WSUS 3 Computer werden nicht angezeigt
Hallo, ich habe bereits gesucht aber keine Lösung hat geholfen. Bei meinem WSUS 3.0 werden keine Computer gefunden. Anbei das Log:
2007-08-28 19:12:42:640 1112 b4 Misc =========== Logging initialized (build: 7.0.6000.374, tz: +0200) ===========
2007-08-28 19:12:42:703 1112 b4 Misc = Process: C:\WINDOWS\System32\svchost.exe
2007-08-28 19:12:42:703 1112 b4 Misc = Module: C:\WINDOWS\system32\wuaueng.dll
2007-08-28 19:12:42:640 1112 b4 Service *************
2007-08-28 19:12:42:703 1112 b4 Service ** START ** Service: Service startup
2007-08-28 19:12:42:703 1112 b4 Service *********
2007-08-28 19:12:42:718 1112 b4 Agent * WU client version 7.0.6000.374
2007-08-28 19:12:42:718 1112 b4 Agent * Base directory: C:\WINDOWS\SoftwareDistribution
2007-08-28 19:12:42:718 1112 b4 Agent * Access type: No proxy
2007-08-28 19:12:42:718 1112 b4 Agent * Network state: Connected
2007-08-28 19:13:41:925 1112 b4 Agent *********** Agent: Initializing Windows Update Agent ***********
2007-08-28 19:13:41:925 1112 b4 Agent *********** Agent: Initializing global settings cache ***********
2007-08-28 19:13:41:925 1112 b4 Agent * WSUS server: http://wsrv2003:8530'>http://wsrv2003:8530'>http://wsrv2003:8530
2007-08-28 19:13:41:925 1112 b4 Agent * WSUS status server: http://wsrv2003:8530
2007-08-28 19:13:41:925 1112 b4 Agent * Target group: http://wsrv2003:8530
2007-08-28 19:13:41:925 1112 b4 Agent * Windows Update access disabled: No
2007-08-28 19:13:41:925 1112 b4 DnldMgr Download manager restoring 0 downloads
2007-08-28 19:13:41:972 1112 b4 DnldMgr Retrieved 2 persisted download jobs
2007-08-28 19:13:41:972 1112 b4 DnldMgr *********** DnldMgr: Restoring download [no. 0] ***********
2007-08-28 19:13:42:003 1112 b4 DnldMgr * BITS JobId = {E977C23D-B2E0-4C40-B811-33B9F007D84A}
2007-08-28 19:13:42:003 1112 b4 DnldMgr * ServiceId = {9482F4B4-E343-43B6-B170-9A65BC822C77}
2007-08-28 19:13:42:269 1112 b4 DnldMgr * UpdateId = {F2FCA9BF-05AD-460A-977C-355CE5734118}.102
2007-08-28 19:13:45:297 1112 b4 DnldMgr * Restored download job.
2007-08-28 19:13:45:297 1112 b4 DnldMgr *********** DnldMgr: Restoring download [no. 1] ***********
2007-08-28 19:13:45:297 1112 b4 DnldMgr * BITS JobId = {8411DB63-71C6-4A3E-A1D2-6ADA87E581D1}
2007-08-28 19:13:45:297 1112 b4 DnldMgr * ServiceId = {9482F4B4-E343-43B6-B170-9A65BC822C77}
2007-08-28 19:13:45:406 1112 b4 DnldMgr * UpdateId = {B4F59888-6F3A-40D0-811E-614AA3C93F45}.101
2007-08-28 19:13:45:765 1112 b4 DnldMgr * Restored download job.
