MikeS 10 Geschrieben 31. August 2008 Melden Geschrieben 31. August 2008 Hallo, vielleicht habe den Titel nicht so elegant gewählt, habe das problem, dass wenn ich ins Festnetz rufe, das Telefon klingelt, der andere kann mich hören, aber ich höre nichts.... hat jemand eine Idee, hier meine Hardware und meine running config: Cisco 2811 VIC2-2BRI NT/TE PVDM2 - 8 no aaa new-model clock timezone MEZ 1 clock summer-time Berlin date Aug 27 2008 22:55 Oct 26 2008 3:00 clock calendar-valid network-clock-participate wic 2 network-clock-select 1 BRI0/2/0 ! dot11 syslog ip source-route no ip routing ! ! no ip cef no ip dhcp use vrf connected ! ip dhcp pool pool1 import all network 192.168.16.0 255.255.255.0 domain-name domain.local dns-server 192.168.16.222 194.8.194.60 default-router 192.168.16.253 option 150 ip 192.168.16.252 ! ! no ipv6 cef ! multilink bundle-name authenticated ! ! isdn switch-type basic-net3 ! ! ! ! ! voice register global mode cme max-dn 144 max-pool 42 ! voice statistics time-range since-reset ! voice translation-rule 10 rule 1 /\(^.*\)/ /00\1/ plan isdn national ! voice translation-rule 11 rule 1 /^27696333$/ /11/ rule 2 /^2769540$/ /12/ ! ! voice translation-profile AZ-IN translate calling 10 translate called 11 ! ! voice-card 0 no dspfarm ! ! interface FastEthernet0/0 ip address 192.168.16.252 255.255.255.0 no ip route-cache duplex half speed auto no mop enabled ! interface FastEthernet0/1 no ip address no ip route-cache shutdown duplex auto speed auto ! interface BRI0/2/0 no ip address no ip route-cache isdn switch-type basic-net3 isdn overlap-receiving isdn point-to-point-setup isdn incoming-voice voice isdn skipsend-idverify ! interface BRI0/2/1 no ip address no ip route-cache isdn switch-type basic-net3 isdn point-to-point-setup ! ip forward-protocol nd ip http server ip http authentication local ip http secure-server ! ! ! no cdp run ! ! ! ! ! ! tftp-server flash:CP7912080003SCCP070409A.sbin tftp-server flash:CP7902080002SCCP060817A.sbin tftp-server flash:ATA030203SCCP051201A.zup ! control-plane ! ! ! voice-port 0/2/0 translation-profile incoming AZ-IN translate calling 10 echo-cancel coverage 32 compand-type a-law cptone DE connection plar 1001 description Netcologne ! voice-port 0/2/1 ! ! ! ! ! dial-peer voice 6400 pots preference 6 destination-pattern 0T progress_ind setup enable 3 progress_ind progress enable 8 direct-inward-dial port 0/2/0 ! ! no dial-peer outbound status-check pots ! ! gatekeeper shutdown ! ! telephony-service load 7902 CP7902080002SCCP060817A load 7912 CP7912080003SCCP070409A load ata ATA030203SCCP051201A max-ephones 35 max-dn 20 ip source-address 192.168.16.252 port 2000 auto assign 1 to 6 timeouts interdigit 3 system message Cisco user-locale DE time-zone 23 time-format 24 date-format dd-mm-yy max-conferences 8 gain -6 moh flash:music-on-hold.au transfer-system full-consult secondary-dialtone 0 create cnf-files version-stamp 7960 Aug 31 2008 21:33:00 ! ! ephone-template 1 ! ! ephone-dn 1 number 11 name xyz ! ! ephone-dn 2 number 12 name zyx ! ! ephone 1 device-security-mode none mac-address 0013.6090.9D8A type 7912 button 1:1 ! ! ! ephone 2 device-security-mode none mac-address 0013.808D.A87E max-calls-per-button 2 type 7902 button 1:2 Wäre super wenn jemand ne Idee hätte mfg Mike Zitieren
collapse 10 Geschrieben 1. September 2008 Melden Geschrieben 1. September 2008 das Interface 0/0 wurde ich unbedingt von: duplex half speed auto auf duplex full speed 10/100 stellen. Kurz uberblickt faellt mir bei der Config kein fehler auf, bei einem Translation pattern haste eine Nummer weniger (zweitem). Zitieren
MikeS 10 Geschrieben 5. September 2008 Autor Melden Geschrieben 5. September 2008 habe ALLES ausprobiert, seit einer Woche bastel ich an der config rum, jetzt habe ich einen Factory Reset al letzten Versuch gemacht, und siehe da, es Funktioniert! vielen Dank für die Hilfe Mike Zitieren
