ISDN-Verbindung bricht sofort wieder ab
anbei die gewünschte info:
Dialer1 is up (spoofing), line protocol is up (spoofing)
Hardware is Unknown
Description: connected to Internet
Internet address will be negotiated using IPCP
MTU 1500 bytes, BW 56 Kbit, DLY 20000 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation PPP, loopback not set
DTR is pulsed for 1 seconds on reset
Last input never, output never, output hang never
Last clearing of "show interface" counters 00:01:58
Input queue: 0/75/0 (size/max/drops); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
0 packets input, 0 bytes
0 packets output, 0 bytes
00:22:35: ISDN BR0: Outgoing call id = 0x8008, dsl 0
00:22:35: ISDN BR0: Event: Call to 01929 at 64 Kb/s
habe den chap hostname auf ffm2 geändert da bei "gast" im debug ein unknown user auftaucht...
00:22:35: ISDN BR0: process_bri_call(): call id 0x8008, called_number 01929, spe
ed 64, call type DATA
00:22:150323896320: CC_CHAN_GetIdleChanbri: dsl 0
00:22:150323896320: Found idle channel B1
00:22:154625117316: ISDN BR0: received HOST_PROCEEDING call_id 0x8008
00:22:163208798208: ISDN BR0: received HOST_CONNECT call_id 0x8008
00:22:163208757260: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
00:22:163208757248: %DIALER-6-BIND: Interface BRI0:1 bound to profile Dialer1
00:22:163208757248: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 01929
00:22:163215051780: BR0:1 PPP: Treating connection as a callout
00:22:163210214760: BR0:1 PPP: Phase is ESTABLISHING, Active Open
00:22:163208757248: BR0:1 LCP: O CONFREQ [Closed] id 8 len 15
00:22:167503724543: BR0:1 LCP: AuthProto CHAP (0x0305C22305)
00:22:163208798208: BR0:1 LCP: MagicNumber 0xB0797554 (0x0506B0797554)
00:22:163215051932: ISDN BR0: Event: Connected to 01929 on B1 at 64 Kb/s
00:22:38: BR0:1 LCP: I CONFREQ [REQsent] id 41 len 25
00:22:38: BR0:1 LCP: AuthProto PAP (0x0304C023)
00:22:38: BR0:1 LCP: MagicNumber 0x5F7B6EF5 (0x05065F7B6EF5)
00:22:38: BR0:1 LCP: MRRU 1524 (0x110405F4)
00:22:38: BR0:1 LCP: EndpointDisc 1 Local (0x13070166666D32)
00:22:38: BR0:1 LCP: O CONFREJ [REQsent] id 41 len 15
00:22:38: BR0:1 LCP: I CONFACK [REQsent] id 8 len 15
00:22:38: BR0:1 LCP: AuthProto CHAP (0x0305C22305)
00:22:38: BR0:1 LCP: MagicNumber 0xB0797554 (0x0506B0797554)
00:22:38: BR0:1 LCP: I CONFREQ [ACKrcvd] id 42 len 14
00:22:38: BR0:1 LCP: O CONFNAK [ACKrcvd] id 42 len 9
00:22:38: BR0:1 LCP: I CONFREQ [ACKrcvd] id 43 len 15
00:22:38: BR0:1 LCP: O CONFACK [ACKrcvd] id 43 len 15
00:22:38: BR0:1 LCP: State is Open
00:22:38: BR0:1 PPP: Phase is AUTHENTICATING, by both
00:22:38: BR0:1 CHAP: Using alternate hostname ffm2
00:22:38: BR0:1 CHAP: O CHALLENGE id 13 len 25 from "ffm2"
00:22:38: BR0:1 CHAP: I CHALLENGE id 1 len 25 from "ffm2"
00:22:38: BR0:1 CHAP: Ignoring Challenge with local name
00:22:44: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 01929
00:22:48: BR0:1 CHAP: I CHALLENGE id 2 len 25 from "ffm2"
00:22:48: BR0:1 CHAP: Using alternate hostname ffm2
00:22:48: BR0:1 CHAP: Ignoring Challenge with local name
00:22:48: BR0:1 CHAP: O CHALLENGE id 14 len 25 from "ffm2"
00:22:58: BR0:1 CHAP: I CHALLENGE id 3 len 25 from "ffm2"
00:22:58: BR0:1 CHAP: Using alternate hostname ffm2
00:22:58: BR0:1 CHAP: Ignoring Challenge with local name
00:22:58: BR0:1 CHAP: O CHALLENGE id 15 len 25 from "ffm2"
00:23:08: BR0:1 CHAP: I CHALLENGE id 4 len 25 from "ffm2"
00:23:08: BR0:1 CHAP: Using alternate hostname ffm2
00:23:08: BR0:1 CHAP: Ignoring Challenge with local name
00:23:08: BR0:1 CHAP: O CHALLENGE id 16 len 25 from "ffm2"
00:45:50: ISDN BR0: Outgoing call id = 0x8012, dsl 0
00:45:50: ISDN BR0: Event: Call to 01929 at 64 Kb/s
00:45:50: ISDN BR0: process_bri_call(): call id 0x8012, called_number 01929, spe
00:45:214748405760: CC_CHAN_GetIdleChanbri: dsl 0
00:45:214748405760: Found idle channel B1
00:45:214749822312: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 91 changed
to up
