jussi 11 Geschrieben 20. Oktober 2008 Melden Geschrieben 20. Oktober 2008 Hallo, scheinbar kann mein 1721 nur 10 mbit/s obwohl es fastethernet ports im switchmodul hat: ------------------------------- Cisco IOS Software, C1700 Software (C1700-IPBASEK9-M), Version 12.4(15)T4, RELEASE SOFTWARE (fc2) Technical Support: Cisco - Shortcut Copyright © 1986-2008 by Cisco Systems, Inc. Compiled Thu 13-Mar-08 00:01 by prod_rel_team ROM: System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1) xxxxx uptime is 24 weeks, 3 days, 3 hours, 30 minutes System returned to ROM by Reload Command System image file is "flash:c1700-ipbasek9-mz.124-15.T4.bin" [...] Cisco 1721 (MPC860P) processor (revision 0x400) with 114688K/16384K bytes of memory. Processor board ID FOC08202XHT (1447131895), with hardware revision 0000 MPC860P processor: part number 5, mask 2 1 Ethernet interface 5 FastEthernet interfaces 1 Serial(sync/async) interface 32K bytes of NVRAM. 32768K bytes of processor board System flash (Read/Write) ---------------------------------------------------------------------------------------- interface FastEthernet0 description dtag etherconnect auf xxxxx ip address xxxxxxxxxxxxxxxxx speed 100 full-duplex ! interface FastEthernet1 ! interface FastEthernet2 ! interface FastEthernet3 description isis switchport access vlan 3 ! interface FastEthernet4 description QSC switchport access vlan 4 ! interface Serial0 description T_COM Backup ip address xxxxxxxxxxxxx no ip redirects no ip unreachables no ip route-cache cef no ip route-cache no ip mroute-cache ! interface Vlan1 no ip address ! interface Vlan2 ! interface Vlan3 description ISIS ip address xxxxxxxxx secondary ip address xxxxxxxxx ! interface Vlan4 description QSC ip address xxxxxxx ! no ip forward-protocol nd ip route 0.0.0.0 0.0.0.0 aaaaaaaa ip route 0.0.0.0 0.0.0.0 bbbbbbbb 200 ip route zzzzzzzz wwwwwwww yyyyyyyy ------------------------------------------------- das betreffende interface macht lt cisco 100 full: MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 4/255, rxload 5/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 100Mb/s, 100BaseTX/FX ------------------------------------------------ das interface hängt an einem metropolis der DTAG , auf der anderen seite ist ein 2950 mit vlan, der wiederum an der routing ggstelle ist. drüben steht auch alles auf 100 mbit, wenn ich alles abbaue und an beiden seiten der dtag etherconnect leitung ein laptop hänge bekomme ich volle 48 mbit (das produkt der dtag ist etherconnect 50 mit 48 mbit/s) sobald die ciscos dranhängen nur noch 10... hat jemand einen guten Vorschlag? Danke im voraus Zitieren
Wordo 11 Geschrieben 20. Oktober 2008 Melden Geschrieben 20. Oktober 2008 Meine Vermutung, der alte Router kann nur 100Mbit switchen, routen dagegen nicht so schnell. Gabs da nicht mal so ein Routingperformance PDF? – http://4isp.ru/admin/images//pp/Doc/routerperformance.pdf Ist schon etwas aelter und gibts nicht mehr auf cisco.com. Keine Ahnung wie ernst man die Werte nehmen darf. Zitieren
jussi 11 Geschrieben 20. Oktober 2008 Autor Melden Geschrieben 20. Oktober 2008 danke schön. Au weia.... das sind aber keine hard caps sondern irgendwelche worst case mediane, oder? ich meine ich hätte schon mehr gehabt als 6.14 nur eben noch nie mehr als 10. Zitieren
daking 10 Geschrieben 20. Oktober 2008 Melden Geschrieben 20. Oktober 2008 Hallo, die pps Angabe basiert auf 64Byte CBR Streams.. Trotzdem wird mit dem 1721 nicht mehr als 10 Mbit/s gehen.. // hat jemand einen guten Vorschlag // ==> Router tauschen brgds Zitieren
blackbox 10 Geschrieben 20. Oktober 2008 Melden Geschrieben 20. Oktober 2008 Hallo, die FastEthernet Ports sind ein Switch der nach innen mit 10 Mbit angebunden ist - das ist das Ethernet Interface was in der Hardware Liste auftraucht : MPC860P processor: part number 5, mask 2 1 Ethernet interface <-------------------- 5 FastEthernet interfaces 1 Serial(sync/async) interface 32K bytes of NVRAM. Gruss Zitieren
