Probleme beim umbenennen von Gruppen im AD
Also für alle die es interessieren sollte. Hab's jetzt rausgefunden. Loginscript mit /f angepasst und alles funktioniert.
Group-membership information cache.
As both methods of retrieving the group-membership are relatively costly in terms of network traffic and process time the latest update of KiXtart caches the group-membership information in the registry. This means that once the cache is filled, subsequent runs of KIX32.EXE will require much less time to retrieve the group-membership information.
The group-membership cache is stored in the registry hive of the current user and contains security-identifier-to-groupname mappings. Changes to a user's group-membership are automatically handled by KiXtart during the next logon.
If an existing group is renamed, that change will not be visible to KiXtart until the next time the token-cache is refreshed.
The cache is automatically refreshed every 30 days.
A refresh of the cache can also be forced using the new '/f' commandline option:
KIX32 <yourscript> /f
Optionally, you can include a date, indicating how old the cache must be for it to be refreshed:
KIX32 <yourscript> /f:2001/12/31
The group-membership cache feature of KiXtart is only available on Windows NT or higher
