BiERWiESEL 10 Geschrieben 29. Juni 2009 Melden Teilen Geschrieben 29. Juni 2009 Huhu, habe ein riesen DNS Problem. Habe zwei Domänen und auf dem einen DC läuft DCDiag /test:dns richtig durch aber auf dem anderen nicht. Hier mal das Result: Testing server: DOM1/SRV Starting test: Connectivity ......................... SRV passed test Connectivity Doing primary tests Testing server: DOM1/SRV DNS Tests are running and not hung. Please wait a few minutes... Running partition tests on : DomainDnsZones Running partition tests on : **** Running partition tests on : ForestDnsZones Running partition tests on : Schema Running partition tests on : Configuration Running enterprise tests on : ***.*** Starting test: DNS Test results for domain controllers: DC: srv.***.*** Domain: ***.** TEST: Basic (Basc) Warning: adapter [00000007] Intel(R) PRO/1000 CT Network Connection has invalid DNS server: 192.168.2.10 (srv.***.***) Error: all DNS servers are invalid TEST: Forwarders/Root hints (Forw) Error: Root hints list has invalid root hint server: a.root-servers.net. (198.41.0.4) Error: Root hints list has invalid root hint server: b.root-servers.net. (192.228.79.201) Error: Root hints list has invalid root hint server: c.root-servers.net. (192.33.4.12) Error: Root hints list has invalid root hint server: d.root-servers.net. (128.8.10.90) Error: Root hints list has invalid root hint server: e.root-servers.net. (192.203.230.10) Error: Root hints list has invalid root hint server: f.root-servers.net. (192.5.5.241) Error: Root hints list has invalid root hint server: g.root-servers.net. (192.112.36.4) Error: Root hints list has invalid root hint server: h.root-servers.net. (128.63.2.53) Error: Root hints list has invalid root hint server: i.root-servers.net. (192.36.148.17) Error: Root hints list has invalid root hint server: j.root-servers.net. (192.58.128.30) Error: Root hints list has invalid root hint server: k.root-servers.net. (193.0.14.129) Error: Root hints list has invalid root hint server: l.root-servers.net. (198.32.64.12) Error: Root hints list has invalid root hint server: l.root-servers.net. (199.7.83.42) Error: Root hints list has invalid root hint server: m.root-servers.net. (202.12.27.33) TEST: Delegations (Del) Error: DNS server: srv.***.***. IP:** [broken delegated domain _msdcs.***.***] TEST: Dynamic update (Dyn) Warning: Dynamic update is enabled on the zone but not secure ***.*** TEST: Records registration (RReg) Error: Record registrations cannot be found for all the network adapters Summary of test results for DNS servers used by the above domain controllers: DNS server: *** (srv.***.***) 2 test failures on this DNS server Name resolution is not functional. _ldap._tcp.***.***. failed on the DNS server *** Delegation is broken for the domain _msdcs.***.*** on the DNS server **** Deshalb geht wohl auch die Vertrauenstellung usw. nicht. Die Zonen sind alle als AD Integriert angelegt und es sind keine Weiterleitungen eingerichtet. Bekomme auch immer den 7062 DNS Fehler. Würde mich freuen wenn ich paar tipps bekommen würde. Zitieren Link zu diesem Kommentar
