a_hempelt 10 Geschrieben 27. Juli 2007 Melden Teilen Geschrieben 27. Juli 2007 Hallo, folgendes Problem bei Importieren von PST mit Exmerge. Ich bin als Admin angemeldet, habe dem Administrator und Domänen-Admins im Ex-Sys-Manag unter "Erste Administrative Gruppe" -> "SERVER-EX" Vollzugriff (Deny bei Receive AS und Send AS entfernt!) Dennoch bekomme ich diese Fehlermeldung, die ich nicht wirklich deuten kann. Danke für Eure Hilfe. **************************************************************** Microsoft Exchange Mailbox Merge Program, v6.5.7529.0 Start Logging:July 27, 2007 10:18:09 **************************************************************** [10:18:09] Logging Level: None [10:18:09] Reading settings from file 'D:\Exchsrvr\bin\EXMERGE.INI'. [10:18:09] Accessing Domain Controller 'SERVER-EX' [10:18:09] 'SERVER-EX' is running Exchange Server 2000 or later [10:18:09] Destination server read from settings file is 'SERVER-EX'. [10:18:09] Reading list of subjects for messages to be selected from file '' [10:18:09] Reading list of attachment names for messages to be selected from file '' [10:18:09] List of folders to be ignored has been read. 0 folders in the list. [10:18:09] Current machine locale ID is 0x407 [10:18:09] Operating System Version 5.2 (Build 3790) [10:18:12] Accessing Domain Controller 'SERVER-EX' [10:18:12] 'SERVER-EX' is running Exchange Server 2000 or later [10:18:17] Mailbox '/o=DRKExchange/ou=Erste administrative Gruppe/cn=Configuration/cn=Servers/cn=SERVER-EX/cn=Microsoft System Attendant' will be ignored as its DN contains strings in the ignore list [10:18:17] Mailbox '/o=DRKExchange/ou=Erste administrative Gruppe/cn=Configuration/cn=Connections/cn=SMTP (SERVER-EX)/cn={06CA539C-513B-483D-AF2D-4684F47FA379}' will be ignored as its DN contains strings in the ignore list [10:18:17] Mailbox '/o=DRKExchange/ou=Erste administrative Gruppe/cn=Recipients/cn=SystemMailbox{06CA539C-513B-483D-AF2D-4684F47FA379}' will be ignored as its DN contains strings in the ignore list [10:18:17] Found 111 mailbox(es) homed on database 'ERSTE SPEICHERGRUPPE/POSTFACHSPEICHER (SERVER-EX)'. [10:18:17] Ignored 3 mailbox(es) homed on database 'ERSTE SPEICHERGRUPPE/POSTFACHSPEICHER (SERVER-EX)'. [10:18:17] Found 111 mailbox(es) homed on the specified databases. [10:18:17] Ignored 3 mailbox(es) homed on the specified databases. [10:18:26] Using attribute 'PR_MESSAGE_DELIVERY_TIME' for date operations. [10:18:26] Merging data into target store. The program will copy only those messages that do not exist in the target store. [10:18:26] Associated folder data will NOT be copied to the target store. [10:18:26] Using 'German' (0x407) as the default locale (Code page 1252) [10:18:26] All mailboxes will be processed, regardless of locale [10:18:26] Using default locale for all mailboxes [10:18:26] Initializing worker thread (Thread0) [10:18:26] Merging data from file '\\SERVER-FS\BACKUP_EXCHANGE_070725\M_Mustermann.PST' to mailbox 'Mustermann Max' ('M_Mustermann') on server 'SERVER-EX'. [10:18:26] Store 'MSPST MS' was not opened. [10:18:26] Errors encountered. Copy process aborted for mailbox 'Mustermann Max' ('M_Mustermann'). [10:18:26] Number of items copied from the source store for all mailboxes processed: 0 [10:18:26] Total number of folders processed in the source store: 0 [10:18:26] 0 mailboxes successfully processed. 1 mailboxes were not successfully processed. 0 non-fatal errors encountered. [10:18:26] Process completion time: 00:00:00 Zitieren Link zu diesem Kommentar
