Deatheye 10 Geschrieben 15. Januar 2009 Melden Geschrieben 15. Januar 2009 Hallo zusammen Ich versuche momentan einige Treiber an die Windowsinstallation über WDS zu übergeben. Die implementation des Netzwerktreibers funktioniert irgendwie nicht. Dazu einige logfile auschnitte: 2009-01-14 18:15:24, Info [0x070035] DIAG CallBack_DiagnosticDataGeneration: Called with notification for Initialization 2009-01-14 18:15:24, Info [0x07003b] DIAG CallBack_DiagnosticDataGeneration: Starting Timer as we are starting new phase 2009-01-14 18:15:24, Info [0x0b0022] WDS StartNetworking: Trying to start networking. 2009-01-14 18:15:24, Info WDS Network service dhcp not running or could not be queried: 43bec0 1 1 2009-01-14 18:15:24, Info WDS Network service lmhosts not running or could not be queried: 43bec0 1 1 2009-01-14 18:15:24, Info WDS Network service lanmanworkstation not running or could not be queried: 43bec0 1 1 2009-01-14 18:15:24, Info WDS Network service ikeext not running or could not be queried: 43bec0 1 1 2009-01-14 18:15:24, Info WDS Network service mpssvc not running or could not be queried: 43bec0 1 1 2009-01-14 18:15:32, Info WDS Installing device pci\ven_8086&dev_10a7 X:\WINDOWS\INF\oem0.inf succeeded 2009-01-14 18:15:38, Info WDS Installing device pci\ven_8086&dev_10a7 X:\WINDOWS\INF\oem0.inf succeeded 2009-01-14 18:15:38, Info WDS Service dhcp stop: 0x00000000 2009-01-14 18:15:38, Info WDS Service lmhosts stop: 0x00000000 2009-01-14 18:15:39, Info WDS Service bfe stop: 0x00000000 2009-01-14 18:15:39, Info WDS Service ikeext stop: 0x00000000 2009-01-14 18:15:39, Info WDS Service mpssvc stop: 0x00000000 2009-01-14 18:15:39, Info WDS Spent 125ms initializing security templates; status 0x00000000 2009-01-14 18:15:40, Info WDS Install MS_MSCLIENT: 0x0004a020 2009-01-14 18:15:40, Info WDS Install MS_NETBIOS: 0x0004a020 2009-01-14 18:15:40, Info WDS Install MS_SMB: 0x0004a020 2009-01-14 18:15:40, Info WDS Install MS_TCPIP6: 0x0004a020 2009-01-14 18:15:41, Info WDS Install MS_TCPIP: 0x0004a020 2009-01-14 18:15:44, Info WDS Spent 5219ms installing network components Wenn ich das richtig interpretiere ist hier noch die eigentlich windows PE Umgebung bevor die Daten vom WDS geholt werden. Dafür nimmt er die Netzwerkkarte in Betrieb. pci\ven_8086&dev_10a7 ist eine Intel Netzwerkkarte die im Windows Später dann nicht funktioniert, bzw Treiber einfach manuell installiert werden müssen. Zitieren
Deatheye 10 Geschrieben 15. Januar 2009 Autor Melden Geschrieben 15. Januar 2009 2009-01-14 18:26:20, Info CBS Pkgmgr: Install Drivers Offline Callback: INFO: Installing driver package '\\vwds08\treiber$\x64\Server\Supermicro25\Netzwerk\Intelpro\e1q51x64.inf' to the currently offline OS ... (Error code (HRESULT) 0x0.) 2009-01-14 18:26:20, Info CBS Pkgmgr: Install Drivers Offline Callback: INFO: The class GUID for INF '\\vwds08\treiber$\x64\Server\Supermicro25\Netzwerk\Intelpro\e1q51x64.inf' is '4d36e972-e325-11ce-bfc1-08002be10318'! (Error code (HRESULT) 0x0.) 2009-01-14 18:26:20, Info CBS Pkgmgr: Install Drivers Offline Callback: INFO: The class GUID '4d36e972-e325-11ce-bfc1-08002be10318' is not boot-critical. (Error code (HRESULT) 0x0.) 