Workaholic4u 10 Geschrieben 25. Juni 2009 Melden Geschrieben 25. Juni 2009 Hallo, Kan mir jemand sagen, was eine Software Deployment Lösung so kostet? sowas wie Netinstall oder Matrix 42 ? oder gar SCCM? SCCM wird ja unheimlich gepusht von MS. (Mein Eindruck) aber was kostet eine SW Deployment Lösung geht das pro Client / pro SW Deployment Server? kann mir jemand der SCCM einsetzt die beweggründe dafür nennen? Zitieren
killtux 11 Geschrieben 25. Juni 2009 Melden Geschrieben 25. Juni 2009 Die Beweggründe liegen wohl auf der Hand - Management?..... ein paar auszüge davon: * Asset Intelligence Configuration Manager 2007 gives organizations better control over their IT infrastructure and assets through asset intelligence technologies that provide IT administrators continuous visibility into what hardware and software assets they have, who is using them, and where they are. * Software Update Management Configuration Manager 2007 Software Update Management simplifies the complex task of delivering and managing updates to IT systems across the enterprise. IT administrators can deliver updates of Microsoft products, third-party applications, custom in-house line-of-business applications, hardware drivers, and system BIOS to a variety of devices—including desktops, laptops, servers, and mobile devices. * Desired Configuration Management With Configuration Manager 2007 Desired Configuration Management, organizations can ensure that IT systems comply with desired configuration states to improve systems availability, security, and performance network-wide. * Software Distribution Microsoft System Center Configuration Manager 2007 Software Distribution simplifies the complex task of distributing applications and updates to desktops, servers, laptops, and mobile devices across enterprise networks. * Operating System Deployment Microsoft System Center Configuration Manager 2007 Operating System Deployment is a highly flexible, automated solution that allows IT administrators to fully deploy and configure servers and desktops from any previous state, including bare-metal deployments. http://www.microsoft.com/systemcenter/configurationmanager/en/us/default.aspx Preise hast du hier: System Center Configuration Manager: Pricing and Licensing Zitieren
goscho 11 Geschrieben 25. Juni 2009 Melden Geschrieben 25. Juni 2009 Hier ist eine Alternative: Funktionen - Altiris Client Management Suite | Symantec Zitieren
Squire 276 Geschrieben 26. Juni 2009 Melden Geschrieben 26. Juni 2009 Hi, bei Empirum (Matrix42) und den üblichen sonstigen Verdächtigen geht das i.d.R. nach Clientanzahl. Aus eigener Erfahrung - die Clientpreise die zuerst genannt werden sind als Verhandlungsbasis anzusehen. Bei uns ging da noch ne ganze Ecke vom genannten Preis weg und wir haben uns den Preis für die ersten 3 Jahre auch für Folgeclients festschreiben lassen :D Zitieren
