Dsl - 1841
Servus Leute,
zur Zeit bekomme ich einen Cisco 1841 mit DSL nicht zum Laufen (mit Dyn. Cryptomap). Soll per pppoe über ein Modem ins Internet. Vielleicht findet Ihr den Fehler warum DSL nicht geht.
Hier die Config:
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
hostname VPN_DSL
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 XXXXXXXXXXXXXXXXXXXXXXX
no aaa new-model
resource policy
memory-size iomem 20
no ip source-route
ip cef
no ip domain lookup
ip domain name yourdomain.com
ip multicast-routing
vpdn enable
username XXXXXX privilege 15 secret 5 XXXXX
crypto isakmp policy 10
authentication pre-share
group 2
crypto isakmp key XXXXXX address 22.25.15.121
crypto ipsec transform-set tfs2 esp-3des
mode transport
crypto map statmap local-address Dialer1
crypto map statmap 10 ipsec-isakmp
set peer 22.25.15.121 default
set transform-set tfs2
match address 177
bba-group pppoe global
virtual-template 1
interface Tunnel30
ip address 10.10.10.29 255.255.255.252
ip pim dense-mode
tunnel source Loopback1
tunnel destination 172.38.131.1
interface Loopback1
ip address 10.0.0.1 255.255.255.252
interface FastEthernet0/0
description to the Internet (DSL Router)
no ip address
no ip redirects
no ip unreachables
ip pim sparse-dense-mode
no ip route-cache cef
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no keepalive
no cdp enable
interface FastEthernet0/1
no ip address
no ip redirects
no ip unreachables
no ip route-cache
no ip mroute-cache
shutdown
duplex auto
speed auto
no keepalive
no cdp enable
interface FastEthernet0/0/0
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Vlan1
description to the Playout PC
ip address 192.20.172.1 255.255.255.248
ip pim dense-mode
interface Dialer1
ip address negotiated
ip mtu 1492
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer remote-name unknown
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname xxxloginname
ppp chap password 7 xxgeheimxx
ppp pap sent-username xxxloginname password 7 xxgeheimxx
crypto map statmap
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 192.168.150.0 255.255.255.0 10.10.10.30
ip route 192.168.100.0 255.255.255.0 10.10.10.30
no ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip pim rp-address 172.38.131.1
access-list 177 remark Gre-Tunnel Traffic
access-list 177 permit gre host 10.0.0.1 host 172.38.131.1
end
Danke, theMatrix
dialer-list permit blabla fehlt.
Dann ist auch der dialer pool im dialer IF unnoetig.
Ausserdem wuerde ich noch ein int vlan 2 machen, darauf die pppoe-client dialer-pool blabla
setzen und dann die physikalischen switchports in vlan 2 legen.
So mach ichs, und so funktionierts bei mir :D