2009-01-14 18:26:20, Info CBS Pkgmgr: Install Drivers Offline Callback: INFO: '\\vwds08\treiber$\x64\Server\Supermicro25\Netzwerk\Intelpro\e1q51x64.inf' is not a boot critical driver. (Error code (HRESULT) 0x0.) 2009-01-14 18:26:20, Error CBS Pkgmgr: Install Drivers Offline Callback: ERROR: Failed to stage driver '\\vwds08\treiber$\x64\Server\Supermicro25\Netzwerk\Intelpro\e1q51x64.inf' (HRESULT= 0x80070002). (Error code (HRESULT) 0x80070002.) 2009-01-14 18:26:20, Error CBS Pkgmgr: Install Drivers Offline Callback: ERROR: Failed to install driver package '\\vwds08\treiber$\x64\Server\Supermicro25\Netzwerk\Intelpro\e1q51x64.inf'. (Error code (HRESULT) 0x80070002.) 2009-01-14 18:26:20, Info CBS Pkgmgr: Install Drivers Offline Callback: INFO: Installing driver package '\\vwds08\treiber$\x64\Server\Supermicro25\Netzwerk\Intelpro\e1q60x64.inf' to the currently offline OS ... (Error code (HRESULT) 0x0.) 2009-01-14 18:26:20, Info CBS Pkgmgr: Install Drivers Offline Callback: INFO: The class GUID for INF '\\vwds08\treiber$\x64\Server\Supermicro25\Netzwerk\Intelpro\e1q60x64.inf' is '4d36e972-e325-11ce-bfc1-08002be10318'! (Error code (HRESULT) 0x0.) 2009-01-14 18:26:20, Info CBS Pkgmgr: Install Drivers Offline Callback: INFO: The class GUID '4d36e972-e325-11ce-bfc1-08002be10318' is not boot-critical. (Error code (HRESULT) 0x0.) 2009-01-14 18:26:20, Info CBS Pkgmgr: Install Drivers Offline Callback: INFO: '\\vwds08\treiber$\x64\Server\Supermicro25\Netzwerk\Intelpro\e1q60x64.inf' is not a boot critical driver. (Error code (HRESULT) 0x0.) 2009-01-14 18:26:20, Error CBS Pkgmgr: Install Drivers Offline Callback: ERROR: Failed to stage driver '\\vwds08\treiber$\x64\Server\Supermicro25\Netzwerk\Intelpro\e1q60x64.inf' (HRESULT= 0x80070002). (Error code (HRESULT) 0x80070002.) 2009-01-14 18:26:20, Error CBS Pkgmgr: Install Drivers Offline Callback: ERROR: Failed to install driver package '\\vwds08\treiber$\x64\Server\Supermicro25\Netzwerk\Intelpro\e1q60x64.inf'. (Error code (HRESULT) 0x80070002.) e1q60x64.inf ist dann auch der Treiber den man am Schluss in Windows manuell installieren muss. Auch soweit verständlich da hier ein Errorcode zurückgegeben wird. Nur happerts jetzt bei der weiteren Fehleranalyse. Ich weiss weder was "to stage a driver" bedeuten soll noch kann ich mit dem Fehlercode was anfangen: # for hex 0x80070002 / decimal -2147024894 : COR_E_FILENOTFOUND corerror.h # MessageText: DIERR_NOTFOUND dinput.h DIERR_OBJECTNOTFOUND dinput.h STIERR_OBJECTNOTFOUND stierr.h # 4 matches found for "0x80070002" Diverse andere Treiber die an dieser Stelle verarbeiten werden laufen mit Status code 0 problemlos durch und werden in Windows dann auch genutzt. Zitieren
Deatheye 10 Geschrieben 16. Januar 2009 Autor Melden Geschrieben 16. Januar 2009 Hab den Fehler womöglich muss es noch übberprüfen aber würde Sinn ergeben. Wenn ich mir die Treiberdatei anschaue: ;-------------- Coinstaller installation [CoInstaller_CopyFiles] NicCo2.dll,,, 0x00000010 ;don't overwrite NicInstQ.dll e1qmsg.dll Diese dll sind nicht in dem Share vorhanden. Womit auch der Errorcode 0x80070002 -->NOTFOUND Sinn ergeben würde. Mal schauen. EDIT: jap tatsächlich.. wie naheliegend und einfach doch die Lösung manchmal sein kann und man findet sie trotzdem Stundenlang nicht -.- *Kopf gegen mit Nägeln bestücktem Brett schlag* Zitieren