2007-08-28 19:13:45:780 1112 b4 AU ########### AU: Initializing Automatic Updates ###########
2007-08-28 19:13:45:812 1112 b4 AU # WSUS server: http://wsrv2003:8530'>http://wsrv2003:8530
2007-08-28 19:13:45:812 1112 b4 AU # Detection frequency: 22
2007-08-28 19:13:45:812 1112 b4 AU # Target group: http://wsrv2003:8530
2007-08-28 19:13:45:812 1112 b4 AU # Approval type: Scheduled (Policy)
2007-08-28 19:13:45:812 1112 b4 AU # Scheduled install day/time: Every day at 12:00
2007-08-28 19:13:45:812 1112 b4 AU # Auto-install minor updates: Yes (Policy)
2007-08-28 19:13:45:843 1112 b4 AU Setting AU scheduled install time to 2007-08-29 10:00:00
2007-08-28 19:13:45:843 1112 b4 AU AU finished delayed initialization
2007-08-28 19:13:45:843 1112 b4 Report *********** Report: Initializing static reporting data ***********
2007-08-28 19:13:45:843 1112 b4 Report * OS Version = 5.1.2600.2.0.65792
2007-08-28 19:13:45:874 1112 b4 Report * Computer Brand = System manufacturer
2007-08-28 19:13:45:874 1112 b4 Report * Computer Model = System Product Name
2007-08-28 19:13:45:905 1112 b4 Report * Bios Revision = 1102
2007-08-28 19:13:45:905 1112 b4 Report * Bios Name = BIOS Date: 01/30/07 15:09:48 Ver: 08.00.12
2007-08-28 19:13:45:905 1112 b4 Report * Bios Release Date = 2007-01-30T00:00:00
2007-08-28 19:13:45:905 1112 b4 Report * Locale ID = 1031
2007-08-28 19:13:51:602 1112 ec0 PT WARNING: Cached cookie has expired or new PID is available
2007-08-28 19:13:51:789 1112 ec0 PT Initializing simple targeting cookie, clientId = 58b3d49c-6de1-45f2-8e4c-ca2a7c136b0d, target group = http://wsrv2003:8530, DNS name = drboe10.drboe.local
2007-08-28 19:13:51:789 1112 ec0 PT Server URL = http://wsrv2003:8530/SimpleAuthWebService/SimpleAuth.asmx
2007-08-28 19:14:03:058 1112 ec0 PT WARNING: GetAuthorizationCookie failure, error = 0x8024400E, soap client error = 7, soap error code = 400, HTTP status code = 200
2007-08-28 19:14:03:058 1112 ec0 PT WARNING: SOAP Fault: 0x000190
2007-08-28 19:14:03:058 1112 ec0 PT WARNING: faultstring:Fault occurred
2007-08-28 19:14:03:058 1112 ec0 PT WARNING: ErrorCode:InternalServerError(5)
2007-08-28 19:14:03:058 1112 ec0 PT WARNING: Message:(null)
2007-08-28 19:14:03:058 1112 ec0 PT WARNING: Method:"http://www.microsoft.com/SoftwareDistribution/Server/SimpleAuthWebService/GetAuthorizationCookie"
2007-08-28 19:14:03:058 1112 ec0 PT WARNING: ID:57f31d9a-be02-4582-93ae-f6112f24a9ce
Kann mir jemand weiterhelfen ?
Vorab schon mal vielen Dank Jörn
@Joern
Besser wäre es gewesen du das WsusClientDiag Tool heruntergeladen hättest und das an einem Client ausgeführt hättest ! Wie sollen bei dir die Client zum Wsus kommen ?
--- GPO
--- Lokale Richtlinie
--- Regkey
Mehr Info findest du hierWSUSPraxis.de und hier WSUS Blog !
Auch findest du unter Downloads das WsusClientDiagTool. Das Ergebnis kannst du dann hier posten. Und dann kann ich dir bestimmt helfen.
Und in der Boardsuche hättest du bestimmt etwas dazu gefunden ! Aber gut bis nachher..........
War heute erst wieder im Büro. Anbei die Einstellungen der GPO:
Einstellung Status
Option "Updates installieren und herunterfahren" im Dialogfeld "Windows herunterfahren" nicht anzeigen Nicht konfiguriert
Die Standardoption "Updates installieren und herunterfahren" im Dialogfeld "Windows herunterfahren" nicht anpassen Nicht konfiguriert
Automatische Updates konfigurieren Aktiviert
Internen Pfad für den Microsoft Updatedienst angeben Aktiviert
Clientseitige Zielzuordnung aktivieren Aktiviert
Zeitplan für geplante Installationen neu erstellen Nicht konfiguriert
Keinen automatischen Neustart für geplante Installationen durchführen Aktiviert
Suchhäufigkeit für automatische Updates Aktiviert
Automatische Updates sofort installieren Aktiviert
Neustart für geplante Installationen verzögern Nicht konfiguriert
Erneut zu einem Neustart für geplante Installationen auffordern Nicht konfiguriert
Nicht-Administratoren gestatten, Updatebenachrichtigungen zu erhalten Nicht konfiguriert
Empfohlene Updates über "Automatische Updates" aktivieren Nicht konfiguriert
Aktivieren des Windows Update-Energieverwaltungsfeatures zum automatischen Einschalten des Systems zur Installation von geplanten Updates Nicht konfiguriert
Signierten Inhalte aus internem Speicherort für Microsoft-Updatedienste zulassen Nicht konfiguriert
Gruß Jörn
Äh ja, war auch mein Fehler.
Automatische Updates konfigurieren: 4 täglich 12:00
Internen Pfad für den Microsoft Updatedienst angeben http://wsrv2003:8530'>http://wsrv2003:8530'>http://wsrv2003:8530 und http://wsrv2003:8530
Clientseitige Zielzuordnung aktivieren http://wsrv2003:8530
Keinen automatischen Neustart für geplante Installationen durchführen aktiviert
Suchhäufigkeit für automatische Updates Aktiviert 22
Gruß Jörn
