osirus01 10 Geschrieben 6. Juni 2007 Melden Geschrieben 6. Juni 2007 Hallo zusammen, wir bei uns das Phänomen, das ausgestellte Zertifikate plötzlich nicht mehr funktionieren. Folge Meldung erscheint dann im LOG-File des VPN-Clients: Cisco Systems VPN Client Version 4.8.00.0440 Copyright © 1998-2005 Cisco Systems, Inc. All Rights Reserved. Client Type(s): Windows, WinNT Running on: 5.1.2600 Service Pack 2 Config file directory: C:\Programme\Cisco Systems\VPN Client Cisco Systems VPN Client Version 4.8.00.0440 Copyright © 1998-2005 Cisco Systems, Inc. All Rights Reserved. Client Type(s): Windows, WinNT Running on: 5.1.2600 Service Pack 2 Config file directory: C:\Programme\Cisco Systems\VPN Client 1 08:43:52.671 06/06/07 Sev=Info/6 CERT/0x63600025 Attempting to find a Certificate using Serial Hash. 2 08:43:52.671 06/06/07 Sev=Info/6 CERT/0x63600026 Found a Certificate using Serial Hash. 3 08:43:52.671 06/06/07 Sev=Info/6 CERT/0x63600025 Attempting to find a Certificate using Serial Hash. 4 08:43:52.671 06/06/07 Sev=Info/6 CERT/0x63600026 Found a Certificate using Serial Hash. 5 08:43:52.687 06/06/07 Sev=Info/6 CERT/0x63600025 Attempting to find a Certificate using Serial Hash. 6 08:43:52.687 06/06/07 Sev=Info/6 CERT/0x63600026 Found a Certificate using Serial Hash. 7 08:43:52.765 06/06/07 Sev=Info/4 CERT/0x63600015 Cert (e=name.nachname@firma.de,cn=name nachname,ou=firma,o=ORGA) verification succeeded. 8 08:43:52.765 06/06/07 Sev=Info/4 CM/0x63100002 Begin connection process 9 08:43:52.781 06/06/07 Sev=Info/4 CVPND/0xE3400001 Microsoft IPSec Policy Agent service stopped successfully 10 08:43:52.781 06/06/07 Sev=Info/4 CM/0x63100004 Establish secure connection using Ethernet 11 08:43:52.781 06/06/07 Sev=Info/4 CM/0x63100024 Attempt connection with server "vpn.firma.de" 12 08:43:53.781 06/06/07 Sev=Info/6 IKE/0x6300003B Attempting to establish a connection with 111.222.333.444. 13 08:43:53.781 06/06/07 Sev=Info/6 CERT/0x63600025 Attempting to find a Certificate using Serial Hash. 14 08:43:53.781 06/06/07 Sev=Info/6 CERT/0x63600026 Found a Certificate using Serial Hash. 15 08:43:53.828 06/06/07 Sev=Info/4 CERT/0x6360001E Function C_SelectPrivateKeyBySPKI failed with an error code - 0x000007A3(C:\temp\build\rel_4.80.572427760761-Fri-04-Nov-2005-17-15-30\rel_4.8\UnityCertAPI\CCertStoreBCERT.cpp:676). 16 08:43:53.828 06/06/07 Sev=Info/4 CERT/0x63600016 Could not load private key for certificate e=name.nachname@firma.de,cn=name nachname,ou=firma,o=ORGA from store Microsoft User Certificate. 17 08:43:53.828 06/06/07 Sev=Warning/2 IKE/0xE3000007 Unable to open certificate (e=name.nachname@firma.de,cn=name nachname,ou=firma,o=ORGA). If you are using a smartcard or token containing a certificate, verify the correct one is plugged in and try again. 18 08:43:53.828 06/06/07 Sev=Warning/2 IKE/0xE3000099 Failed to open my certificate (Connection:240) 19 08:43:53.828 06/06/07 Sev=Warning/2 IKE/0xE3000098 Failed to set up connection data 20 08:43:53.828 06/06/07 Sev=Info/4 CM/0x6310001C Unable to contact server "vpn.firma.de" 21 08:43:53.828 06/06/07 Sev=Info/5 CM/0x63100025 Initializing CVPNDrv 22 08:43:53.828 06/06/07 Sev=Info/4 IKE/0x63000001 IKE received signal to terminate VPN connection 23 08:43:53.828 06/06/07 Sev=Info/4 IKE/0x63000086 Microsoft IPSec Policy Agent service started successfully Zitieren
osirus01 10 Geschrieben 6. Juni 2007 Autor Melden Geschrieben 6. Juni 2007 24 08:43:53.828 06/06/07 Sev=Info/4 IPSEC/0x63700008 IPSec driver successfully started 25 08:43:53.843 06/06/07 Sev=Info/4 IPSEC/0x63700014 Deleted all keys 26 08:43:53.843 06/06/07 Sev=Info/4 IPSEC/0x63700014 Deleted all keys 27 08:43:53.843 06/06/07 Sev=Info/4 IPSEC/0x63700014 Deleted all keys 28 08:43:53.843 06/06/07 Sev=Info/4 IPSEC/0x63700014 Deleted all keys 29 08:43:53.843 06/06/07 Sev=Info/4 IPSEC/0x6370000A IPSec driver successfully stopped Das Problem tritt ganz sporadisch auf und lässt sich durch Austellen eines neuen Zertifikates wieder beheben. Als CA-Server setzen wir Windows 2003-Server R2 SP1 ein. Clients sind Unterschiedlich. Bei dem jetzigen ist Windows XP SP2 mit IE7 Build 7.0.5730.11 Leider konnte ich im Internet nichts zu der Fehlermeldung finden. Hat hier jemand ähnliche Erfahrungen? Danke + Gruß Osirus Zitieren
