sebastian.f 10 Geschrieben 16. November 2007 Melden Geschrieben 16. November 2007 Hallo mir ist gestern ein Cisco 3020 BladeSwitch gecrashed und hat leider einige ESX Server mitgerissen was zu einem Failover führte... In den Logs des Switches war das zu finden: .Nov 13 07:44:35: %PLATFORM-1-CRASHED: System previously crashed with the following message: .Nov 13 07:44:35: %PLATFORM-1-CRASHED: Cisco IOS Software, CBS30X0 Software (CBS30X0-LANBASE-M), Version 12.2(25)SEF1 , RELEASE SOFTWARE (fc3) .Nov 13 07:44:35: %PLATFORM-1-CRASHED: Copyright (c) 1986-2006 by Cisco Systems, Inc. .Nov 13 07:44:35: %PLATFORM-1-CRASHED: Compiled Tue 23-May-06 15:26 by antonino .Nov 13 07:44:35: %PLATFORM-1-CRASHED: .Nov 13 07:44:35: %PLATFORM-1-CRASHED: Program Exception (0x0700)! .Nov 13 07:44:35: %PLATFORM-1-CRASHED: .Nov 13 07:44:35: %PLATFORM-1-CRASHED: SRR0 = 0x00A1AA40 SRR1 = 0x00029210 SRR2 = 0x00451BDC SRR3 = 0x00021200 .Nov 13 07:44:35: %PLATFORM-1-CRASHED: ESR = 0x08000000 DEAR = 0x00000000 TSR = 0x8C000000 DBSR = 0x00000000 .Nov 13 07:44:35: %PLATFORM-1-CRASHED: .Nov 13 07:44:35: %PLATFORM-1-CRASHED: CPU Register Context: .Nov 13 07:44:35: %PLATFORM-1-CRASHED: Vector = 0x00000700 PC = 0x00A1AA40 MSR = 0x00029210 CR = 0x35555039 .Nov 13 07:44:35: %PLATFORM-1-CRASHED: LR = 0x00A4FC90 CTR = 0x004B95EC XER = 0xC0000004 .Nov 13 07:44:35: %PLATFORM-1-CRASHED: R0 = 0x00A4FC90 R1 = 0x015A9D88 R2 = 0x00000000 R3 = 0x00000000 .Nov 13 07:44:35: %PLATFORM-1-CRASHED: R4 = 0x019B6540 R5 = 0x00000000 R6 = 0x00029210 R7 = 0x00000006 .Nov 13 07:44:35: %PLATFORM-1-CRASHED: R8 = 0x00029210 R9 = 0xFFFFFFFF R10 = 0x01220000 R11 = 0x00F60000 .Nov 13 07:44:35: %PLATFORM-1-CRASHED: R12 = 0x55555039 R13 = 0x00110000 R14 = 0x015A9DA8 R15 = 0x00E90000 .Nov 13 07:44:35: %PLATFORM-1-CRASHED: R16 = 0x00EA0000 R17 = 0x00E90000 R18 = 0x00000000 R19 = 0x00000000 .Nov 13 07:44:35: %PLATFORM-1-CRASHED: R20 = 0x00000000 R21 = 0x01340000 R22 = 0x00000000 R23 = 0x01220000 .Nov 13 07:44:35: %PLATFORM-1-CRASHED: R24 = 0x00000000 R25 = 0x01220000 R26 = 0x00000000 R27 = 0x01220000 .Nov 13 07:44:35: %PLATFORM-1-CRASHED: R28 = 0x00000001 R29 = 0x01702850 R30 = 0x00000000 R31 = 0x01702720 .Nov 13 07:44:35: %PLATFORM-1-CRASHED: .Nov 13 07:44:35: %PLATFORM-1-CRASHED: Stack trace: .Nov 13 07:44:35: %PLATFORM-1-CRASHED: PC = 0x00A1AA40, SP = 0x015A9D88 .Nov 13 07:44:35: %PLATFORM-1-CRASHED: Frame 00: SP = 0x015A9DA0 PC = 0x00A4FC90 .Nov 13 07:44:35: %PLATFORM-1-CRASHED: Frame 01: SP = 0x015A9F20 PC = 0x00A84238 .Nov 13 07:44:35: %PLATFORM-1-CRASHED: Frame 02: SP = 0xFFFFFFFF PC = 0x00A7EF8C .Nov 13 07:44:35: %PLATFORM-1-CRASHED: Kann dammit jemand was anfangen? Deutet das auf einen HW defekt hin ? Dann würde ich das Gerät nämlich tauschen lassen. Danke Sebastian Zitieren
Otaku19 33 Geschrieben 23. November 2007 Melden Geschrieben 23. November 2007 Der Output interpreter sagt: Recommended Action: Use the exception crashinfo command to enable 'core dump' on the switch that crashed. The core dump file will be able to a capture a more detailed crash and have enough information to determine a root cause. Consider an IOS upgrade. Zitieren
sebastian.f 10 Geschrieben 24. November 2007 Autor Melden Geschrieben 24. November 2007 Danke für die Antwort, werde das so machen, hab allerdings schon den Garantieaustausch durch unseren Cisco Partner in Auftrag gegeben. Sicher ist Sicher :) Evtl. kommt dann das Gerät schon mit einem neuen IOS. Zitieren
