Gadget 37 Geschrieben 9. Juli 2007 Melden Teilen Geschrieben 9. Juli 2007 Vor kurzem wurde das bereits bei Microsoft Intern sehr beliebte Tool VMRC Plus im Downloadcenter für die Öffentlichkeit freigegeben. Wer Virtual Server 2005 R2 einsetzt, sollte sich das Toolkit auf jedenfall mal anschauen. Da es eine deutlich verbesserte GUI für die Fernsteuerung von Gastsystemen darstellt als die normale "VMRC = Virtual Maschine Remote Control" [MSFT-BE] Arlindo's Blog - IT Pro Evangelist : Manage your Virtual Server Machines with VMRC Plus * Direct control of local or remote instances of the Virtual Server service. IIS and IE browser are no longer required! * Tabbed interface to quickly jump between Virtual Server hosts and guest VMRC sessions. * Reusable saved states: this feature allows users to preserve a particular saved state and return to that state at any time. * Multiple guest selection supported for startup/shutdown/save/display. * Browse button navigation for media, hard disk images, ISO images, .VMC files, etc. * Drag and Drop support for .VMC files, ISO's images, VHD and VFD files. * Resizable desktop support for guests running Virtual Machine Additions (maximize VMRC window supported). * Limited cut and paste of text from host to guest (only). * A built-in utility to take JPG screenshots of running guests. Useful when filing bugs. * Built-in error notification with Virtual Server event log viewer. * A Virtual Networks Manager and Virtual Disks Manager that cover all features. * Keyboard shortcuts (e.g. Ctrl-S to save state a guest). * Create multiple guests at once. * Create guest from parent (or multiple guests)! * Automatic reconnect to a designated Virtual Server host. * Toolbars in both Guest and Console Manager for quick access. * Unlimited number of guests. * Maximum of 32 Virtual Server hosts. * Sorting on columns of guests so you can sort based on status and multi-select. * Automatic detection of Virtual Machine Additions and notification. * Detection of Virtual Server 2005 R2 SP1. Der offizielle Blog zu VMRC Plus (Fragen und Feedback können dort Direkt an den Entwickler gesandt werden): VMRCplus Download: Download details: Virtual Machine Remote Control Client Plus (VMRCplus) LG Gadget Zitieren Link zu diesem Kommentar
Necron 71 Geschrieben 9. Juli 2007 Melden Teilen Geschrieben 9. Juli 2007 Klasse Sache die VMRC Plus.:thumb1: Zitieren Link zu diesem Kommentar
Gadget 37 Geschrieben 28. Juli 2007 Autor Melden Teilen Geschrieben 28. Juli 2007 Kann ich mit VMRC Plus, auf Host-Server außerhalb der Domäne zugreifen? => Nein, alternative Credentials lassen sich mit VMRC Plus leider nicht übergeben: VMRCplus : VMRCplus and authentication Zitieren Link zu diesem Kommentar
