Verzeichnisberechtigung über ADS verteilen
Hallo Rockhound,
wenn's dir direkt per GPO ausreicht, ist das natürlich die einfachere Methode. Trotzdem der Vollständigkeit halber ein Beispielcode von MS in VB, um ACEs zu setzen
Dim x as IADs
Dim sd as IADsSecurityDescriptor
Dim Ace1 As new IADsAccessControlEntry
Dim Ace2 As new IADsAccessControlEntry
Dim Dacl As new IADsAccessControlList
On Error GoTo Cleanup
Set x = GetObject("LDAP://OU=Sales,DC=Fabrikam,DC=com")
Set sd = x.Get("ntSecurityDescriptor")
' Add the ACEs to the Disretionary ACL.
Dacl.AclRevision = ADS_SD_REVISION_DS 'DS ACL Revision
' Set up the first ACE.
Ace1.AccessMask = -1 'Full Permission (Allowed)
Ace1.AceType = ADS_ACETYPE_ACCESS_ALLOWED
Ace1.AceFlags = ADS_ACEFLAG_INHERIT_ACE
Ace1.Trustee = "myMachine\Administrator"
' Set up the 2nd ACE.
Ace2.AccessMask = -1 'Full Permission (Denied)
Ace2.AceType = ADS_ACETYPE_ACCESS_DENIED
Ace2.AceFlags = ADS_ACEFLAG_INHERIT_ACE
Ace2.Trustee = "aDomain\aUser"
Dacl.AddAce Ace1
Dacl.AddAce Ace2
'Commit the changes.
sd.DiscretionaryAcl = Dacl
x.Put "ntSecurityDescriptor", Array(sd)
x.SetInfo
Cleanup:
If (Err.Number<>0) Then
MsgBox("An error has occurred. " & Err.Number)
End If
Set Ace1 = Nothing
Set Ace2 = Nothing
Set Dacl = Nothing
Set x = Nothing
Set sd = Nothing
  • 1 Jahr später...
