Wordo 11 Geschrieben 17. Februar 2009 Melden Teilen Geschrieben 17. Februar 2009 Noch nicht .. der muss noch 3 2950 fertig machen ... noch etwas Geduld bitte :) Zitieren Link zu diesem Kommentar
Wordo 11 Geschrieben 19. Februar 2009 Melden Teilen Geschrieben 19. Februar 2009 Also ich habs jetzt selbst gemacht und funzt einwandfrei: Cisco IOS Software, C870 Software (C870-ADVENTERPRISEK9-M), Version 12.4(22)T, RELEASE SOFTWARE (fc1) Technical Support: Cisco - Shortcut Copyright © 1986-2008 by Cisco Systems, Inc. Compiled Fri 10-Oct-08 12:57 by prod_rel_team ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE testtest uptime is 3 hours, 0 minutes System returned to ROM by reload at 15:54:25 MET Tue Nov 11 2008 System image file is "flash:c870-adventerprisek9-mz.124-22.T.bin" Last reload reason: Reload Command This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: Export Compliance Product Report Application If you require further assistance please contact us by sending email to export@cisco.com. Cisco 876 (MPC8272) processor (revision 0x200) with 118784K/12288K bytes of memory. Processor board ID FHK12122A8V MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10 4 FastEthernet interfaces 1 ISDN Basic Rate interface 1 ATM interface 128K bytes of non-volatile configuration memory. 28672K bytes of processor board System flash (Intel Strataflash) Configuration register is 0x2102 ! interface FastEthernet0 switchport access vlan 2 ! interface Vlan1 ip address 10.11.12.13 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Vlan2 no ip address pppoe-client dial-pool-number 4 ! interface Dialer4 ip address negotiated ip mtu 1492 ip nat outside ip virtual-reassembly encapsulation ppp dialer pool 4 dialer-group 4 no cdp enable ppp authentication pap callin ppp pap sent-username xxx password xxx ppp ipcp dns request ppp ipcp wins request ! ip forward-protocol nd ip route 0.0.0.0 0.0.0.0 Dialer4 ! dialer-list 4 protocol ip permit testtest#sh int dialer 4 Dialer4 is up, line protocol is up (spoofing) Hardware is Unknown Internet address is X.X.X.X/32 MTU 1500 bytes, BW 56 Kbit/sec, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, loopback not set Keepalive set (10 sec) DTR is pulsed for 1 seconds on reset Interface is bound to Vi1 [...] Bound to: Virtual-Access1 is up, line protocol is up Hardware is Virtual Access interface MTU 1500 bytes, BW 56 Kbit/sec, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, LCP Open Open: IPCP PPPoE vaccess, cloned from Dialer4 Vaccess status 0x44, loopback not set [...] Zitieren Link zu diesem Kommentar
glady 10 Geschrieben 25. Februar 2009 Autor Melden Teilen Geschrieben 25. Februar 2009 Wordo, erst mal Danke für Deinen Test! Kann das Problem evtl. an der aaa Konfiguration liegen? aaa new-model ! ! aaa authentication login group group tacacs+ local aaa authentication enable default group tacacs+ enable aaa authorization exec default group tacacs+ local if-authenticated aaa authorization commands 15 default group tacacs+ local if-authenticated ! ! aaa session-id common tacacs-server host x.x.x.x timeout 2 key 0815 Zitieren Link zu diesem Kommentar
Wordo 11 Geschrieben 25. Februar 2009 Melden Teilen Geschrieben 25. Februar 2009 Hm, kannst den Mist nich mal raushaun? ;) Zitieren Link zu diesem Kommentar
jussi 11 Geschrieben 27. Februar 2009 Melden Teilen Geschrieben 27. Februar 2009 glady, binde doch mal de den dialer pool direkt an ein eth läuft bei mir einwandfrei Zitieren Link zu diesem Kommentar
matrixxx 10 Geschrieben 10. März 2009 Melden Teilen Geschrieben 10. März 2009 Hey Gladdy, ich schlag' mich grad mit ähnlichen Problemen rum (wer helfen kann, der helfe! :D Hier is mein Thread: http://www.mcseboard.de/cisco-forum-allgemein-38/cisco-876-sdsl-modem-t-com-business-anschluss-148758.html ) Also was die AAA-Einträge angeht, kann ich dir sagen dass es an denen sicher nicht scheitert. Die haben definitiv nichts mit der PPPoE-Verbindung o.ä. zu tun! Dienen lediglich zur Authentifizierung von Benutzern die sich remote (Telnet/SSH) auf deinen Router verbinden wollen. Grüße, Tom ;) Zitieren Link zu diesem Kommentar
glady 10 Geschrieben 19. März 2009 Autor Melden Teilen Geschrieben 19. März 2009 Problem ist gelöst. Der Kunde hat mir ein Ei gelegt. Meine Anweisung war, zieh das Kabel am Router, steck es am NB ein, wähle dich ein. Er hat aber eindere Kabel an's Modem gesteckt... DAS KABEL WAR'S!!! Das Fliederfabene Cisco Original-Kabel wurde an das Fa3 gesteckt. Zwar geht der Port up, funktioniert aber trotzdem nicht. Danke für eure Mithilfe, besonders Wordo, der extra nachgestellt hat! Grüße, Glady Zitieren Link zu diesem Kommentar
Wordo 11 Geschrieben 19. März 2009 Melden Teilen Geschrieben 19. März 2009 Jaja .. es sind immer die kleinen Dinge im Leben ... ;) Zitieren Link zu diesem Kommentar
JohnnyFu 10 Geschrieben 30. September 2010 Melden Teilen Geschrieben 30. September 2010 (bearbeitet) glady, binde doch mal de den dialer pool direkt an ein eth läuft bei mir einwandfrei Auch wenn das jetzt schon ein altes Thema ist, bei mir läuft das nicht sondern endet in PAPI timeout! Ich muss den dialer pool auf ein Vlan Interface legen (Cisco 876). Ich könnte aber auch zu müde sein :D Außerdem habe ich gemerkt das der Dialer die configuration nicht on the fly übernimmt. Ich habe den Dialer auf das Interface Fa0 gelegt und im debug sind die PAPI packets weiterhin auf Vlan 2 gesendet worden. bearbeitet 30. September 2010 von JohnnyFu Zitieren Link zu diesem Kommentar
