.100.4 1352 interface Dialer0 1352
ip nat inside source static tcp 10.177.100.4 25 interface Dialer0 25
logging trap debugging
access-list 1 remark INSIDE_IF=Ethernet0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.177.100.0 0.0.0.255
access-list 100 remark auto generated by Cisco SDM Express firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip 62.99.165.152 0.0.0.7 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by Cisco SDM Express firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 remark Auto generated by SDM for NTP (123) 192.5.41.41
access-list 101 permit udp host 192.5.41.41 eq ntp host 62.99.165.153 eq ntp
access-list 101 permit udp host 195.34.133.22 eq domain host 62.99.165.153
access-list 101 permit udp host 195.34.133.21 eq domain host 62.99.165.153
access-list 101 permit tcp any host 62.99.165.153 eq www
access-list 101 permit tcp any host 62.99.165.153 eq 1352
access-list 101 permit tcp any host 62.99.165.153 eq smtp
access-list 101 deny ip 10.177.100.0 0.0.0.255 any
access-list 101 permit icmp any host 62.99.165.153 echo-reply
access-list 101 permit icmp any host 62.99.165.153 time-exceeded
access-list 101 permit icmp any host 62.99.165.153 unreachable
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip any any
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport output telnet
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler interval 500
sntp server 192.5.41.41
end
HI
bei meinem 824 Router sieht das ganze so aus.
interface ATM0
no ip address
no ip mroute-cache
atm vc-per-vp 64
pvc 8/48
interface Dialer0
ip address negotiated
no ip redirects
ip mtu 1492
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer remote-name redback
dialer-group 1
no cdp enable
ppp chap hostname XXX@inode.at
ppp chap password 7 XXX
ppp pap sent-username XXX@inode.at password 7 XXX
hold-queue 224 in
vielleicht hilfts dir ja.
ciao onedread
