Problem beim Verbindungsaufbau mit Cisco 876 über DSL
Hi zusammen,
hab nen 876er der via DSL ins I-Net soll.
Das PPP-Lämpchen leuchtet, aber ich bekomme keine Verbindung. Mit nem anderen Router (nicht Cisco ) geht es.
Anbei meine Konfig, auch auf die Gefahr hin diverse Lacher zu provozieren:
version 12.4
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname gw-01
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.11.1 192.168.11.10
ip dhcp pool client
import all
network 192.168.11.0 255.255.255.0
default-router 192.168.11.1
dns-server 195.186.1.111
lease 7 12 23
ip inspect name myfw cuseeme timeout 3600
ip inspect name myfw ftp timeout 3600
ip inspect name myfw rcmd timeout 3600
ip inspect name myfw realaudio timeout 3600
ip inspect name myfw smtp timeout 3600
ip inspect name myfw tftp timeout 30
ip inspect name myfw udp timeout 15
ip inspect name myfw tcp timeout 3600
ip inspect name myfw h323 timeout 3600
ip flow-cache timeout active 5
no ip domain lookup
!username XXX password 0 encryption XXX
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
description WAN ADSL
no ip address
atm vc-per-vp 64
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.2 point-to-point
pvc 8/35
encapsulation aal5snap
protocol ppp dialer
dialer pool-member 1
interface FastEthernet0
description LAN
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
ip address 192.168.11.1 255.255.255.0
ip access-group 122 out
no ip unreachables
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Dialer1
ip address negotiated
ip access-group 111 in
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer remote-name redback
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname xxx@bluewin.ch
ppp chap password 0 xxx
ppp pap sent-username xxx@bluewin.ch password 0 xxx
ppp ipcp address accept
ip classless
no ip http server
no ip http secure-server
ip nat inside source list 102 interface Dialer1 overload
access-list 2 permit 192.168.11.0 0.0.0.255
access-list 2 deny any
access-list 23 permit 192.168.11.0 0.0.0.255
access-list 102 permit ip 192.168.11.0 0.0.0.255 any
access-list 111 permit ip any any
access-list 122 deny tcp any any eq telnet
access-list 122 permit ip any any
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
Gurss und besten Dank im voraus
Olaf
Hi zusammen,
erst mal Danke fuer die Infos.
Ich selber bin ein waschechter Westfaelischer Dickschaedel, der Kunde sityt in der schoenen Schweiz, leider immer noch ywei Stunden mit dem Auto weg von den Bergen......lechz.
pvc 8/35 gibt bluewin tatsaechlich auf seiner Seite so vor, diese Einstellung in einem Zyxel-Router funzt prima.
Aua. Ich wusste doch das ich was uebersehen habe. Danke fuer den Hinweis auf die defaultroute, mann oh mann bin ich blond....:-)
Gruss und guten Abend miteinander
Olaf
