NTDS Replication Issue
Hallo
Wir haben 2 Windows 2003 Domaincontroller im Einsatz. Eigentlich funktioniert auch alles wunderbar, nur hin- und wieder tauchen solche Fehlermeldungen in Folge auf. Manuelles Replizieren funktioniert problemlos!
Event Type: Warning
Event Source: NTDS Replication
Event Category: Replication
Event ID: 1083
Date: 14.12.2007
Time: 13:12:26
User: NT AUTHORITY\ANONYMOUS LOGON
Computer: DC3
Description:
Active Directory could not update the following object with changes received from the domain controller at the following network address because Active Directory was busy processing information.
Object:
CN=Administrator,CN=Users,DC=mydomain,DC=local
Network address:
f5d31278-13d1-405b-b533-3cae614e6754._msdcs.mydomain.local
This operation will be tried again later.
Event Type: Information
Event ID: 1955
Date: 14.12.2007
Time: 13:12:26
Computer: DC3
Description:
Active Directory encountered a write conflict when applying replicated changes to the following object.
Object:
Time in seconds:
0
Event log entries preceding this entry will indicate whether or not the update was accepted.
A write conflict can be caused by simultaneous changes to the same object or simultaneous changes to other objects that have attributes referencing this object. This commonly occurs when the object represents a large group with many members, and the functional level of the forest is set to Windows 2000. This conflict triggered additional retries of the update. If the system appears slow, it could be because replication of these changes is occurring.
User Action
Use smaller groups for this operation or raise the functional level to Windows Server 2003.
Den Output von dcdiag /v /c hab ich angefügt.
[EDIT]Hier der Link zum log general pastebin - Anonymous - post number 820316[edit]
Folgendes habe ich bereits versucht, leider ist der Fehler dadurch nicht verschwunden
  • betroffenes Objekt in eine andere OU verschoben
  • manuelle Replikation angestossen
  • Objekt wieder zurückgeschoben
Kann mir jemand sagen was hier los ist? Was hat es mit dieser dcdiag-Meldung auf sich?
Latency information for 7 entries in the vector were ignored.
dcdiag.txt
aus dem dcdiag log
Starting test: systemlog
* The System Event log test
An Error Event occured. EventID: 0xC0002719
Time Generated: 12/17/2007 14:04:41
(Event String could not be retrieved)
die dazugehörige Fehlermeldung im Eventlog
Event Type: Error
Event Source: DCOM
Event Category: None
Event ID: 10009
Date: 17.12.2007
Time: 14:05:23
User: N/A
Computer: DC3
Description:
DCOM was unable to communicate with the computer 217.8.192.52 using any of the configured protocols.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Bei dieser IP handelt es sich um den DNS Server unseres Providers
Okay, hab den Artikel nochmal durchgelesen. Leider scheinen die Lösungsvorschläge nur für Windows 2000 Server gültig zu sein. Bin die Punkte aber trotzdem mal für die W2k3 DCs durchgegangen
APPLIES TO
• Microsoft Windows 2000 Server
• Microsoft Windows 2000 Advanced Server
Auch konnte ich kein doppelt vorhandenes Objekt finden und wie schon gesagt, das verschieben in eine andere OU und wieder zurück hat nichts gebracht.
4. Use the Repadmin.exe tool (located in Windows 2000 Support Tools) to synchronize the configuration and domain naming contexts. Use the following syntax (replace the domain components with your own):
Ist das gleiche wie wenn ich unter "Active Directory Sites and Services" manuell eine Replikation anstosse, richtig?
