Cisco 1760 und PPPoE
Hi,
Ich bekomme einfach auf meinem Cisco 1760 Router pppoe nicht zum laufen vielleicht seht ihr ja anhand meiner Config-Datei was ich falsch gemmacht habe.
Aufbau:
Modem------WIC-1Enet------Cisco-1760-Router------Netzwerk-Switch
Hier meine Config:
[ATTACH]3388[/ATTACH]
Danke
Building configuration...
Current configuration : 7527 bytes
version 12.4
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Gateway-1
boot-start-marker
boot-end-marker
no logging buffered
enable password ........................
no aaa new-model
resource policy
ip cef
no ip dhcp use vrf connected
ip dhcp pool 1
network 192.168.17.0 255.255.255.0
default-router 192.168.17.1
ip name-server 217.237.149.161
vpdn enable
interface Ethernet0/0
description $ETH-WAN$
no ip address
half-duplex
pppoe enable
pppoe-client dial-pool-number 1
no keepalive
interface FastEthernet0/0
description $ETH-LAN$
ip address 192.168.17.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
speed auto
interface Dialer1
description connected to Internet
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 2
ppp authentication chap pap callin
ppp chap hostname ........................
ppp chap password ........................
ppp pap sent-username ........................ password........................
router rip
version 2
passive-interface Dialer1
no auto-summary
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 192.168.17.0 0.0.0.255
dialer-list 2 protocol ip permit
snmp-server community public RO
control-plane
line con 0
exec-timeout 0 0
login
line aux 0
line vty 0 4
login
end
hier die ausgaben:
Gateway-1#deb pppoe er
PPPoE protocol errors debugging is on
Gateway-1#deb pppoe ev
PPPoE protocol events debugging is on
Gateway-1#deb ppp neg
PPP protocol negotiation debugging is on
Gateway-1#deb ppp auth
PPP authentication debugging is on
Gateway-1#
03:58:27: Vi1 PPP: Outbound cdp packet dropped
du hast in deiner Konfig:
stehen. Dies sollte meiner Meinung nach
dialer-list 1 protocol ip permit
heißen, weil:
gate(config)#dialer-list ?
 <1-128>  Dialer group number
gate(config)#
und die dialer-group-number bei dir die 1 ist.
In deinem Fall "sieht" die dialer-group 1 nie den "interessanten Traffic" und versucht daher auch keine Einwahl.
mfg
okay jetzt funktioniert schonmal icq und skype muss nur noch http funktionieren muss ich dafür ergendwelche access Einträge erstellen?
Current configuration : 1643 bytes
version 12.4
hostname Gateway-1
boot-start-marker
boot-end-marker
no logging buffered
enable password
no aaa new-model
resource policy
ip cef
ip dhcp pool 1
vpdn enable
no ip address
half-duplex
pppoe enable
no keepalive
ip nat inside
speed auto
interface Dialer1
ip access-group 103 in
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname
ppp chap password
ppp pap sent-username password
router rip
version 2
no auto-summary
ip http server
control-plane
line con 0
exec-timeout 0 0
password
login
line aux 0
line vty 0 4
password
login
end
ich habe jetzt folgenden eintrag in die access liste hinzugefügt leider funktioniert immer noch kein http oder was für ein eintrag muss ich hinzufügen damit ich mit den clients http aufrufen können?
access-list 100 permit tcp 192.168.17.0 0.0.0.255 any eq www
ich habe jetzt
access-list 198 permit tcp any eq www any eq www
und
ip nat inside source list 198 interface FastEthernet0/0 overload
zur config hinzugefügt leider funktioniert immer noch kein http oder seht ihr rnoch ein fehler in meiner config?