Christoph35 10 Geschrieben 27. Juli 2007 Melden Teilen Geschrieben 27. Juli 2007 Gibt es auf dem betreffenden Mailbox-Store sonst keine Deny-Einträge mehr für SendAs und Receive As? Auch nicht in den Security Settings des User-Kontos ? (da sollten normalerweise auch keine sein, aber besser einmal zu viel als einmal zu wenig schauen.) Dann setze mal in der exmerge.ini den Logging-Level auf 3 (maximum). Danach starte noch mal ExMerge und stelle das neue Log hier rein. Christoph Zitieren Link zu diesem Kommentar
a_hempelt 10 Geschrieben 27. Juli 2007 Autor Melden Teilen Geschrieben 27. Juli 2007 Gibt es auf dem betreffenden Mailbox-Store sonst keine Deny-Einträge mehr für SendAs und Receive As? Habe bei alle Deny-Einträge entfernt, es gibt entweder keinen Eintrag oder Zulassen. Verweigern ist kein Eintrag. Aktuelles exmerge.log **************************************************************** Microsoft Exchange Mailbox Merge Program, v6.5.7529.0 Start Logging:July 27, 2007 11:07:18 **************************************************************** [11:07:18] Logging Level: Maximum [11:07:18] Reading settings from file 'D:\Exchsrvr\bin\EXMERGE.INI'. [11:07:18] Data directory name read from .INI file: '\\SERVER-FS\BACKUP_EXCHANGE_070725'. [11:07:18] Merge action read from .INI file: 1 [11:07:18] DomainControllerForSourceServer read from INI file: '' [11:07:18] SrcServerLDAP-Port read from INI file: '' [11:07:18] Source server name read from .INI file: ''. [11:07:18] DomainControllerForDestServer read from INI file: '' [11:07:18] SrcServerLDAP-Port read from INI file: '' [11:07:18] Destination server name read from .INI file: 'SERVER-EX'. [11:07:18] Entered Routine: (CADRoutines::IdentifyFamilyOfExchangeRunningOnServer) [11:07:18] Entered Routine: (CADRoutines::GetNamingContextData) [11:07:18] BaseDN: 'LDAP://SERVER-EX/rootDSE' [11:07:18] Ending Routine: (CADRoutines::GetNamingContextData) [11:07:18] Default Naming Context: 'DC=mydomain,DC=local' [11:07:18] Entered Routine: (CADRoutines::GetNamingContextData) [11:07:18] BaseDN: 'LDAP://rootDSE' [11:07:18] Ending Routine: (CADRoutines::GetNamingContextData) [11:07:18] Default Naming Context: 'DC=mydomain,DC=local' [11:07:18] Accessing Domain Controller 'SERVER-EX' [11:07:18] Entered Routine: (CADRoutines::GetExchangeServerNameInfo) [11:07:18] BaseDN: 'LDAP://SERVER-EX/CN=Microsoft Exchange,CN=Services,CN=Configuration,DC=mydomain,DC=local' [11:07:18] Got IDirectorySearch interface [11:07:18] Set search preferences [11:07:18] Filter used: '(&(objectCategory=msexchExchangeServer)(cn=SERVER-EX))' [11:07:18] Successfully executed directory search [11:07:18] Ending Routine: (CADRoutines::GetExchangeServerNameInfo) [11:07:18] 'SERVER-EX' is running Exchange Server 2000 or later [11:07:18] Ending Routine: (CADRoutines::IdentifyFamilyOfExchangeRunningOnServer) [11:07:18] Destination server read from settings file is 'SERVER-EX'. [11:07:18] Message selection start date read from .INI file: ''. [11:07:18] Reading list of subjects for messages to be selected from file '' [11:07:18] Subject string match criteria read from INI file: 0 [11:07:18] Reading list of attachment names for messages to be selected from file '' [11:07:18] Attachment name string match criteria read from INI file: 0 [11:07:18] Folder process setting read from .INI file: 2 [11:07:18] Apply to sub folders setting, read from .INI file: 0 [11:07:18] List of folders to be ignored has been read. 0 folders in the list. [11:07:18] DelimiterUsedInMailboxFile setting read from .INI file: 0 [11:07:18] File containing list of mailboxes, read from .INI file: 'D:\EXCHSRVR\BIN\MAILBOXES.TXT'. Zitieren Link zu diesem Kommentar
