Replikation zwischen zwei DCs schlägt fehl
Halo alle zusammen,
ich weiß es ist schon Freitag, aber vielleicht kann mir ja noch jemand helfen. Wir haben bei uns zwei DC. Seit einiger Zeit erhalte ich im Log Fehlermeldungen das die Replikation fehlschlägt. Auf DC1 habe ich mal dcdiag gestartet was mir folgendes ausgibt.
Performing initial setup:
Done gathering initial info.
Doing initial required tests
Testing server: Standardname-des-ersten-Standorts\SVR10000-01
Starting test: Connectivity
......................... SVR10000-01 passed test Connectivity
Doing primary tests
Starting test: Replications
[Replications Check,SVR10000-01] A recent replication attempt failed:
From SVR10000-02 to SVR10000-01
Naming Context: DC=DOM10000,DC=local
The replication generated an error (8456):
Der Quellserver nimmt zurzeit keine Replikationsanforderungen entgegen.
The failure occurred at 2007-12-07 13:54.54.
The last success occurred at 2007-10-17 11:55.57.
1489 failures have occurred since the last success.
Replication has been explicitly disabled through the server options.
Naming Context: CN=Configuration,DC=DOM10000,DC=local
The last success occurred at 2007-10-17 11:58.00.
2797 failures have occurred since the last success.
REPLICATION LATENCY WARNING
ERROR: Expected notification link is missing.
Source SVR10000-02
Replication of new changes along this path will be delayed.
This problem should self-correct on the next periodic sync.
Naming Context: CN=Schema,CN=Configuration,DC=DOM10000,DC=local
The last success occurred at 2007-10-17 08:46.03.
1231 failures have occurred since the last success.
Und hier der Rest. Es hatt nicht alles in einen Beitrag gepasst.
......................... SVR10000-01 passed test Replications
Starting test: NCSecDesc
......................... SVR10000-01 passed test NCSecDesc
Starting test: NetLogons
......................... SVR10000-01 passed test NetLogons
Starting test: Advertising
......................... SVR10000-01 passed test Advertising
Starting test: KnowsOfRoleHolders
......................... SVR10000-01 passed test KnowsOfRoleHolders
Starting test: RidManager
......................... SVR10000-01 passed test RidManager
Starting test: MachineAccount
......................... SVR10000-01 passed test MachineAccount
Starting test: Services
TrkWks Service is stopped on [sVR10000-01]
TrkSvr Service is stopped on [sVR10000-01]
......................... SVR10000-01 failed test Services
Starting test: ObjectsReplicated
......................... SVR10000-01 passed test ObjectsReplicated
Starting test: frssysvol
There are errors after the SYSVOL has been shared.
The SYSVOL can prevent the AD from starting.
......................... SVR10000-01 passed test frssysvol
Starting test: kccevent
......................... SVR10000-01 passed test kccevent
Starting test: systemlog
......................... SVR10000-01 passed test systemlog
Running enterprise tests on : DOM10000.local
Starting test: Intersite
......................... DOM10000.local passed test Intersite
Starting test: FsmoCheck
......................... DOM10000.local passed test FsmoCheck
Bis auf Windowsupdates habe ich auf den Servern nichts installiert. Der eine DC ist mal abgestürzt. Ich kann mir aber nicht so richtig vorstellen das es von da herkommt. Habt ihr eine Idee was ich noch tun kann?
Mfg Drillsergeant
  • 3 Monate später...
hallo,
Da ist vermutlich schon die TombstoneLifetime überschritten "The last success occurred at 2007-10-17 11:58.00",
Am besten entfernst du DC2 und installierst ihn neu. Such hier im Board nach "metadata cleanup"
Wenn das z.B. organisatorisch nicht geht, such mal bei microsoft nach
"Allow Replication With Divergent and Corrupt Partner"
und
"strict replication consistency"
Mit diesen RegKeys replizieren DCs, egal ob Fehler auftreten oder nicht.
Besser ist auf jeden Fall das Neuaufsetzen von DC2.
cu
blub
