Cisco 876 - Verbindungsabbrüche trotz stehender Verbindung
Hallo zusammen,
ich habe seit kurzem recht große Probleme mit dem 876 an einem T-Com Business Anschluss.
Die Verbindung steht, es gehen icmp Pakete über die Leitung aber sobald man versucht eine Website aufzurufen, klappt das nicht.
Nach einem Neustart geht wieder alles.
Der Dialer sieht folgender maßen aus:
interface Dialer0
ip address xx.xx.xx.xx 255.255.255.224
ip mtu 1452
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname bla@t-
ppp chap password 7 xxxxxxxxxxxxx
end
interface ATM0
no ip address
ip route-cache flow
atm vc-per-vp 64
no atm ilmi-keepalive
dsl operating-mode auto
end
interface ATM0.1 point-to-point
pvc 1/32
pppoe-client dial-pool-number 1
end
sh int di0:
Dialer0 is up, line protocol is up (spoofing)
 Hardware is Unknown
 Internet address is xx.xx.xx.xx/27
 MTU 1500 bytes, BW 56 Kbit, DLY 20000 usec,
    reliability 255/255, txload 1/255, rxload 1/255
 Encapsulation PPP, loopback not set
 Keepalive set (10 sec)
 DTR is pulsed for 1 seconds on reset
 Interface is bound to Vi1
 Last input never, output never, output hang never
 Last clearing of "show interface" counters 1d00h
 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
 Queueing strategy: weighted fair
 Output queue: 0/1000/64/0 (size/max total/threshold/drops)
    Conversations  0/0/16 (active/max active/max total)
    Reserved Conversations 0/0 (allocated/max allocated)
    Available Bandwidth 42 kilobits/sec
 5 minute input rate 0 bits/sec, 0 packets/sec
 5 minute output rate 0 bits/sec, 0 packets/sec
    4163370 packets input, 77210658 bytes
    3263500 packets output, 348916567 bytes
Bound to:
Virtual-Access1 is up, line protocol is up
 Hardware is Virtual Access interface
 MTU 1500 bytes, BW 967 Kbit, DLY 20000 usec,
 Encapsulation PPP, LCP Open
 Open: IPCP
 PPPoE vaccess, cloned from Dialer0
 Vaccess status 0x44, loopback not set
 Interface is bound to Di0 (Encapsulation PPP)
 Last input 00:00:07, output never, output hang never
 Last clearing of "show interface" counters 00:21:09
 Queueing strategy: fifo
 Output queue: 0/40 (size/max)
    157 packets input, 3074 bytes, 0 no buffer
    Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
    0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
    158 packets output, 6320 bytes, 0 underruns
    0 output errors, 0 collisions, 0 interface resets
    0 output buffer failures, 0 output buffers swapped out
    0 carrier transitions
Hat jemand eine Idee woran das liegen kann?
Danke,
Felix
Ja.
Ja das log habe ich heraus kopiert als es nicht ging. Also gerade jetzt :(
Und wie gesagt, es geht eine Zeit lang, manchmal Tage und Wochen, und dann fällt es plötzlich aus?
Diese Woche ist es besonders schlimm, bisher jeden Tag einen Ausfall.
Aber Ping geht weiterhin, nur keine Websites!
Hallo Deepc,
hängen mit unserem 876w auch an einem T-COM Business Anschluss und nachdem wir eine feste IP beantragt haben, ging die Katastrophe los. Aus diesem Grunde authentifizieren wir auch mit pap und mit chap. Ich habe Dir mal die Settings unten angehängt. Ich glaube mich zu erinnern, daß es am Eintrag "no oam-pvc manage" unter ATM0.2 lag. Jedenfalls klappt das jetzt so ohne Probleme. Wünsch Dir viel Erfolg damit.
interface Dialer1
ip ddns update hostname Firmenname.dnsalias.com
ip ddns update sdm_ddns2
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname username
ppp chap password 0 passwort
ppp pap sent-username username password 0 passwort
interface ATM0
no ip address
ip mask-reply
no ip redirects
no ip unreachables
ip directed-broadcast
no ip proxy-arp
ip route-cache flow
interface ATM0.2 point-to-point
pvc 1/32
no oam-pvc manage
Greets eagle
es könnte aber auch an der firmware des atm interfaces liegen,..
(so als ideen noch). ich hatte zumindest mal so ein problem.
die infos findest du mit dem befehl:
sh dsl interface ATM 0
mit dieser version würd ich dann noch auf die suche gehen ob es hier
ähnliche fälle gibt wie du sie hast,
das update gibts auch ohne login von cisco unter:
ftp://ftp.cisco.com/pub/access/800/
hier auch noch eine config, ....
interface ATM0
description **** Provider T-Online ****
no ip address
no ip redirects
ip route-cache flow
no ip mroute-cache
atm vc-per-vp 64
bundle-enable
pvc 1/32
interface Dialer1
description **** WAN ****
ip access-group 110 in
no ip redirects
ip nat outside
encapsulation ppp
ip route-cache flow
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname XXXXXXXXXXXXXXX
ppp chap password XXXXXXXXXXXXXXXXX
ppp pap sent-username XXXXXXXXXXXXXXX password XXXXXXXXXXXXXX
Du solltest das mal genauer ueberwachen:
Client im Netz pingt einen DNS-Namen (z.b. Heise.de)
Client im Netz pingt IP (z.b. von Heise.de)
Client im Netz pingt interne Router IP
Client im Netz pingt externe Router IP
Router pingt einen DNS-Namen (z.b. Heise.de)
Router pingt IP (z.b. von Heise.de)
Die Ergebnisse waeren schon sehr aufschlussreich
@deepc
zuerst sorry bzgl dem vorletzten posting! hab mich da verhaut! ;-)
mir ist aufgefallen du hast die mtu size am dialer interface0 geändert!
nur mal als test stelle die mtu size auf 1500.
(ich hab in deutschland deinen 876 router stehen mit mtu 1500)
der funktioniert ohne probleme!
nur mal so als idee
