mmeglitsch 10 Geschrieben 4. September 2007 Melden Geschrieben 4. September 2007 Der DC Server der Hauptdomäne (Spacegate) wurde entfernt und auf einen anderen Server verlagert. Die Replikationspartner in den Subdomains haben davon nichts mitbekommen. Die DCs in den Subdomains versuchen immer noch den SPACEGATE (alten DC) zu finden. Wie kann ich der Subdomain beibringen, dass sie mit einem neuen DC replizieren soll. DCDiag.exe bringt folgendes: Doing primary tests Testing server: Sto-KTS-Villach\SVR-202479 Starting test: Replications [Replications Check,SVR-202479] A recent replication attempt failed: From SPACEGATE to SVR-202479 Naming Context: DC=ForestDnsZones,DC=xxx,DC=xx,DC=at The replication generated an error (1256): Der Remotecomputer ist nicht verfgbar. Weitere Informationen zur Behebung von Netzwerkproblemen finden Sie in der Windows-Hilfe. The failure occurred at 2007-09-04 10:48:59. The last success occurred at 2007-05-18 06:48:51. 655 failures have occurred since the last success. [Replications Check,SVR-202479] A recent replication attempt failed: From SPACEGATE to SVR-202479 Naming Context: CN=Schema,CN=Configuration,DC=xxxx,DC=xx,DC=at The replication generated an error (1396): Anmeldung fehlgeschlagen: Der Zielkontoname ist ungltig. The failure occurred at 2007-09-04 10:48:59. The last success occurred at 2007-05-18 06:48:51. 655 failures have occurred since the last success. Kerberos Error. The KDC could not find the SPN for the server SPACEGATE. This can be for several reasons: (1) - The SPN is not registered on the KDC (usually SVR-202479). Check that the SPN is registered on at least one other server besides SPACEGATE, and that replication is progressing between this server and the KDC. The tool repadmin/syncall can be used for this purpose. (2) - This server could be a deleted server (and deleted DSA object), and this deletion has not replicated across the enterprise yet. This will rectify itself within the general replication latency plus the latency of the KCC. Should be less than a day. (3) - It's possible that this server was reclaimed, but it's DSA object was not deleted and an old DNS record representing the server is present. This can result in this error for the duration of a DNS record lease. Often about 2 weeks. To fix this, please clean up the DSA's metadata with ntdsutil. (4) - Finally, it's possible that this server has acquired a new IP address, the server's old IP address has been reused, and DNS hasn't been updated to reflect the new IP address. If this problem persists, stop and restart the "Net Logon" service on SPACEGATE, and delete the old DNS record. [Replications Check,SVR-202479] A recent replication attempt failed: From SPACEGATE to SVR-202479 Naming Context: CN=Configuration,DC=xxxx,DC=xx,DC=at The replication generated an error (1396): Anmeldung fehlgeschlagen: Der Zielkontoname ist ungltig. The failure occurred at 2007-09-04 10:48:59. The last success occurred at 2007-05-18 06:48:51. 655 failures have occurred since the last success. Kerberos Error. The KDC could not find the SPN for the server SPACEGATE. This can be for several reasons:
carlito 10 Geschrieben 4. September 2007 Melden Geschrieben 4. September 2007 FSMO Rollen übertragen? netdiag /test:dns /debug ausgeführt? repadmin /syncall /force probiert?