Wordo 11 Geschrieben 6. Juni 2007 Melden Geschrieben 6. Juni 2007 Wie werden die Zertifikate denn installiert? Weiter, weiter, fertigstellen? Zitieren
osirus01 10 Geschrieben 6. Juni 2007 Autor Melden Geschrieben 6. Juni 2007 Hi Wordo, Sind eigentlich keine besonderen EInstellungen. Zertifikat anfordern -> erweiterte Zertifikatanforderung -> Anforderung an Zertifizierungsstelle erstellen und einreichen -> und dann alles Standardwerte Name, Vorname, Firma, Abteilung, E-Mail Kryptografiedienstanbieter: Gemplus GemSafe Card CSP 1.0 Schlüsselgröße: 1024 Automatischer Schlüsselcontainername Anforderungsformat: CMC Hashalgorythmus : SHA1 Gruß Osirus Zitieren
Wordo 11 Geschrieben 6. Juni 2007 Melden Geschrieben 6. Juni 2007 Besteht die Moeglichkeit den Installationsprozess aus dem VPN Client auszugliedern und selbst vorzunehmen? Zitieren
osirus01 10 Geschrieben 6. Juni 2007 Autor Melden Geschrieben 6. Juni 2007 Hi, weiss jetzt nicht so genau was Du meinst. Aber die Zertifikate werden über den IIS auf dem Cert-Server beantragt. Gruß Michael Zitieren
Wordo 11 Geschrieben 6. Juni 2007 Melden Geschrieben 6. Juni 2007 Genau, dann lad sie einfach runter (ueber Browser) und installier sie per Hand. Also Start - Ausfuehren - mmc, dann Snapin hinzufuegen, Zertifikate, und dann fuer Computer und nicht lokalen User installieren. Dann kannste es ueber den VPN Client aus der Liste auswaehlen. Zitieren
osirus01 10 Geschrieben 6. Juni 2007 Autor Melden Geschrieben 6. Juni 2007 Hehe, genau so mache ich es ja :) Das lustige ist halt, das es bei manchen Anwendern vorkommt und bei manchen ist das Cert noch nie kaputt gegangen. Dachte anfangs, es könnte evt. mit der Kennwortänderung an der lokalen Workstation (Benutzeraccount) zusammenhängen. ISt aber leider auch nicht so. Bei der Einrichtung der VPNM-Verbindung wähle ich halt Cert.Authentication aus und dann das entsprechende Cert. aus dem Cert.Speicher (Was ein Satz ;) ). Die Zertifikate werden auch immer unter dem Benutzer-Account installiert, der später via VPN aufs Netz zugreifen soll. Gruß Osirus Zitieren
Wordo 11 Geschrieben 6. Juni 2007 Melden Geschrieben 6. Juni 2007 Aber die Zertifikate werden dir in der Liste noch angezeigt? Zitieren
osirus01 10 Geschrieben 6. Juni 2007 Autor Melden Geschrieben 6. Juni 2007 Jup, die werden mir noch angezeigt. Kannst Du auch im Logfile sehen. Er sagt mir halt nur, das er auf den Privatekey nicht zugreifen kann. Und jetzt suche ich halt nach der Ursache. Wie gesagt, dacht anfangs es könnte mit der Passwortänderung des Account zusammenhängen - tut es aber nicht. Das lustige ist halt, sobald ich das alte Cert lösche, ein neues Zertifikat beantrage und austelle (mit den gleichen Daten) gehts sofort wieder. Gruß Osirus Zitieren
Wordo 11 Geschrieben 6. Juni 2007 Melden Geschrieben 6. Juni 2007 Das lustige ist halt, sobald ich das alte Cert lösche, ein neues Zertifikat beantrage und austelle (mit den gleichen Daten) gehts sofort wieder. Auch nach einem Reboot? Zitieren
osirus01 10 Geschrieben 6. Juni 2007 Autor Melden Geschrieben 6. Juni 2007 Ja, auch nach einem Reboot. Das ganze hält dann wieder X Tage. Bei manchen kommt es auch gar nicht mehr vor. Hab halt nichts, wo ich irgendwie ansetzen könnte.... Zitieren
Wordo 11 Geschrieben 8. Juni 2007 Melden Geschrieben 8. Juni 2007 Hmmm .. also ehrlich gesagt faellt mir da nich mehr viel ein. Ausser vielleicht mal im Quarantaeneverzeichnis vom Virenscanner schauen ob da was gesperrt wurde?! Vielleicht entdeckt der beim taeglich/woechentlichen Scan irgendwas falsch und sperrts. Zitieren
osirus01 10 Geschrieben 8. Juni 2007 Autor Melden Geschrieben 8. Juni 2007 Schade :( Trotzdem vielen Dank für Deine Hilfe! ;) @Mod Kann man evt. den Beitrag ins Windows-Forum verschieben? Vielleicht kann mir dort ein helfen. Vielen Dank! Gruß Osirus Zitieren
osirus01 10 Geschrieben 13. Juni 2007 Autor Melden Geschrieben 13. Juni 2007 Hallo zusammen, möchte ja nicht drängeln, aber könnte evt. ein Mod den Beitrag in Windows FOrum verschieben? Habe leider immer noch das Problem. Danke+ Gruß Osirus Zitieren