a_hempelt 10 Geschrieben 27. Juli 2007 Autor Melden Teilen Geschrieben 27. Juli 2007 [11:07:18] Remove intermediate PST files setting read from .INI file: 1 [11:07:18] Date attribute read from .INI file: 0 [11:07:18] Data import method read from .INI file: 1 [11:07:18] ReplaceDataOnlyIfSourceItemIsMoreRecent setting read from .INI file: 1 [11:07:18] Copy user data setting read from .INI file: 1 [11:07:18] Copy associated folder data setting read from .INI file: 0 [11:07:18] Copy folder permissions setting read from .INI file: 0 [11:07:18] Copy dumpster items setting read from .INI file: 0 [11:07:18] UseThisPSTFileForAllMailboxes setting read from .INI file: '' [11:07:18] MapFolderNameToLocalisedName setting read from .INI file: 0 [11:07:18] RenameFoldersBasedOnFolderMappings setting read from INI file: 0 [11:07:18] RenameSpecialFolders setting read from INI file: 1 [11:07:18] Default Locale read from INI file: 1031 [11:07:18] UseLastLogonLocaleID setting read from INI file: 0 [11:07:18] Current machine locale ID is 0x407 [11:07:18] Command line received: [11:07:18] Processor architecture: Intel [11:07:18] Operating System Version 5.2 (Build 3790) [11:07:22] Entered Routine: (CADRoutines::IdentifyFamilyOfExchangeRunningOnServer) [11:07:22] Entered Routine: (CADRoutines::GetNamingContextData) [11:07:22] BaseDN: 'LDAP://SERVER-EX/rootDSE' [11:07:22] Ending Routine: (CADRoutines::GetNamingContextData) [11:07:22] Default Naming Context: 'DC=mydomain,DC=local' [11:07:22] Entered Routine: (CADRoutines::GetNamingContextData) [11:07:22] BaseDN: 'LDAP://rootDSE' [11:07:22] Ending Routine: (CADRoutines::GetNamingContextData) [11:07:22] Default Naming Context: 'DC=mydomain,DC=local' [11:07:22] Accessing Domain Controller 'SERVER-EX' [11:07:22] Entered Routine: (CADRoutines::GetExchangeServerNameInfo) [11:07:22] BaseDN: 'LDAP://SERVER-EX/CN=Microsoft Exchange,CN=Services,CN=Configuration,DC=mydomain,DC=local' [11:07:22] Got IDirectorySearch interface [11:07:22] Set search preferences [11:07:22] Filter used: '(&(objectCategory=msexchExchangeServer)(cn=SERVER-EX))' [11:07:22] Successfully executed directory search [11:07:22] Ending Routine: (CADRoutines::GetExchangeServerNameInfo) [11:07:22] 'SERVER-EX' is running Exchange Server 2000 or later [11:07:22] Ending Routine: (CADRoutines::IdentifyFamilyOfExchangeRunningOnServer) [11:07:22] Entered Routine: (CADRoutines::GetExchangeServerStorageGroupInfo) [11:07:22] BaseDN: 'GC://CN=InformationStore,CN=SERVER-EX,CN=Servers,CN=Erste administrative Gruppe,CN=Administrative Groups,CN=MyExchange,CN=Microsoft Exchange,CN=Services,CN=Configuration,DC=mydomain,DC=local' [11:07:22] Got IDirectorySearch interface [11:07:22] Set search preferences [11:07:22] Filter used: '(objectClass=msexchPrivateMDB)' Zitieren Link zu diesem Kommentar
a_hempelt 10 Geschrieben 27. Juli 2007 Autor Melden Teilen Geschrieben 27. Juli 2007 [11:07:22] Successfully executed directory search [11:07:22] Ending Routine: (CADRoutines::GetExchangeServerStorageGroupInfo) [11:07:22] Entered Routine: (CADRoutines::GetMailboxesHomedOnExchangeServerDatabases) [11:07:24] Mailbox '/o=MyExchange/ou=Erste administrative Gruppe/cn=Configuration/cn=Servers/cn=SERVER-EX/cn=Microsoft System Attendant' will be ignored as its DN contains strings in the ignore list [11:07:24] Mailbox '/o=MyExchange/ou=Erste administrative Gruppe/cn=Configuration/cn=Connections/cn=SMTP (SERVER-EX)/cn={06CA539C-513B-483D-AF2D-4684F47FA379}' will be ignored as its DN contains strings in the ignore list [11:07:24] Mailbox '/o=MyExchange/ou=Erste administrative Gruppe/cn=Recipients/cn=SystemMailbox{06CA539C-513B-483D-AF2D-4684F47FA379}' will be ignored as its DN contains strings in