schmitty 10 Geschrieben 20. Mai 2008 Melden Geschrieben 20. Mai 2008 Hallo Zusammen, Kann mir einer Sagen warum meine offline Anmeldung so lange braucht? Ich weiß zwar wo es lt. Log hängt, aber nicht den Hintergrund. Bitte mal um Hilfe SERENV(658.898) 10:46:48:578 ProcessGPOs: Machine role is 2. USERENV(658.898) 10:46:48:578 ProcessGPOs: The DC for domain PAPE is not available. aborting USERENV(658.898) 10:46:48:578 ProcessGPOs: No WMI logging done in this policy cycle. USERENV(658.898) 10:46:48:578 ProcessGPOs: Processing failed with error 1355. USERENV(658.898) 10:46:48:578 LeaveCriticalPolicySection: Critical section 0x6f0 has been released. USERENV(658.898) 10:46:48:578 ProcessGPOs: User Group Policy has been applied. USERENV(658.898) 10:46:48:578 ProcessGPOs: Leaving with 0. USERENV(658.898) 10:46:48:578 ApplyGroupPolicy: Leaving successfully. USERENV(658.8ac) 10:46:48:656 GPOThread: Next refresh will happen in 99 minutes USERENV(658.65c) 10:46:48:656 IsSyncForegroundPolicyRefresh: Asynchronous, Reason: NoNeedForSync USERENV(9b0.9b4) 10:46:51:578 LibMain: Process Name: C:\WINDOWS\system32\wbem\wmiprvse.exe USERENV(a50.a54) 10:47:32:359 LibMain: Process Name: C:\WINDOWS\system32\wuauclt.exe USERENV(a9c.aa0) 10:47:40:937 LibMain: Process Name: C:\WINDOWS\SYSTEM32\userinit.exe USERENV(684.4a0) 10:48:10:203 LoadUserProfile: Yes, we can impersonate the user. Running as self USERENV(684.4a0) 10:48:10:203 ========================================================= USERENV(684.4a0) 10:48:10:203 LoadUserProfile: Entering, hToken = <0x10>, lpProfileInfo = 0xc9f69c USERENV(684.4a0) 10:48:10:203 LoadUserProfile: lpProfileInfo->dwFlags = <0x9> USERENV(684.4a0) 10:48:10:203 LoadUserProfile: lpProfileInfo->lpUserName = <LocalService> USERENV(658.be8) 10:45:46:484 UnloadUserProfileP: Leaving with a return value of 1 USERENV(658.be8) 10:45:46:484 UnloadUserProfileI: returning 0 USERENV(658.670) 10:45:46:484 IProfileSecurityCallBack: client authenticated. USERENV(658.670) 10:45:46:484 ReleaseClientContext: Releasing context USERENV(658.670) 10:45:46:484 ReleaseClientContext_s: Releasing context USERENV(658.670) 10:45:46:484 MIDL_user_free enter USERENV(658.65c) 10:46:36:734 InitializePolicyProcessing: Initialised Machine Mutex/Events USERENV(658.65c) 10:46:36:796 InitializePolicyProcessing: Initialised User Mutex/Events USERENV(658.65c) 10:46:36:796 LibMain: Process Name: \??\C:\WINDOWS\SYSTEM32\winlogon.exe USERENV(658.65c) 10:46:36:890 Entering CUserProfile::Initialize ... USERENV(658.65c) 10:46:36:890 CUserProfile::Initialize called by winlogon Zitieren
olc 18 Geschrieben 20. Mai 2008 Melden Geschrieben 20. Mai 2008 Hi schmitty, öhm - das ist jetzt nicht böse gemeint, aber was soll uns Dein Post jetzt sagen? Daß Du einen Delay von 1x ca. 40 Sekunden und einen von ca. 30 Sekunden hast, ist sichtbar. Daß es sich höchstwahrscheinlich um ein Windows XP System handelt könnten wir uns vielleicht auch noch gerade so aus den Daten herausziehen. Seit wann das Problem existiert, ob es tatsächlich nur im Offline-Betrieb auftritt, ob die Ereignisprotokolle Fehler auswerfen, ob Du schon einmal ein WMI Logging gemacht hast (siehe Prozess C:\WINDOWS\system32\wbem\wmiprvse.exe), ob die Treiber des Systems aktuell und korrekt sind usw. usf. können wir nur schwer erraten. Weiterhin sind die Ausschnitte des UserEnv Logs (welche Du zeitlich gesehen auch noch verkehrt herum gepostet hast) nur bedingt aussagekräftig. Meist ist das ganze Log notwendig, um sich dem Problem zu nähern. How to ask a question Viele Grüße olc Zitieren
