plvoy 10 Geschrieben 29. August 2007 Melden Geschrieben 29. August 2007 Servus, ich versuche zur Zeit eine PIX 501 zu konfigurieren. Die Einwahl ins DSL mit pppoe klappt, ich kann übers CLI externe hosts anpingen. Ich bekomme aber keine Verbindung vom Client zum Internet. Die PIX scheint alles zu blocken und ich weiss nicht genau warum. Anbei die conf Building configuration... : Saved : PIX Version 6.3(5) interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password ###### encrypted passwd ########## encrypted hostname ##### domain-name ###### fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names name 192.168.1.10 #### name 192.168.1.4 #### access-list inside_access_in permit ip 192.168.1.0 255.255.255.0 any access-list inside_outbound_nat0_acl permit ip any 192.168.1.64 255.255.255.192 access-list outside_cryptomap_dyn_20 permit ip any 192.168.1.64 255.255.255.192 pager lines 24 logging on icmp permit any outside icmp permit any inside mtu outside 1500 mtu inside 1500 ip address outside pppoe setroute ip address inside 192.168.1.30 255.255.255.0 ip audit info action alarm ip audit attack action alarm ip local pool ####### 192.168.1.90-192.168.1.99 pdm location ###### 255.255.255.255 inside pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 10 interface nat (inside) 0 access-list inside_outbound_nat0_acl nat (inside) 10 0.0.0.0 0.0.0.0 0 0 access-group inside_access_in in interface inside timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout sip-disconnect 0:02:00 sip-invite 0:03:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local ntp server #### source inside http server enable http #### 255.255.255.255 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable sysopt connection permit-ipsec crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20 crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5 crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map crypto map outside_map interface outside isakmp enable outside isakmp policy 20 authentication pre-share isakmp policy 20 encryption 3des isakmp policy 20 hash md5 isakmp policy 20 group 2 isakmp policy 20 lifetime 86400 vpngroup #### address-pool ##### vpngroup #### dns-server 192.168.1.2 vpngroup #### default-domain ################## vpngroup #### idle-time 1800 vpngroup #### password ******** telnet timeout 5 ssh timeout 5 console timeout 0 vpdn group pppoe_group request dialout pppoe vpdn group pppoe_group localname ############### vpdn group pppoe_group ppp authentication chap vpdn username ############# password ********* username #### password ############## encrypted privilege 15 terminal width 80 Cryptochecksum:c6a80e79aabe121f81657bb0d8ff7be3 : end [OK] besten dank schon mal im vorraus :) Zitieren
hegl 10 Geschrieben 30. August 2007 Melden Geschrieben 30. August 2007 Schon mal an den echo-reply gedacht, der zurückgeschickt wird? Du läst zwar durch ..ip any... icmp-Pakete raus, aber für den ech-reply hast du weder eine ACL noch die dazugehörende access-group. Während bei z.B. http die PIX die Rückantwort automatisch zulässt, musst Du beim ping dies explizit freischalten! Zitieren
plvoy 10 Geschrieben 30. August 2007 Autor Melden Geschrieben 30. August 2007 Es klappen nicht nur die Pings nicht, auch http/https nach aussen klappt nicht... Zitieren
hegl 10 Geschrieben 30. August 2007 Melden Geschrieben 30. August 2007 Hmm, auf den ersten Blick sehe ich auch nichts. Was sagt denn das logging? Zitieren
Wordo 11 Geschrieben 30. August 2007 Melden Geschrieben 30. August 2007 Namensaufloesung? Default-GW der Clients richtig? Zitieren
plvoy 10 Geschrieben 30. August 2007 Autor Melden Geschrieben 30. August 2007 okay problem 1 ist erlegt... ist ja fast schon peinlich.. ich habe beim testen vergessen dem DNS Server das neue Gateway auch zu geben ^^... okay nun hänge ich aber noch am port forwarding fest.. die ACLs, die ich finde z.b. access-list In_Outside permit tcp any host 1.2.3.4 eq 80 access-group In_Outside in interface outside klappen nicht und wenn ich im PDM eine ACL hinzufügen will mit source any dest 192.168.1.4 http möchte er immer eine statische nat hinzufügen, aber die kann ich doch wegen dem PPPOE und dyn IP nicht angeben oder? Zitieren