hier show interface:
Gateway-1#show inter
Ethernet0/0 is up, line protocol is up
 Hardware is PQUICC Ethernet, address is 0004.dc0c.b5a5 (bia 0004.dc0c.b5a5)
 MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
    reliability 255/255, txload 1/255, rxload 1/255
 Encapsulation ARPA, loopback not set
 Keepalive not set
 Half-duplex, 10BaseT
 ARP type: ARPA, ARP Timeout 04:00:00
 Last input 00:00:03, output 00:00:03, output hang never
 Last clearing of "show interface" counters never
 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
 Queueing strategy: fifo
 Output queue: 0/40 (size/max)
 5 minute input rate 0 bits/sec, 0 packets/sec
 5 minute output rate 0 bits/sec, 0 packets/sec
    191 packets input, 25502 bytes, 0 no buffer
    Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
    0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
    0 input packets with dribble condition detected
    216 packets output, 46065 bytes, 0 underruns
    0 output errors, 0 collisions, 1 interface resets
    0 babbles, 0 late collision, 0 deferred
    0 lost carrier, 0 no carrier
    0 output buffer failures, 0 output buffers swapped out
FastEthernet0/0 is up, line protocol is up
 Hardware is PQUICC_FEC, address is 0011.92ec.bb09 (bia 0011.92ec.bb09)
 Description: $ETH-LAN$
 Internet address is 192.168.17.1/24
 MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
 Keepalive set (10 sec)
 Full-duplex, 100Mb/s, 100BaseTX/FX
 Last input 00:00:00, output 00:00:00, output hang never
 5 minute input rate 2000 bits/sec, 5 packets/sec
 5 minute output rate 2000 bits/sec, 3 packets/sec
    503 packets input, 61185 bytes
    Received 233 broadcasts, 0 runts, 0 giants, 0 throttles
    0 watchdog
    242 packets output, 32012 bytes, 0 underruns
NVI0 is up, line protocol is up
 Hardware is NVI
 Interface is unnumbered. Using address of NVI0 (0.0.0.0)
 MTU 1514 bytes, BW 10000000 Kbit, DLY 0 usec,
 Encapsulation UNKNOWN, loopback not set
 Last input never, output never, output hang never
    0 packets input, 0 bytes, 0 no buffer
    0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
    0 packets output, 0 bytes, 0 underruns
    0 output errors, 0 collisions, 0 interface resets
Password:
Virtual-Access1 is up, line protocol is up
 Hardware is Virtual Access interface
 MTU 1500 bytes, BW 56 Kbit, DLY 20000 usec,
 Encapsulation PPP, LCP Open
 Listen: CDPCP
 Open: IPCP
 PPPoE vaccess, cloned from Dialer1
 Vaccess status 0x44, loopback not set
 DTR is pulsed for 5 seconds on reset
 Interface is bound to Di1 (Encapsulation PPP)
 Last input 00:00:31, output never, output hang never
 Last clearing of "show interface" counters 00:06:17
    187 packets input, 21510 bytes, 0 no buffer
    205 packets output, 38232 bytes, 0 underruns
    0 carrier transitions
Dialer1 is up, line protocol is up (spoofing)
 Hardware is Unknown
 Description: connected to Internet
 Internet address is 84.140.144.199/32
 Encapsulation PPP, loopback not set
 DTR is pulsed for 1 seconds on reset
 Interface is bound to Vi1
 Last clearing of "show interface" counters 00:06:24
 Queueing strategy: weighted fair
 Output queue: 0/1000/64/0 (size/max total/threshold/drops)
    Conversations  0/0/16 (active/max active/max total)
    Reserved Conversations 0/0 (allocated/max allocated)
    Available Bandwidth 42 kilobits/sec
    174 packets input, 21307 bytes
    192 packets output, 38045 bytes
Bound to:
 Listen: CDPCP
 Open: IPCP
 Last input 00:00:34, output never, output hang never
 Last clearing of "show interface" counters 00:06:20
    188 packets input, 21524 bytes, 0 no buffer
    206 packets output, 38246 bytes, 0 underruns
ich habe das mal mit sdm getestet und das programm meinte die verbindung wäre erfolgreich denn skype und icq funktionieren ja cuh nur http nicht. wenns würklich an dns namen liegt wie kann ich das testen mein Provider ist t-online?
