probleme mit pppoe über c1720
Hallo, ich kann mich mit dieser Config auf einer cisco 1720 einwählen (s.u), kann aber nicht ins internet pingen.
mich wundert das di1 an vi2 bindet und dieser nur 56k verbindung hat.
was ist hier falsch ??
danke für euer hilfe
hoellentor uptime is 33 minutes
System returned to ROM by reload
System image file is "flash:c1700.122.bin"
Current configuration : 1144 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
service password-encryption
memory-size iomem 25
ip subnet-zero
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
ip mtu adjust
interface FastEthernet0
ip address 192.168.3.1 255.255.255.240
ip nat inside
no ip route-cache
ip tcp adjust-mss 1452
no ip mroute-cache
speed 10
half-duplex
pppoe enable
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer hold-queue 10
dialer-group 1
no cdp enable
ppp chap hostname 1111111111111xxxxxxxxxxxaaaa@t-online.de
ppp chap password 7 122345
ip nat inside source list 1 interface Dialer1 overload
ip classless
access-list 1 permit 192.168.0.0 0.0.255.255
dialer-list 1 protocol ip permit
FastEthernet0 is up, line protocol is up
Hardware is PQUICC_FEC, address is 0008.e320.f08d (bia 0008.e320.f08d)
Internet address is 192.168.3.1/28
Dialer1 is up, line protocol is up (spoofing)
Hardware is Unknown
Internet address is 217.232.227.10/32
MTU 1500 bytes, BW 56 Kbit, DLY 20000 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation PPP, loopback not set
DTR is pulsed for 1 seconds on reset
Interface is bound to Vi2
Virtual-Access2 is up, line protocol is up
Hardware is Virtual Access interface
MTU 1500 bytes, BW 56 Kbit, DLY 100000 usec,
Encapsulation PPP, LCP Open
Open: IPCP
PPPoE vaccess, cloned from Dialer1, loopback not set
Interface is bound to Di1 (Encapsulation PPP)
Last input 00:03:15, output never, output hang never
Last clearing of "show interface" counters 00:20:12
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Virtual-Access1 is up, line protocol is up
MTU 1492 bytes, BW 100000 Kbit, DLY 100000 usec,
Base PPPoE vaccess, loopback not set
DTR is pulsed for 5 seconds on reset
Last input never, output never, output hang never
Last clearing of "show interface" counters 00:36:07
Input queue: 0/4096/0/0 (size/max/drops/flushes); Total output drops: 0
Output queue: 0/40 (size/max)
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 0 interface resets
0 output buffer failures, 0 output buffers swapped out
0 carrier transitions
Total PPPoE sessions 1
PPPoE Session Information
UID SID RemMAC OIntf Intf Session
LocMAC VASt state
0 2209 0090.1aa0.8e66 Fa0 Vi2 N/A
0008.e320.f08d UP
Hallo.
das ganze ist so aufgebaut. Ich habe einen Thomson Speedtouch Modem (Bridge Mode) der dsl seitig am splitter hängt. In dessen lanseitigen 4-Port Switch steckt das kabel, welches von fa0 der cisco kommt. dazu noch ein weiteres kabel, das zu meinem eigentlichen lan switch geht. Dazu noch ein drittes Kabel, welches mit einem 2. Router verbunden ist, der eine eigene PPPoe verbindung aufbauen kann. Das brauch ich aus beruflichen Gründen manchmal, weil ich bei diesem pppoe account eine feste ip habe.
Das ganze geht zwar auch parallel dauerhaft ganz gut, aber ist ja in T-Com nicht erlaubt 2 verbindungen parallel zu fahren.
Fakt ist halt, das die cisco sich einwählt, aber nicht raus pingen kann.
ich muss mal schauen, wenn ich daheim bin, ob das echt an der fehlenden default route liegt. Das wäre der hammer.
dirk
FA0 steckt sowohl im internen LAN als auch am DSL? Stimmt das?
uuups das wäre der Hammer, danke dir.. das werde ich sofort gegen checken. Was mich halt irritiert ist, das di1 an vi2 gebunden ist, die nur 56kbit breit ist.
weisst du warum das so ist. bei meiner alten 1603er war immer nur 1vi an di1 gebunden.
die konfig ist eigentlich von der 1603 kopiert. haben beide ein 12.2er ios.
mit den selben features.
wenn das die koplette config ist, dann fehlt dir zB ne Default Route
