Oder unter VbScript:
set WshShell = CreateObject("WScript.Shell")
RegPfad = "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\ProductName"
WindowsVersion = WshShell.RegRead(RegPfad)
RegPfad = "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\CSDVersion"
ServicePack = WshShell.RegRead(RegPfad)
Meldung = "Ermitteltes Betriebssystem: " &vbcr & WindowsVersion & ", " & Servicepack
msgbox meldung,vbokonly,"Ergebnis"
Oder zum Download (bitte die Endung ".txt" entfernen ;)):
Get_WinVer_and_SP.vbs.txt
Hier das Beispiel aus dem MS-Scripting repository:
Set dtmConvertedDate = CreateObject("WbemScripting.SWbemDateTime")
strComputer = "."
Set objWMIService = GetObject("winmgmts:" _
   & "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2")
Set colOperatingSystems = objWMIService.ExecQuery _
   ("Select * from Win32_OperatingSystem")
For Each objOperatingSystem in colOperatingSystems
   Wscript.Echo "Boot Device: " & objOperatingSystem.BootDevice
   Wscript.Echo "Build Number: " & objOperatingSystem.BuildNumber
   Wscript.Echo "Build Type: " & objOperatingSystem.BuildType
   Wscript.Echo "Caption: " & objOperatingSystem.Caption
   Wscript.Echo "Code Set: " & objOperatingSystem.CodeSet
   Wscript.Echo "Country Code: " & objOperatingSystem.CountryCode
   Wscript.Echo "Debug: " & objOperatingSystem.Debug
   Wscript.Echo "Encryption Level: " & objOperatingSystem.EncryptionLevel
   dtmConvertedDate.Value = objOperatingSystem.InstallDate
   dtmInstallDate = dtmConvertedDate.GetVarDate
   Wscript.Echo "Install Date: " & dtmInstallDate
   Wscript.Echo "Licensed Users: " & _
       objOperatingSystem.NumberOfLicensedUsers
   Wscript.Echo "Organization: " & objOperatingSystem.Organization
   Wscript.Echo "OS Language: " & objOperatingSystem.OSLanguage
   Wscript.Echo "OS Product Suite: " & objOperatingSystem.OSProductSuite
   Wscript.Echo "OS Type: " & objOperatingSystem.OSType
   Wscript.Echo "Primary: " & objOperatingSystem.Primary
   Wscript.Echo "Registered User: " & objOperatingSystem.RegisteredUser
   Wscript.Echo "Serial Number: " & objOperatingSystem.SerialNumber
   Wscript.Echo "Version: " & objOperatingSystem.Version
Next
Als Sprache wird allerdings der interne Sprachcode zurückgeliefert, 1031 ist Deutsch.
Für andere Sprachen einfach mal bei MS suchen...
