ISDN-Einwahl - Layer2-Problem
An dem NTBA hängt nur der Router, sonst kein Gerät !!
#do sh debug
PPP:
PPP authentication debugging is on
PPP protocol negotiation debugging is on
Jun 28 10:57:55.692: %DIALER-6-BIND: Interface BR0:1 bound to profile Di99
Jun 28 10:57:55.696: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
Jun 28 10:57:55.696: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to XXXXXXXX N/A
Jun 28 08:57:55.696: BR0:1 PPP: Using dialer call direction
Jun 28 08:57:55.696: BR0:1 PPP: Treating connection as a callin
Jun 28 08:57:55.696: BR0:1 PPP: Session handle[7E0000FC] Session id[149]
Jun 28 08:57:55.696: BR0:1 PPP: Phase is ESTABLISHING, Passive Open
Jun 28 08:57:55.696: BR0:1 LCP: State is Listen
Jun 28 08:57:57.696: BR0:1 LCP: Timeout: State Listen
Jun 28 08:57:57.696: BR0:1 PPP: Authorization NOT required
Jun 28 08:57:57.696: BR0:1 LCP: O CONFREQ [Listen] id 114 len 38
Jun 28 08:57:57.696: BR0:1 LCP: AuthProto MS-CHAP (0x0305C22380)
Jun 28 08:57:57.696: BR0:1 LCP: MagicNumber 0x494BCD00 (0x0506494BCD00)
Jun 28 08:57:57.696: BR0:1 LCP: MRRU 1500 (0x110405DC)
Jun 28 08:57:57.696: BR0:1 LCP: EndpointDisc 1 vpn-XXXXXXXX
Jun 28 08:57:57.696: BR0:1 LCP: (0x13130176706E2D64652D67656E736861)
Jun 28 08:57:57.696: BR0:1 LCP: (0x67656E)
Jun 28 08:57:59.712: BR0:1 LCP: Timeout: State REQsent
Jun 28 08:57:59.712: BR0:1 LCP: O CONFREQ [REQsent] id 115 len 38
Jun 28 08:57:59.712: BR0:1 LCP: AuthProto MS-CHAP (0x0305C22380)
Jun 28 08:57:59.712: BR0:1 LCP: MagicNumber 0x494BCD00 (0x0506494BCD00)
Jun 28 08:57:59.712: BR0:1 LCP: MRRU 1500 (0x110405DC)
Jun 28 08:57:59.712: BR0:1 LCP: EndpointDisc 1 vpn-XXXXXXXX
Jun 28 08:57:59.712: BR0:1 LCP: (0x13130176706E2D64652D67656E736861)
Jun 28 08:57:59.712: BR0:1 LCP: (0x67656E)
Jun 28 10:58:01.572: %ISDN-6-DISCONNECT: Interface BRI0:1 disconnected from 2644980706 , call lasted 5 seconds
Jun 28 10:58:01.572: %LINK-3-UPDOWN: Interface BRI0:1, changed state to down
Jun 28 10:58:01.572: %DIALER-6-UNBIND: Interface BR0:1 unbound from profile Di99
Jun 28 08:58:01.572: BR0:1 PPP: Sending Acct Event[Down] id[80]
Jun 28 08:58:01.572: BR0:1 LCP: State is Closed
Jun 28 08:58:01.572: BR0:1 PPP: Phase is DOWN
da du den offensichtlich nicht runternehmen kannst
Was kann ich nicht runternehmen? Du meinst das "isdn point-to-point-setup"? Das konnte ich ja deaktivieren mit "no isdn point-to-point-setup".
Aber ich habs gerade getestet, wenn ich die TEI statisch zuweise, ist es egal, ob "isdn point-to-point-setup" aktiviert oder nicht.
Wenn ich das richtig verstanden habe, ist die TEI-Aushandlung doch dem Layer 2 zuzuordnen? Wieso sehe ich denn dann im Debug schon Meldungen vom PPP Auth(Layer 3)??
Wofür ist dieser TEI denn genau?
Hi,
der TEI (terminal equipment identifier oder so ähnlich) dient zur Adressierung deines Routers im ISDN. es gibt halt feste oder automatische TEIs. irgendwie scheint da was buggy zu sein, da der layer 3 schon da ist und dir dann der layer 2 wieder wegfliegt, wenn es so funzt lass es einfach, der router hat dann halt immer den gleichen tei. probleme gibt es nur, wenn du jetzt noch nen router reinhängst der auch denselben statischen tei verwenden soll.
gruss
rob
