AustriaWien 10 Geschrieben 3. Juni 2008 Melden Geschrieben 3. Juni 2008 Hi, ich habe heute versucht auf einem 2008er Server (als Domaincontroller) ein Backup des System States zu machen. mittels WBADMIN START SYSTEMSTATEBACKUP -backupTarget:e: wobei e: eine externe Harddisk ist. der ablauf sah wie folgt aus *****----- WBADMIN START SYSTEMSTATEBACKUP -backupTarget:e: wbadmin 1.0 - Backup command-line tool © Copyright 2004 Microsoft Corp. Starting System State Backup [03.06.2008 13:00] Retrieving volume information... This would backup the system state from volume(s) Local Disk(C:) to e:. Do you want to start the backup operation? [Y] Yes [N] No Y Creating the shadow copy of volumes requested for backup. Creating the shadow copy of volumes requested for backup. Creating the shadow copy of volumes requested for backup. Creating the shadow copy of volumes requested for backup. Creating the shadow copy of volumes requested for backup. Creating the shadow copy of volumes requested for backup. Creating the shadow copy of volumes requested for backup. Identifying system state files to backup (This may take a few minutes)... Identifying system state files to backup (This may take a few minutes)... Identifying system state files to backup (This may take a few minutes)... Identifying system state files to backup (This may take a few minutes)... Identifying system state files to backup (This may take a few minutes)... Summary of backup: ------------------ Backup of system state failed [03.06.2008 13:03] Log of files successfully backed up 'C:\Windows\Logs\WindowsServerBackup\SystemStateBackup 03-06-2008 13-01-17.log' Log of files for which backup failed 'C:\Windows\Logs\WindowsServerBackup\SystemStateBackup_Error 03-06-2008 13-01-17 .log' System writer is not found in the backup. -----***** Ablauf ende Die Logfiles sind leer und haben Größe 0 vssadmin list writers - zeigt keine auffälligkeiten einen writer name 'system writer' gibts allerdings nicht in der Liste. sollte es das ?? ich habe auch schon den VSS-Dienst restartet und nochmal versucht. und auch einmal mit ShadowCopies Enabled und einmal mit Disabled versucht. gleiches ergebnis. Im Event Viewer sehe ich: Event 517 "Backup started at '03.06.2008 11:01:17' failed with following error code '2155348226' (System writer is not found in the backup.). Please rerun backup once issue is resolved." und Event 513 "Cryptographic Services failed while processing the OnIdentity() call in the System Writer Object. Details: AddCoreCsiFiles : GetNextFileMapContent() failed. System Error: The request could not be performed because of an I/O device error. ." bzgl. Event 513 - die Berechtigungen auf den Ordner windows/registration sind wie in Microsoft Corporation beschrieben ok. hatte schonmal jemand das gleiche problem? und evtl auch ne lösung dafür? ;) danke vorab lg D.
Lian 2.807 Geschrieben 3. Juni 2008 Melden Geschrieben 3. Juni 2008 Hallo, folgendes habe ich dazu gefunden: Microsoft TechNet Forums Home : General : System State Backup on Windows 2008 hth
XP-Fan 238 Geschrieben 3. Juni 2008 Melden Geschrieben 3. Juni 2008 Hallo, zum Event 517: Microsoft Corporation - Ist die USB Platte NTFS formatiert ? - Schlägt das Backup auch fehl wenn du ein lokales Verzeichnis als Ziel nutzt ?
AustriaWien 10 Geschrieben 3. Juni 2008 Autor Melden Geschrieben 3. Juni 2008 danke. schon probiert. auf diesen seiten war ich heute schon. wie auf viiiiiieeeeeelen anderen auch ;) jedenfalls ist mir mittlerweile auf einigen seiten aufgefallen, daß anscheinend mit "vssadmin list writers" - ein writer mit writer name: 'system writer' aufscheinen sollte. ich habe allerdings noch keinen plan wie ich einen solchen starten könnte o.ä. lg D.
Thommy70 10 Geschrieben 25. April 2011 Melden Geschrieben 25. April 2011 Falls noch jemand das gleiche Problem hat: System State backup using Windows Server Backup fails with error: System writer is not found in the backup