the ignore list [11:07:24] Found 111 mailbox(es) homed on database 'ERSTE SPEICHERGRUPPE/POSTFACHSPEICHER (SERVER-EX)'. [11:07:24] Ignored 3 mailbox(es) homed on database 'ERSTE SPEICHERGRUPPE/POSTFACHSPEICHER (SERVER-EX)'. [11:07:24] Found 111 mailbox(es) homed on the specified databases. [11:07:24] Ignored 3 mailbox(es) homed on the specified databases. [11:07:24] Ending Routine: (CADRoutines::GetMailboxesHomedOnExchangeServerDatabases) [11:07:24] Entered Routine: (CMapiSession::CreateSystemAttendantProfile) [11:07:24] Entered Routine: (CAdminProfileRoutines::CreateSystemAttendantProfile) [11:07:24] Entered Routine: (CAdminProfileRoutines::CreateSystemAttendantProfile) [11:07:24] Entered Routine: (CAdminProfileRoutines::HackMapiSvcInfForSA) [11:07:24] Ending Routine: (CAdminProfileRoutines::HackMapiSvcInfForSA) [11:07:24] Ending Routine: (CAdminProfileRoutines::CreateSystemAttendantProfile) [11:07:24] Ending Routine: (CAdminProfileRoutines::CreateSystemAttendantProfile) [11:07:24] Ending Routine: (CMapiSession::CreateSystemAttendantProfile) [11:07:24] Entered Routine: (CMapiSession::Logon) [11:07:24] Entered Routine: (CMapiSession::MapiInit) [11:07:24] Successfully initialized MAPI. [11:07:24] Ending Routine: (CMapiSession::MapiInit) [11:07:24] MAPI Logon successful. [11:07:24] Ending Routine: (CMapiSession::Logon) [11:07:24] Entered Routine: (CMapiSession::GetMailboxesOnServer) [11:07:24] Getting list of mailboxes on the server. [11:07:24] Found default store. [11:07:24] Opened Exchange Server Store. [11:07:24] Entered Routine: (CMapiSession::GetMailboxesOnServerFromPrivateIS) [11:07:24] GetMailboxesOnServerFromPrivateIS: QueryInterface succeeded [11:07:24] GetMailboxesOnServerFromPrivateIS: GetMailboxTable succeeded [11:07:24] Number of mailbox records read: 31. (CMapiSession::GetMailboxesOnServerFromPrivateIS) [11:07:24] Ending Routine: (CMapiSession::GetMailboxesOnServerFromPrivateIS) [11:07:24] Finished getting list of mailboxes. [11:07:24] Ending Routine: (CMapiSession::GetMailboxesOnServer) [11:07:24] Session logoff successful. [11:07:24] Entered Routine: (CMapiSession::DeleteOurProfile) [11:07:24] Ending Routine: (CMapiSession::DeleteOurProfile) [11:07:24] Time to get mailbox data: 1 seconds [11:07:31] Using attribute 'PR_MESSAGE_DELIVERY_TIME' for date operations. [11:07:31] Merging data into target store. The program will copy only those messages that do not exist in the target store. [11:07:31] Associated folder data will NOT be copied to the target store. [11:07:31] Using 'German' (0x407) as the default locale (Code page 1252) [11:07:31] All mailboxes will be processed, regardless of locale [11:07:31] Using default locale for all mailboxes [11:07:31] Program will use 1 worker threads [11:07:31] Initializing worker thread (Thread0) [11:07:31] ((Thread0)) Before CopyMailboxData -M_Mustermann [11:07:31] Entered Routine: EDKRoutines::CopyMailBoxData) [11:07:31] Using locale 'German' (0x407) and code page 1252 to connect to mailbox Zitieren Link zu diesem Kommentar
a_hempelt 10 Geschrieben 27. Juli 2007 Autor Melden Teilen Geschrieben 27. Juli 2007 [11:07:31] Merging data from file '\\SERVER-FS\BACKUP_EXCHANGE_070725\M_Mustermann.PST' to mailbox 'Mustermann Max' ('M_Mustermann') on server 'SERVER-EX'. [11:07:31] DN of object is '/O=MyExchange/OU=ERSTE ADMINISTRATIVE GRUPPE/CN=RECIPIENTS/CN=M_Mustermann'. [11:07:31] Entered Routine: (CMapiSession::MapiInit) [11:07:31] Successfully initialized MAPI. [11:07:31] Ending Routine: (CMapiSession::MapiInit) [11:07:31] Entered Routine: (CMapiSession::CreateEMSPSTProfile) [11:07:31] Ending Routine: (CMapiSession::CreateEMSPSTProfile) [11:07:31] Successfully created profile. [11:07:31] Entered Routine: (CMapiSession::Logon) [11:07:31] Entered Routine: (CMapiSession::MapiInit) [11:07:31] Successfully initialized MAPI. [11:07:31] Ending Routine: (CMapiSession::MapiInit) [11:07:31] MAPI Logon successful. [11:07:31] Ending Routine: (CMapiSession::Logon) [11:07:31] Entered Routine: (CMapiSession::GetSession) [11:07:31] Ending Routine: (CMapiSession::GetSession) [11:07:31] Entered Routine: EDKRoutines::OpenStores) [11:07:31] OpenStores: Start [11:07:31] GetMsgStoresTable successful. [11:07:31] Checking service 'Microsoft Exchange-Nachrichtenspeicher' [11:07:31] Checking service 'Persnliche Ordner' [11:07:31] Store 'MSPST MS' was not opened. [11:07:31] Ending Routine: EDKRoutines::OpenStores) [11:07:31] Errors encountered. Copy process aborted for mailbox 'Mustermann Max' ('M_Mustermann'). [11:07:31] Entered Routine: (CMapiSession::DeleteOurProfile) [11:07:31] Ending Routine: (CMapiSession::DeleteOurProfile) [11:07:31] Session logoff successful. [11:07:31] Ending Routine: EDKRoutines::CopyMailBoxData) [11:07:31] ((Thread0)) CopyMailboxData Failed -M_Mustermann [11:07:31] ((Thread0)) Incremented progress bar [11:07:31] Number of items copied from the source store for all mailboxes processed: 0 [11:07:31] Total number of folders processed in the source store: 0 [11:07:31] 0 mailboxes successfully processed. 1 mailboxes were not successfully processed. 0 non-fatal errors encountered. [11:07:31] Process completion time: 00:00:00 [11:07:31] MAPI uninitialized. [11:07:33] MAPI uninitialized. Zitieren Link zu diesem Kommentar
Christoph35 10 Geschrieben 27. Juli 2007 Melden Teilen Geschrieben 27. Juli 2007 [11:07:31] Checking service 'Persnliche Ordner'[11:07:31] Store 'MSPST MS' was not opened. Die Zeilen habe ich zunächst übersehen... :o Ok, du scheinst ein Problem mit Länder-Einstellungen zu haben. Schau mal hier: Troubleshooting ExMerge Issues Fast ganz am Ende des Artikels steht was dazu. Christoph Zitieren Link zu diesem Kommentar
a_hempelt 10 Geschrieben 27. Juli 2007 Autor Melden Teilen Geschrieben 27. Juli 2007 **************************************************************** Microsoft Exchange Mailbox Merge Program, v6.5.7529.0 Start Logging:July 27, 2007 11:24:07 **************************************************************** [11:24:07] Logging Level: Maximum [11:24:07] Reading settings from file 'D:\Exchsrvr\bin\EXMERGE.INI'. [11:24:07] Data directory name read from .INI file: '\\SERVER-FS\BACKUP_EXCHANGE_070725'. [11:24:07] Merge action read from .INI file: 1 [11:24:07] DomainControllerForSourceServer read from INI file: '' [11:24:07] SrcServerLDAP-Port read from INI file: '' [11:24:07] Source server name read from .INI file: ''. [11:24:07] DomainControllerForDestServer read from INI file: '' [11:24:07] SrcServerLDAP-Port read from INI file: '' [11:24:07] Destination server name read from .INI file: 'SERVER-EX'. [11:24:07] Entered Routine: (CADRoutines::IdentifyFamilyOfExchangeRunningOnServer) [11:24:07] Entered Routine: (CADRoutines::GetNamingContextData) [11:24:07] BaseDN: 'LDAP://SERVER-EX/rootDSE' [11:24:07] Ending Routine: (CADRoutines::GetNamingContextData) [11:24:07] Default Naming Context: 'DC=MyDomain,DC=local' [11:24:07] Entered Routine: (CADRoutines::GetNamingContextData) [11:24:07] BaseDN: 'LDAP://rootDSE' [11:24:07] Ending Routine: (CADRoutines::GetNamingContextData) [11:24:07] Default Naming Context: 'DC=MyDomain,DC=local' [11:24:07] Accessing Domain Controller 'SERVER-EX' [11:24:07] Entered Routine: (CADRoutines::GetExchangeServerNameInfo) [11:24:07] BaseDN: 'LDAP://SERVER-EX/CN=Microsoft