scottel 10 Geschrieben 3. Juli 2008 Melden Geschrieben 3. Juli 2008 Hallo, ich sitze seit geraumer Zeit am Upgrade unserer Domain von W2K auf W2K3. Leider bleibe ich im Schritt "ADPREP" hängen. Folgender Fehler ist es: <-- schnipp ADPREP WARNING: Before running adprep, all Windows 2000 domain controllers in the forest should be upgraded to Windows 2000 Service Pack 1 (SP1) with QFE 265089, or to Windows 2000 SP2 (or later). QFE 265089 (included in Windows 2000 SP2 and later) is required to prevent poten tial domain controller corruption. For more information about preparing your forest and domain see KB article Q3311 61 at Microsoft Help and Support. [user Action] If ALL your existing Windows 2000 domain controllers meet this requirement, type C and then press ENTER to continue. Otherwise, type any other key and press ENT ER to quit. C ============================================================================ "attributeId" attribute value for objects defined in Windows 2000 schema and ext ended schema do not match. A previous schema extension has defined the attribute value as "1.2.840.113556.1 .4.7000.233.28688.28684.8.464850.1724825.154498.1299246.15" for object "CN=uid,C N=Schema,CN=Configuration,DC=wsc,DC=biz" differently than the schema extension n eeded for Windows 2003 server . [status/Consequence] Adprep cannot extend your existing schema [user Action] Contact the vendor of the application that previously extended the schema to res olve the inconsistency. Then run adprep again. ============================================================================= "isSingleValued" attribute value for objects defined in Windows 2000 schema and extended schema do not match. A previous schema extension has defined the attribute value as "TRUE" for object "CN=uid,CN=Schema,CN=Configuration,DC=wsc,DC=biz" differently than the schema e xtension needed for Windows 2003 server . [status/Consequence] Adprep cannot extend your existing schema [user Action] Contact the vendor of the application that previously extended the schema to res olve the inconsistency. Then run adprep again. ============================================================================= "attributeSyntax" attribute value for objects defined in Windows 2000 schema and extended schema do not match. A previous schema extension has defined the attribute value as "2.5.5.4" for obj ect "CN=uid,CN=Schema,CN=Configuration,DC=wsc,DC=biz" differently than the schem a extension needed for Windows 2003 server . [status/Consequence] Adprep cannot extend your existing schema [user Action] Contact the vendor of the application that previously extended the schema to res olve the inconsistency. Then run adprep again. <-- schnapp Ich habe schon vieles versucht, habe Exchange installiert/desinstalliert, div. Patches ausprobiert, also alles was zu dem Thema zu finden ist ( auch den Fix wenn SFU 2.0 installiert ist ). Leider alles ohne Erfolg, ich komme da einfach nicht weiter, es ist zum verrückt werden. Kennt sich jemand hier damit besser aus und hat einen Tipp für mich ? ich bedanke mich schon mal bei Euch. Gruss Thomas
NorbertFe 2.326 Geschrieben 3. Juli 2008 Melden Geschrieben 3. Juli 2008 Hi, kann dir nicht wirklich helfen, aber zumindest Ich habe schon vieles versucht, habe Exchange installiert/desinstalliert das hättest du dir sparen können, da eine Deinstallation von Exchange genau gar nichts am Schema ändert. div. Patches ausprobiert Welche genau? , also alles was zu dem Thema zu finden ist ( auch den Fix wenn SFU 2.0 installiert ist ).[/Quote] Waren denn die SFU bei dir mal installiert? Es gibt zwei SFU Fixes. FIX: Error message when you try to prepare the Active Directory directory service for Windows Server 2003 R2: "Attribute value for objects defined in Windows 2000 schema and extended schema do not match" und Cannot Upgrade Windows 2000 Server to Windows Server 2003 with Windows Services for UNIX 2.0 Installed Kennt sich jemand hier damit besser aus und hat einen Tipp für mich ?[/Quote] Du plenkst. Beantworte mal obige Fragen. Und schau dir die beiden Links genau an. Bye Norbert
scottel 10 Geschrieben 7. Juli 2008 Autor Melden Geschrieben 7. Juli 2008 Hallo, ich habe mir die beiden Links angeschaut ( diese Fixes hatte ich schon mal versucht anzuwenden, was deine Frage beantwortet. Beim ersten gibts ne Meldung dass 0 Einträge geändert wurden, war also leider nix: 0 entries modified successfully. The command has completed successfully Beim zweiten gibts das hier: Connecting to localhost ... Success Current host (PDC) is the FsmoRoleOwner(CN=PDC) Attribute 'uid' not found Attribute 'msSFU-Sync-Nis-Domain' not found also auch nicht viel besser. Leider komme ich da nicht wirklich weiter.
