ASA5510 VPN NAT Problem: portmap translation creation failed
Hi,
ich versuche hier gerade an meiner ASA VPN einzurichten, das hat auch alles wunderbar geklappt! Ich kann mich mit meinem VPN Client an der Firewall anmelden und bekomme auch eine IP: 10.24.3.10!
Wenn ich aber nun eine Interne Adresse (10.99.0.8) anpingen möchte, bekomme ich immer die Fehlermeldung:
portmap translation creation failed for udp src Outside:10.24.3.10/137 dst NLs:10.24.3.255/137
portmap translation creation failed for icmp src Outside:10.24.3.10 dst DRC_SRV_Inside:10.99.0.8 (type 8, code 0)
Hier meine Konfig:
ASA Version 8.0(4)3
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list DRC_Server_access_in extended permit ip any any log warnings
access-list NLs_access_in extended permit ip any any log warnings
access-list BT_access_in extended permit icmp any any log warnings
access-list DRC_SRV_Inside_nat0_outbound extended permit ip any 10.99.1.0 255.25
5.255.240
access-list DRC_SRV_Inside_nat0_outbound extended permit ip any 10.24.3.0 255.25
5.255.0
access-list Outside_access_in extended permit icmp any any log warnings
pager lines 24
mtu Outside 1500
mtu GlobalMP 1500
mtu NLs 1500
mtu DRC_SRV_Inside 1500
ip local pool VPNPool 10.24.3.10-10.24.3.254 mask 255.255.255.0
ip verify reverse-path interface Outside
ip verify reverse-path interface GlobalMP
ip verify reverse-path interface NLs
ip verify reverse-path interface DRC_SRV_Inside
icmp unreachable rate-limit 1 burst-size 1
arp timeout 14400
global (Outside) 1 interface
global (GlobalMP) 1 interface
nat (Outside) 1 10.24.3.0 255.255.255.0 outside
nat (DRC_SRV_Inside) 0 access-list DRC_SRV_Inside_nat0_outbound
nat (DRC_SRV_Inside) 1 0.0.0.0 0.0.0.0
access-group Outside_access_in in interface Outside
access-group BT_access_in in interface GlobalMP
access-group NLs_access_in in interface NLs
access-group DRC_Server_access_in in interface DRC_SRV_Inside
route Outside 0.0.0.0 0.0.0.0 212.xxx.xxx.xxx 1
route NLs 10.0.0.0 255.0.0.0 10.99.1.2 1
route DRC_SRV_Inside 192.168.0.0 255.255.0.0 10.99.0.8 1
dynamic-access-policy-record DfltAccessPolicy
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map Outside_dyn_map 20 set pfs
crypto dynamic-map Outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto dynamic-map Outside_dyn_map 20 set security-association lifetime seconds
28800
crypto dynamic-map Outside_dyn_map 20 set security-association lifetime kilobyte
s 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128
-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256
-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set security-association life
time seconds 28800
crypto map Outside_map 65535 ipsec-isakmp dynamic Outside_dyn_map
crypto map Outside_map interface Outside
crypto isakmp enable Outside
crypto isakmp policy 10
X
crypto isakmp ipsec-over-tcp port 10000
telnet timeout 30
ssh timeout 5
console timeout 0
e-rate 200
group-policy xxxxx internal
group-policy xxxxx attributes
dns-server value 10.99.0.20 192.168.250.3
vpn-tunnel-protocol IPSec svc
ip-comp enable
re-xauth enable
group-lock value xxxxxxxx
pfs enable
default-domain value de.xxxxxxxxx.com
vpn-group-policy xxxxxxx
tunnel-group xxxxxxx type remote-access
tunnel-group xxxxxxx general-attributes
address-pool VPNPool
default-group-policy xxxxxxx
tunnel-group xxxxxxx ipsec-attributes
pre-shared-key xxxxxxx
class-map global-class
match default-inspection-traffic
policy-map global-policy
class global-class
inspect ftp
inspect icmp
service-policy global-policy global
: end
Ich hoffe es kann mir jemand helfen.... THX:D
Das ganze hört sich nach einem Fehler im "NAT" an. Schau dir das ganze mal an - ich bin etwas erstaunt, weil deine NAT0 Regel aus 2 besteht - normalerweise sollte die von <-> an sein und reichen.