Exchange,CN=Services,CN=Configuration,DC=MyDomain,DC=local' [11:24:07] Got IDirectorySearch interface [11:24:07] Set search preferences [11:24:07] Filter used: '(&(objectCategory=msexchExchangeServer)(cn=SERVER-EX))' [11:24:07] Successfully executed directory search [11:24:07] Ending Routine: (CADRoutines::GetExchangeServerNameInfo) [11:24:07] 'SERVER-EX' is running Exchange Server 2000 or later [11:24:07] Ending Routine: (CADRoutines::IdentifyFamilyOfExchangeRunningOnServer) [11:24:07] Destination server read from settings file is 'SERVER-EX'. [11:24:07] Message selection start date read from .INI file: ''. [11:24:07] Reading list of subjects for messages to be selected from file '' [11:24:07] Subject string match criteria read from INI file: 0 [11:24:07] Reading list of attachment names for messages to be selected from file '' [11:24:07] Attachment name string match criteria read from INI file: 0 [11:24:07] Folder process setting read from .INI file: 2 [11:24:07] Apply to sub folders setting, read from .INI file: 0 [11:24:07] List of folders to be ignored has been read. 0 folders in the list. [11:24:07] DelimiterUsedInMailboxFile setting read from .INI file: 0 [11:24:07] File containing list of mailboxes, read from .INI file: 'D:\EXCHSRVR\BIN\MAILBOXES.TXT'. [11:24:07] Remove intermediate PST files setting read from .INI file: 1 [11:24:07] Date attribute read from .INI file: 0 [11:24:07] Data import method read from .INI file: 1 [11:24:07] ReplaceDataOnlyIfSourceItemIsMoreRecent setting read from .INI file: 1 [11:24:07] Copy user data setting read from .INI file: 1 [11:24:07] Copy associated folder data setting read from .INI file: 0 [11:24:07] Copy folder permissions setting read from .INI file: 0 [11:24:07] Copy dumpster items setting read from .INI file: 0 [11:24:07] UseThisPSTFileForAllMailboxes setting read from .INI file: '' [11:24:07] MapFolderNameToLocalisedName setting read from .INI file: 0 [11:24:07] RenameFoldersBasedOnFolderMappings setting read from INI file: 0 [11:24:07] RenameSpecialFolders setting read from INI file: 1 [11:24:07] Default Locale read from INI file: 1031 [11:24:07] UseLastLogonLocaleID setting read from INI file: 0 [11:24:07] Current machine locale ID is 0x407 Zitieren Link zu diesem Kommentar
a_hempelt 10 Geschrieben 27. Juli 2007 Autor Melden Teilen Geschrieben 27. Juli 2007 [11:24:07] Command line received: [11:24:07] Processor architecture: Intel [11:24:07] Operating System Version 5.2 (Build 3790) [11:24:07] Personal Folders service name got from EXMERGE.INI file is 'Persnliche Ordner' (LocalisedPersonalFoldersServiceName entry in section [EXMERGE]). [11:24:07] Exchange Server service name got from EXMERGE.INI file is 'Microsoft Exchange Message Store' (LocalisedExchangeServerServiceName entry in section [EXMERGE]). [11:24:13] Entered Routine: (CADRoutines::IdentifyFamilyOfExchangeRunningOnServer) [11:24:13] Entered Routine: (CADRoutines::GetNamingContextData) [11:24:13] BaseDN: 'LDAP://SERVER-EX/rootDSE' [11:24:13] Ending Routine: (CADRoutines::GetNamingContextData) [11:24:13] Default Naming Context: 'DC=MyDomain,DC=local' [11:24:13] Entered Routine: (CADRoutines::GetNamingContextData) [11:24:13] BaseDN: 'LDAP://rootDSE' [11:24:13] Ending Routine: (CADRoutines::GetNamingContextData) [11:24:13] Default Naming Context: 'DC=MyDomain,DC=local' [11:24:13] Accessing Domain Controller 'SERVER-EX' [11:24:13] Entered Routine: (CADRoutines::GetExchangeServerNameInfo) [11:24:13] BaseDN: 'LDAP://SERVER-EX/CN=Microsoft Exchange,CN=Services,CN=Configuration,DC=MyDomain,DC=local' [11:24:13] Got IDirectorySearch interface [11:24:13] Set search preferences [11:24:13] Filter used: '(&(objectCategory=msexchExchangeServer)(cn=SERVER-EX))' [11:24:13] Successfully executed directory search [11:24:13] Ending Routine: (CADRoutines::GetExchangeServerNameInfo) [11:24:13] 'SERVER-EX' is running Exchange Server 2000 or later [11:24:13] Ending Routine: (CADRoutines::IdentifyFamilyOfExchangeRunningOnServer) [11:24:13] Entered Routine: (CADRoutines::GetExchangeServerStorageGroupInfo) [11:24:13] BaseDN: 'GC://CN=InformationStore,CN=SERVER-EX,CN=Servers,CN=Erste administrative Gruppe,CN=Administrative Groups,CN=MyExchange,CN=Microsoft Exchange,CN=Services,CN=Configuration,DC=MyDomain,DC=local' [11:24:13] Got IDirectorySearch interface [11:24:13] Set search preferences [11:24:13] Filter used: '(objectClass=msexchPrivateMDB)' [11:24:13] Successfully executed directory search [11:24:14] Ending Routine: (CADRoutines::GetExchangeServerStorageGroupInfo) [11:24:14] Entered Routine: (CADRoutines::GetMailboxesHomedOnExchangeServerDatabases) [11:24:15] Mailbox '/o=MyExchange/ou=Erste administrative Gruppe/cn=Configuration/cn=Servers/cn=SERVER-EX/cn=Microsoft System Attendant' will be ignored as its DN contains strings in the ignore list [11:24:15] Mailbox '/o=MyExchange/ou=Erste administrative Gruppe/cn=Configuration/cn=Connections/cn=SMTP (SERVER-EX)/cn={06CA539C-513B-483D-AF2D-4684F47FA379}' will be ignored as its DN contains strings in the ignore list [11:24:15] Mailbox '/o=MyExchange/ou=Erste administrative Gruppe/cn=Recipients/cn=SystemMailbox{06CA539C-513B-483D-AF2D-4684F47FA379}' will be ignored as its DN contains strings in the ignore list [11:24:15] Found 111 mailbox(es) homed on database 'ERSTE SPEICHERGRUPPE/POSTFACHSPEICHER (SERVER-EX)'. [11:24:15] Ignored 3 mailbox(es) homed on database 'ERSTE SPEICHERGRUPPE/POSTFACHSPEICHER (SERVER-EX)'. Zitieren Link zu diesem Kommentar
a_hempelt 10 Geschrieben 27. Juli 2007 Autor Melden Teilen Geschrieben 27. Juli 2007 [11:24:15] Found 111 mailbox(es) homed on the specified databases. [11:24:15] Ignored 3 mailbox(es) homed on the specified databases. [11:24:15] Ending Routine: (CADRoutines::GetMailboxesHomedOnExchangeServerDatabases) [11:24:15] Entered Routine: (CMapiSession::CreateSystemAttendantProfile) [11:24:15] Entered Routine: (CAdminProfileRoutines::CreateSystemAttendantProfile) [11:24:15] Entered Routine: (CAdminProfileRoutines::CreateSystemAttendantProfile) [11:24:16] Entered Routine: (CAdminProfileRoutines::HackMapiSvcInfForSA) [11:24:16] Ending Routine: (CAdminProfileRoutines::HackMapiSvcInfForSA) [11:24:16] Ending Routine: (CAdminProfileRoutines::CreateSystemAttendantProfile) [11:24:16] Ending Routine: (CAdminProfileRoutines::CreateSystemAttendantProfile) [11:24:16] Ending Routine: (CMapiSession::CreateSystemAttendantProfile) [11:24:16] Entered Routine: (CMapiSession::Logon) [11:24:16] Entered Routine: (CMapiSession::MapiInit) [11:24:16] Successfully initialized MAPI. [11:24:16] Ending Routine: (CMapiSession::MapiInit) [11:24:16] MAPI Logon successful. [11:24:16] Ending Routine: (CMapiSession::Logon) [11:24:16] Entered Routine: (CMapiSession::GetMailboxesOnServer) [11:24:16] Getting list of mailboxes on the server. [11:24:16] Found default store. [11:24:16] Opened Exchange Server Store. [11:24:16] Entered Routine: (CMapiSession::GetMailboxesOnServerFromPrivateIS) [11:24:16] GetMailboxesOnServerFromPrivateIS: QueryInterface succeeded [11:24:16] GetMailboxesOnServerFromPrivateIS: GetMailboxTable succeeded [11:24:16] Number of mailbox records read: 47. (CMapiSession::GetMailboxesOnServerFromPrivateIS) [11:24:16] Ending Routine: (CMapiSession::GetMailboxesOnServerFromPrivateIS) [11:24:16] Finished getting list of mailboxes. [11:24:16] Ending Routine: (CMapiSession::GetMailboxesOnServer) [11:24:16] Session logoff successful. [11:24:16] Entered Routine: (CMapiSession::DeleteOurProfile) [11:24:16] Ending Routine: (CMapiSession::DeleteOurProfile) [11:24:16] Time to get mailbox data: 1 seconds [11:24:21] Using attribute 'PR_MESSAGE_DELIVERY_TIME' for date operations. [11:24:21] Merging data into target store. The program will copy only those messages that do not exist in the target store. [11:24:21] Associated folder data will NOT be copied to the target store. [11:24:21] Using 'German' (0x407) as the default locale (Code page 1252) [11:24:21] All mailboxes will be processed, regardless of locale [11:24:21] Using default locale for all mailboxes [11:24:21] Program will use 1 worker threads [11:24:21] Initializing worker thread (Thread0) [11:24:21] ((Thread0)) Before CopyMailboxData -A_NOACK [11:24:21] Entered Routine: EDKRoutines::CopyMailBoxData) [11:24:21] Using locale 'German' (0x407) and code page 1252 to connect to mailbox [11:24:21] Merging data from file '\\SERVER-FS\BACKUP_EXCHANGE_070725\A_NOACK.PST' to mailbox 'Noack Andreas' ('A_NOACK') on server 'SERVER-EX'. [11:24:21] DN of object is '/O=MyExchange/OU=ERSTE ADMINISTRATIVE GRUPPE/CN=RECIPIENTS/CN=A_NOACK'. [11:24:21] Entered Routine: (CMapiSession::MapiInit) [11:24:21] Successfully initialized MAPI. [11:24:21] Ending Routine: (CMapiSession::MapiInit) [11:24:21] Entered Routine: (CMapiSession::CreateEMSPSTProfile) [11:24:21] Ending Routine: (CMapiSession::CreateEMSPSTProfile) [11:24:21] Successfully created profile. [11:24:21] Entered Routine: (CMapiSession::Logon) [11:24:21] Entered Routine: (CMapiSession::MapiInit) [11:24:21] Successfully initialized MAPI. Zitieren Link zu diesem Kommentar
a_hempelt 10 Geschrieben 27. Juli 2007 Autor Melden Teilen Geschrieben 27. Juli 2007 [11:24:21] Ending Routine: (CMapiSession::MapiInit) [11:24:21] MAPI Logon successful. [11:24:21] Ending Routine: (CMapiSession::Logon) [11:24:21] Entered Routine: (CMapiSession::GetSession) [11:24:21] Ending Routine: (CMapiSession::GetSession) [11:24:21] Entered Routine: EDKRoutines::OpenStores) [11:24:21] OpenStores: Start [11:24:21] GetMsgStoresTable successful. [11:24:21] Checking service 'Microsoft Exchange-Nachrichtenspeicher' [11:24:21] Checking service 'Persnliche Ordner' [11:24:21] Store 'MSPST MS' was not opened. [11:24:21] Ending Routine: EDKRoutines::OpenStores) [11:24:21] Errors encountered. Copy process aborted for mailbox 'Noack Andreas' ('A_NOACK'). [11:24:21] Entered Routine: (CMapiSession::DeleteOurProfile) [11:24:21] Ending Routine: (CMapiSession::DeleteOurProfile) [11:24:21] Session logoff successful. [11:24:21] Ending Routine: EDKRoutines::CopyMailBoxData) [11:24:21] ((Thread0)) CopyMailboxData Failed -A_NOACK [11:24:21] ((Thread0)) Incremented progress bar [11:24:21] Number of items copied from the source store for all mailboxes processed: 0 [11:24:21] Total number of folders processed in the source store: 0 [11:24:21] 0 mailboxes successfully processed. 1 mailboxes were not successfully processed. 0 non-fatal errors encountered. [11:24:21] Process completion time: 00:00:00 [11:24:21] MAPI uninitialized. [11:24:25] MAPI uninitialized. Zitieren Link zu diesem Kommentar
Christoph35 10 Geschrieben 27. Juli 2007 Melden Teilen Geschrieben 27. Juli 2007 Am besten postest Du nur Differenzen zum vorherigen Log. Diese Fülle an Info reicht einmal. Oder Du machst Anhänge... Ausserdem hast du immer noch den Eintrag mit "Store MSPST MS was not opened" drin... Christoph Zitieren Link zu diesem Kommentar
