Problem mit ISDN Remote Einwahl
Servus zusammen,
ich habe seit etlicher Zeit keine ISDN Remote Einwahl mehr konfiguriert und kann mich mit der folgenden Config nicht einwählen. Ggf. hat einer von Euch eine Idee.
interface BRI0
no ip address
encapsulation ppp
isdn switch-type basic-net3
isdn point-to-point-setup
isdn caller xxx
isdn answer1 xxx
isdn calling-number xxx
interface Dialer2
description "ISDN-Remoteeinwahl"
ip address 192.168.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly
encapsulation ppp
dialer pool 2
dialer remote-name xxx
dialer idle-timeout 180
dialer-group 1
peer default ip address dhcp-pool ISDN-Remoteeinwahl
no cdp enable
ppp authentication chap callin
ppp multilink
dialer-list 1 protocol ip permit
So und hier der Debug.
Nov 10 2007 03:48:21.491 CET: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 78 changed to down
Nov 10 2007 03:48:21.499 CET: ISDN BR0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Nov 10 2007 03:48:41.674 CET: ISDN BR0 Q931: RX <- SETUP pd = 8 callref = 0x39
Sending Complete
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Calling Party Number i = 0x2181, 'xxx'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, 'xxx'
Plan:ISDN, Type:Subscriber(local)
Nov 10 2007 03:48:41.682 CET: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0xEA calltype 1 HOST_INCOMING_CALL
Nov 10 2007 03:48:41.682 CET: ISDN BR0 EVENT: host_incoming_call: call_id 0x00EA, Guid = 0000023D81CB bchan 0
Nov 10 2007 03:48:41.690 CET: ISDN BR0 **ERROR**: host_incoming_call: Rejecting call. isdn screening failed
Nov 10 2007 03:48:41.694 CET: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0xEA calltype 1 HOST_DISCONNECT_ACK
Nov 10 2007 03:48:41.706 CET: ISDN BR0 Q931: RX <- SETUP pd = 8 callref = 0x26
Sending Complete
Standard = CCITT
Channel ID i = 0x8A
Nov 10 2007 03:48:41.718 CET: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0xEB calltype 1 HOST_INCOMING_CALL
Nov 10 2007 03:48:41.718 CET: ISDN BR0 EVENT: host_incoming_call: call_id 0x00EB, Guid = 0000023D81CB bchan 1
Nov 10 2007 03:48:41.726 CET: ISDN BR0 **ERROR**: host_incoming_call: Rejecting call. isdn screening failed
Nov 10 2007 03:48:41.730 CET: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0xEB calltype 1 HOST_DISCONNECT_ACK
Nov 10 2007 03:48:42.726 CET: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 78 changed to up
Nov 10 2007 03:48:42.730 CET: ISDN BR0 **ERROR**: L3_Go: Multi nlcb DL_EST, cid 0xEB cr 0xA6 ev 0x300 ces 1
Nov 10 2007 03:48:42.734 CET: ISDN BR0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xB9
Cause i = 0x8095 - Call rejected
Nov 10 2007 03:48:42.762 CET: ISDN BR0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xA6
