a.haist 10 Geschrieben 25. September 2008 Melden Geschrieben 25. September 2008 Hello Community, I am at a customer which has some Kerberos problems in his SharePoint/K2 environment. Topology: The Customer has a one SharePoint server with all roles and K2 2003 for Workflows on it and one SQL Server 2005. Windows Server 2003, SQL Server 2005 and SharePoint 2007 are up to date. Problem: The customer wants to have Kerberos as auth. protocol and therefore we have done the following steps to enable it: 1. Enable Kerberos for SQL Server setspn -A MSSQLSvc/sql01.devdemo.de:1433 devdemo\_svc_sql Restartet SQL Server Test it with: select auth_scheme, * from sys.dm_exec_connections Works! 2. Added the URL as a SPN setspn -A HTTP/intranet.devdemo.de devdemo\_svc_app_intranet setspn -A HTTP/intranet devdemo\_svc_app_intranet 3. Created a SPN for the Application pool Account setspn –A…. 4. Enable Kerberos in the SharePoint Web Application auth provider 5. Set Service Accounts “Account is trusted for delegation” I tested with Fiddler if the User now uses Kerberos when he entered the SharePoint Site and he does so… But we have still these Errors in the Event Log: Event Type: Error Event Source: Kerberos Event Category: None Event ID: 3 Date: 25.09.2008 Time: 09:24:34 User: N/A Computer: W01ABBP01 Description: A Kerberos Error Message was received: on logon session eu\user Client Time: Server Time: 7:24:34.0000 9/25/2008 Z Error Code: 0x18 KDC_ERR_PREAUTH_FAILED Extended Error: Client Realm: Client Name: Server Realm: eu Server Name: krbtgt/eu Target Name: krbtgt/eu@eu Error Text: File: e Line: 6c0 Error Data is in record data. For more information, see Help and Support Center at Events and Errors Message Center: Basic Search. Data: 0000: 30 75 30 73 a1 03 02 01 0u0s¡... 0008: 0b a2 6c 04 6a 30 68 30 .¢l.j0h0 0010: 09 a0 03 02 01 17 a1 02 . ....¡. 0018: 04 00 30 0a a0 04 02 02 ..0. ... 0020: ff 7b a1 02 04 00 30 09 ÿ{¡...0. 0028: a0 03 02 01 80 a1 02 04 ...¡.. 0030: 00 30 21 a0 03 02 01 03 .0! .... 0038: a1 1a 04 18 45 55 2e 54 ¡...EU.T 0040: 41 4b 41 54 41 43 4f 52 AKATACOR 0048: 50 2e 43 4f 4d 6d 61 6c P.COMmal 0050: 73 61 6d 61 30 21 a0 03 sama0! . 0058: 02 01 01 a1 1a 04 18 45 ...¡...E 0060: 55 2e 54 41 4b 41 54 41 U.CUSTOMER 0068: 43 4f 52 50 2e 43 4f 4d CORP.COM 0070: 6d 61 6c 73 61 6d 61 user Event Type: Error Event Source: Kerberos Event Category: None Event ID: 3 Date: 25.09.2008 Time: 09:22:52 User: N/A Computer: W01ABBP01 Description: A Kerberos Error Message was received: on logon session Client Time: Server Time: 7:22:52.0000 9/25/2008 Z Error Code: 0xd KDC_ERR_BADOPTION Extended Error: 0xc00000bb KLIN(0) Client Realm: Client Name: Server Realm: EU.TAKATACORP.COM Server Name: host/w01abbp01.eu.customer.com Target Name: host/w01abbp01.eu.customer.com@EU.CUSTOMER.COM Error Text: File: 9 Line: ae0 Error Data is in record data. For more information, see Help and Support Center at Events and Errors Message Center: Basic Search. Data: 0000: 30 15 a1 03 02 01 03 a2 0.¡....¢ 0008: 0e 04 0c bb 00 00 c0 00 ...»..À. 0010: 00 00 00 03 00 00 00 ....... I already searched for a resolution and some Forum entry’s pointed, that this could be a problem with Cross Forest trust or some that the Client has two SPN’s. Hope that helps a little bit… Attached I have the Netdiag /v file from that server, that shows that everything is fine!?! Questions: • Does anyone have seen these errors before? • Is there any further configuration for K2 or the Server necessary? • How can I check if the Server does not have two SPN’s? Hope someone solved this problem before… Please contact me directly: andreas.haist@avanade.com Thanks, Andreas
olc 18 Geschrieben 25. September 2008 Melden Geschrieben 25. September 2008 Hi Andreas, welcome to the board, I am not a SharePoint expert, but I think you should take a network trace to have a look on the Kerberos messages between client and SharePoint respectively SharePoint and DC. A network trace mostly gives you some hints regarding the underlaying issue. Since we can see the error Error Code: 0x18 KDC_ERR_PREAUTH_FAILEDmaybe this is an authentication problem. Are you sure that the credentials you provided for the testuser are correct?If yes, check the time on the IIS / SharePoint and the DC. Is there a time difference? How can I check if the Server does not have two SPN’s? See http://support.microsoft.com/kb/321044/en-US: ldifde -f check_SPN.txt -t 3268 -d "" -l servicePrincipalName -r (servicePrincipalName=HOST/mycomputer*)" -p subtree Please contact me directly: andreas.haist@avanade.com You know this is a forum and not a newsgroup, right? Or is this thread just a joke? ;) Regards, olc
Sunny61 834 Geschrieben 25. September 2008 Melden Geschrieben 25. September 2008 You know this is a forum and not a newsgroup, right? Off-Topic: Auch in einer Newsgroups gibts keine Antworten an eine Mailadresse. ;)