00:45:214754659460: ISDN BR0: received HOST_PROCEEDING call_id 0x8012
00:45:223338340352: ISDN BR0: received HOST_CONNECT call_id 0x8012
00:45:223338299404: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
00:45:227633266688: %DIALER-6-BIND: Interface BRI0:1 bound to profile Dialer1
00:45:227633266688: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 01929
00:45:227639561220: BR0:1 PPP: Treating connection as a callout
00:45:227634724200: BR0:1 PPP: Phase is ESTABLISHING, Active Open
00:45:227633266688: BR0:1 LCP: O CONFREQ [Closed] id 14 len 15
00:45:231928233983: BR0:1 LCP: AuthProto CHAP (0x0305C22305)
00:45:227633307648: BR0:1 LCP: MagicNumber 0xB08EBCB7 (0x0506B08EBCB7)
00:45:227639561372: ISDN BR0: Event: Connected to 01929 on B1 at 64 Kb/s
00:45:53: BR0:1 LCP: I CONFREQ [REQsent] id 106 len 25
00:45:53: BR0:1 LCP: AuthProto PAP (0x0304C023)
00:45:53: BR0:1 LCP: MagicNumber 0x05EF39E0 (0x050605EF39E0)
00:45:53: BR0:1 LCP: MRRU 1524 (0x110405F4)
00:45:53: BR0:1 LCP: EndpointDisc 1 Local (0x13070166666D32)
00:45:53: BR0:1 LCP: O CONFREJ [REQsent] id 106 len 15
00:45:53: BR0:1 LCP: I CONFACK [REQsent] id 14 len 15
00:45:53: BR0:1 LCP: AuthProto CHAP (0x0305C22305)
00:45:53: BR0:1 LCP: MagicNumber 0xB08EBCB7 (0x0506B08EBCB7)
00:45:53: BR0:1 LCP: I CONFREQ [ACKrcvd] id 107 len 14
00:45:53: BR0:1 LCP: O CONFACK [ACKrcvd] id 107 len 14
00:45:53: BR0:1 LCP: State is Open
00:45:53: BR0:1 PPP: Phase is AUTHENTICATING, by both
00:45:53: BR0:1 CHAP: Using alternate hostname gast
00:45:53: BR0:1 CHAP: O CHALLENGE id 31 len 25 from "gast"
00:45:53: BR0:1 PAP: O AUTH-REQ id 1 len 14 from "gast"
00:45:53: BR0:1 PAP: I AUTH-ACK id 1 len 5
00:45:53: BR0:1 LCP: I TERMREQ [Open] id 108 len 4
00:45:53: BR0:1 LCP: O TERMACK [Open] id 108 len 4
00:45:53: BR0:1 PPP: Phase is TERMINATING
00:45:236223201279: ISDN BR0: received HOST_FACILITY_INVOKE call_id 0x8012
Cause i = 0x83AF - Resources unavailable, unspecified
00:45:231928274944: Facility i = 0x91A115020200CD020124300C300AA10530030
20100820100
00:45:231928274944: - ETSI Supplementary Service, Invoke, AOC-E Charging Uni
ts: 0
00:45:231934528644: ISDN BR0: received HOST_DISCONNECT call_id 0x8012
00:45:231928233984: ISDN BR0: Event: Call to <unknown> was hung up.
00:45:231934528516: ISDN BR0: process_disc_ack(): call id 0x8012, ces 1, call ty
pe DATA
00:45:236223201279: %LINK-3-UPDOWN: Interface BRI0:1, changed state to down
00:45:231928233984: BR0:1 LCP: State is Closed
00:45:231934528364: BR0:1 PPP: Phase is DOWN
00:45:231929691499: %DIALER-6-UNBIND: Interface BRI0:1 unbound from profile Dial
er1
00:45:231929682184: ISDN BR0: received HOST_DISCONNECT_ACK call_id 0x8012
00:45:231928233984: ISDN BR0: HOST_DISCONNECT_ACK: call type is DATA
da kommst du auch nicht sauber rein - er versucht zwar die aushandlung - aber dann "Phase is TERMINATING" - das war es - gehen deine Zugangsdaten mit einer ISDN Karte ?
Bist du dir mit CHAP da sicher - die meisten Provider machen nur PAP (ist halt der kleinste gemeinsame Nenner)
Im letzten Debug hast du den User "Gast" - davor "ffm2" - welcher ist deb Richtig ?
.... habs geschafft.
Welchen Sinn/Bedeutung hat dieses "callin" - ich mach ja eigentlich einen callout?
eigentlich wird bei der Authentisierung gegenseitig geprüft ob einander vertraut wird.
du wählst zwar raus (callout) aber die Authentisierung ist in Richtung callin.
Kurz: Das callin unterdrück die Überprüfung des Einwahlknoten auf dem Router.
Länger:
Der Router wählt sich mit Benutzername und Passwort ein. Dies Prüft der Einwahlknoten.
Lt Chap wird der Einwählende (Router) auch die Gegenseite prüfen. Der Username müsste mit "dialer remote-name <NAME>" auf dem Dialer konfiguriert sein. Das macht aber bei Interneteinwahl üblicherweise wenig Sinn da dies oft in Einwahlplattformen nicht Identisch konfiguriert ist.
Bei einer Punkt zu Punktverbindung zwischen Router und Router oder zur Fernwartung ist dies ein "Sicherheitsfeature"