Kann es sein das die Route "route NLs 10.0.0.0 255.0.0.0 10.99.1.2 1" irgendwie nicht passt - das ganze 10er Netz auf eine 10er Adresse ?
hi Blackbox.... danke für die schnelle Antwort....
hab die Sache mal mit einer NAT0 Regel getestet, leider kein Erfolg!
eigentlich sieht das Routing so aus: (Ich hatte nur nicht so viel Zeichen zum erstellen meiner Anfrage:()
route GlobalMP 10.0.9.17 255.255.255.255 10.24.0.5 1
route GlobalMP 10.13.16.0 255.255.255.0 10.24.0.5 1
route GlobalMP 10.13.17.0 255.255.255.0 10.24.0.5 1
route GlobalMP 10.13.18.0 255.255.255.0 10.24.0.5 1
route GlobalMP 10.13.22.40 255.255.255.255 10.24.0.5 1
route GlobalMP 10.13.22.41 255.255.255.255 10.24.0.5 1
route GlobalMP 10.13.22.47 255.255.255.255 10.24.0.5 1
route GlobalMP 10.13.22.48 255.255.255.255 10.24.0.5 1
route GlobalMP 10.13.22.49 255.255.255.255 10.24.0.5 1
route GlobalMP 10.14.2.0 255.255.255.0 10.24.0.5 1
route GlobalMP 10.14.5.0 255.255.255.0 10.24.0.5 1
route GlobalMP 10.14.6.33 255.255.255.255 10.24.0.5 1
route GlobalMP 10.14.33.0 255.255.255.0 10.24.0.5 1
route GlobalMP 10.15.6.0 255.255.255.0 10.24.0.5 1
route GlobalMP 10.19.111.0 255.255.255.0 10.24.0.5 1
route NLs 10.30.1.0 255.255.255.192 10.99.1.5 1
route NLs 10.30.2.0 255.255.255.192 10.99.1.5 1
route NLs 10.30.5.0 255.255.255.192 10.99.1.5 1
route NLs 10.30.6.0 255.255.255.192 10.99.1.5 1
route NLs 10.30.7.0 255.255.255.192 10.99.1.5 1
route NLs 10.30.10.0 255.255.255.192 10.99.1.5 1
route NLs 10.30.52.0 255.255.255.0 10.99.1.5 1
route NLs 10.30.104.0 255.255.255.192 10.99.1.5 1
route NLs 10.90.9.0 255.255.255.192 10.99.1.5 1
route NLs 10.90.85.0 255.255.255.192 10.99.1.5 1
route NLs 10.90.86.0 255.255.255.192 10.99.1.5 1
route NLs 10.90.94.0 255.255.255.192 10.99.1.5 1
route NLs 10.90.97.0 255.255.255.192 10.99.1.5 1
route NLs 10.90.98.0 255.255.255.192 10.99.1.5 1
route NLs 10.91.2.0 255.255.255.192 10.99.1.5 1
route GlobalMP 10.99.2.0 255.255.255.0 10.24.0.5 1
route GlobalMP 10.149.10.0 255.255.255.0 10.24.0.5 1
route GlobalMP 10.151.0.0 255.255.0.0 10.24.0.5 1
route GlobalMP 10.152.4.0 255.255.255.0 10.24.0.5 1
route GlobalMP 10.152.5.0 255.255.255.0 10.24.0.5 1
route GlobalMP 10.152.104.44 255.255.255.255 10.24.0.5 1
route GlobalMP 10.153.0.0 255.255.255.0 10.24.0.5 1
Ich denke aber nicht, das es am Routing liegt, das komische ist, wenn ich eine Statische NAT Regel anlege:
static (Outside,DRC_SRV_Inside) interface 10.24.3.10 netmask 255.255.255.255 tcp 0 0 udp 0
im ASDM kommt dabei diese Fehlermeldung:
[WARNING] static (Outside,DRC_SRV_Inside) interface 10.24.3.10 netmask 255.255.255.255 tcp 0 0 udp 0
All traffic destined to the IP address of the DRC_SRV_Inside interface is being redirected.
WARNING: Users will not be able to access any service enabled on the DRC_SRV_Inside interface.
aber der Ping funktioniert dann!!!:confused:
