Joe 10 Geschrieben 30. März 2009 Melden Geschrieben 30. März 2009 Hallo zusammen, ich habe hier einen frisch aufgesetzten WSUS-Server, der leider einem Test-Client keine Updates liefern will. In WindowsUpdate.log steht am Ende: 2009-03-30 22:15:41:339 508 6d8 Setup *********** Setup: Checking whether self-update is required *********** [...] 2009-03-30 22:15:41:371 508 6d8 Setup * IsUpdateRequired = No 2009-03-30 22:15:41:527 508 6d8 PT +++++++++++ PT: Synchronizing server updates +++++++++++ 2009-03-30 22:15:41:527 508 6d8 PT + ServiceId = {3DA21691-E39D-4DA6-8A4B-B43877BCB1B7}, Server URL = http://UpdateServer/ClientWebService/client.asmx 2009-03-30 22:15:41:699 508 6d8 PT WARNING: Cached cookie has expired or new PID is available 2009-03-30 22:15:41:699 508 6d8 PT Initializing simple targeting cookie, clientId = eaa4b5b8-ea2b-42b1-9295-09547d56393c, target group = , DNS name = uma 2009-03-30 22:15:41:699 508 6d8 PT Server URL = http://UpdateServer/SimpleAuthWebService/SimpleAuth.asmx 2009-03-30 22:16:32:433 508 6d8 PT WARNING: Exceeded max server round trips: 0x80244010 2009-03-30 22:16:32:433 508 6d8 PT WARNING: Sync of Updates: 0x80244010 2009-03-30 22:16:32:433 508 6d8 PT WARNING: SyncServerUpdatesInternal failed: 0x80244010 2009-03-30 22:16:32:433 508 6d8 Agent * WARNING: Failed to synchronize, error = 0x80244010 2009-03-30 22:16:32:433 508 6d8 Agent * WARNING: Exit code = 0x80244010 2009-03-30 22:16:32:433 508 6d8 Agent ********* 2009-03-30 22:16:32:433 508 6d8 Agent ** END ** Agent: Finding updates [CallerId = AutomaticUpdates] 2009-03-30 22:16:32:433 508 6d8 Agent ************* 2009-03-30 22:16:32:433 508 6d8 Agent WARNING: WU client failed Searching for update with error 0x80244010 2009-03-30 22:16:32:449 508 9f4 AU >>## RESUMED ## AU: Search for updates [CallId = {971801A4-1A85-41A8-8163-8EEBF8C173D3}] 2009-03-30 22:16:32:449 508 9f4 AU # WARNING: Search callback failed, result = 0x80244010 2009-03-30 22:16:32:449 508 9f4 AU # WARNING: Failed to find updates with error code 80244010 2009-03-30 22:16:32:449 508 9f4 AU ######### 2009-03-30 22:16:32:449 508 9f4 AU ## END ## AU: Search for updates [CallId = {971801A4-1A85-41A8-8163-8EEBF8C173D3}] 2009-03-30 22:16:32:449 508 9f4 AU ############# 2009-03-30 22:16:32:449 508 9f4 AU AU setting next detection timeout to 2009-03-31 01:16:32 2009-03-30 22:16:37:433 508 6d8 Report REPORT EVENT: {C0322C84-D439-4335-8563-F30D57EA70E2} 2009-03-30 22:16:32:433+0200 1 148 101 {00000000-0000-0000-0000-000000000000} 0 80244010 AutomaticUpdates Failure Software Synchronization Windows Update Client failed to detect with error 0x80244010. Die Forum-Suche brachte das hier zu Tage: Link Das Neuregistrieren von msxml3.dll brachte keine Besserung. Löschen des SoftwareDistribution-Verzeichnisses half ebenfalls nichts. WSUS Client Diagnostic Tool läuft ohne Fehler durch. In der WSUS-Konsole erscheint der Rechner mit 19 notwendigen Updates. Hat jemand eine Idee, wo man noch ansetzen kann? Der Client wurde zuvor mit dem alten WSUS 2.0-Server ohne Probleme synchronisiert. Was hat es mit der Meldung "WARNING: Exceeded max server round trips: 0x80244010" auf sich? Gruss, Joe Zitieren
Sunny61 823 Geschrieben 31. März 2009 Melden Geschrieben 31. März 2009 Welches OS mit welchem Patch-Stand hat der Testclient? Sind auf dem WSUS auch diese Updates zum installieren freigegeben? http://www.wsus.de/images/WSUSUpdates.png Wenn nein, hol das bitte nach. Zitieren
