MYOEY 10 Geschrieben 26. August 2007 Melden Geschrieben 26. August 2007 Moin Moin, Kann man mit der folgenden Meldung eines Cisco Catalyst4006 Switches was anfangen: Aug 26 11:01:36: %C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: (Suppressed 7 times)Unable to determine whether to route or bridge replicated software-processed packet with source address 00:E0:81:41:24:0A and destination address 00:00:0C:07:AC:01 Was bedeutet das eigentlich? Danke im voraus! Gruß Zitieren
hforster 10 Geschrieben 27. August 2007 Melden Geschrieben 27. August 2007 Hi Vieleicht hilft dir die erkärung vom Cisco IOS System Messages Guide weiter Error Message C4K_PKTPROCESSING-4-UNKNOWNBRIDGEORROUTE: Unable to determine whether to route or bridge replicated software-processed packet with source address [mac-addr] and destination address [mac-addr] Explanation When a replicated packet is sent to the software by an output ACL, the hardware does not indicate whether the packet needs to be bridged or routed. When resources are exhausted or when the ACLs programmed in the hardware cannot handle processing directly (such as ACLs matching TCP flags), the Supervisor Engine III sends the packets to software for processing. If the software cannot determine whether to bridge or route, the packet might be dropped. This drop indicates that the packet was directed to a Hot Standby Routing Protocol (HSRP) router group MAC address. nice day Zitieren