BiERWiESEL 10 Geschrieben 29. Juni 2009 Autor Melden Teilen Geschrieben 29. Juni 2009 2. teil DNS server: 128.63.2.53 (h.root-servers.net.) 1 test failure on this DNS server Name resolution is not functional. _ldap._tcp.***.***. failed on the DNS server 128.63.2.53 DNS server: 128.8.10.90 (d.root-servers.net.) 1 test failure on this DNS server Name resolution is not functional. _ldap._tcp.***.***. failed on the DNS server 128.8.10.90 DNS server: 192.112.36.4 (g.root-servers.net.) 1 test failure on this DNS server Name resolution is not functional. _ldap._tcp.***.***. failed on the DNS server 192.112.36.4 DNS server: 192.203.230.10 (e.root-servers.net.) 1 test failure on this DNS server Name resolution is not functional. _ldap._tcp.***.***. failed on the DNS server 192.203.230.10 DNS server: 192.228.79.201 (b.root-servers.net.) 1 test failure on this DNS server Name resolution is not functional. _ldap._tcp.***.***. failed on the DNS server 192.228.79.201 DNS server: 192.33.4.12 (c.root-servers.net.) 1 test failure on this DNS server Name resolution is not functional. _ldap._tcp.***.***. failed on the DNS server 192.33.4.12 DNS server: 192.36.148.17 (i.root-servers.net.) 1 test failure on this DNS server Name resolution is not functional. _ldap._tcp.***.***. failed on the DNS server 192.36.148.17 DNS server: 192.5.5.241 (f.root-servers.net.) 1 test failure on this DNS server Name resolution is not functional. _ldap._tcp.***.***. failed on the DNS server 192.5.5.241 DNS server: 192.58.128.30 (j.root-servers.net.) 1 test failure on this DNS server Name resolution is not functional. _ldap._tcp.***.***. failed on the DNS server 192.58.128.30 DNS server: 193.0.14.129 (k.root-servers.net.) 1 test failure on this DNS server Name resolution is not functional. _ldap._tcp.***.***. failed on the DNS server 193.0.14.129 DNS server: 198.32.64.12 (l.root-servers.net.) 1 test failure on this DNS server This is not a valid DNS server. PTR record query for the 1.0.0.127.in-addr.arpa. failed on the DNS server 198.32.64.12 Name resolution is not functional. _ldap._tcp.***.***. failed on the DNS server 198.32.64.12 DNS server: 198.41.0.4 (a.root-servers.net.) 1 test failure on this DNS server Name resolution is not functional. _ldap._tcp.***.***. failed on the DNS server 198.41.0.4 DNS server: 199.7.83.42 (l.root-servers.net.) 1 test failure on this DNS server Name resolution is not functional. _ldap._tcp.***.***. failed on the DNS server 199.7.83.42 DNS server: 202.12.27.33 (m.root-servers.net.) 1 test failure on this DNS server Name resolution is not functional. _ldap._tcp.***.***. failed on the DNS server 202.12.27.33 Summary of DNS test results: Auth Basc Forw Del Dyn RReg Ext ________________________________________________________________ Domain: ***.*** srv PASS FAIL FAIL FAIL WARN FAIL n/a ......................... ***.*** failed test DNS Zitieren Link zu diesem Kommentar
Deejablo 10 Geschrieben 29. Juni 2009 Melden Teilen Geschrieben 29. Juni 2009 Poste mal bitte ein IPConfig/all des betreffenden DC Zitieren Link zu diesem Kommentar
zahni 562 Geschrieben 29. Juni 2009 Melden Teilen Geschrieben 29. Juni 2009 Welcher DNS-Server ist denn eingetragen ? Nicht etwas der von irgendeiner Fritzbox, oder so ? Auf "192.168.2.10" muss der MS-DNS Server Deiner Domäne laufen... -Zahni Zitieren Link zu diesem Kommentar
Necron 71 Geschrieben 29. Juni 2009 Melden Teilen Geschrieben 29. Juni 2009 Hi, schau auch mal hier nach: Event ID 7062 Source DNS Zitieren Link zu diesem Kommentar
BiERWiESEL 10 Geschrieben 29. Juni 2009 Autor Melden Teilen Geschrieben 29. Juni 2009 genau der 2.10er ist der DNS Zitieren Link zu diesem Kommentar
zahni 562 Geschrieben 29. Juni 2009 Melden Teilen Geschrieben 29. Juni 2009 Und der Server ist ein Windows 2000 oder höher DNS-Server ? Wenn ja, hat jemand die _msdcs bzw. _ldap Einträge gelöscht ? -Zahni Zitieren Link zu diesem Kommentar
BiERWiESEL 10 Geschrieben 29. Juni 2009 Autor Melden Teilen Geschrieben 29. Juni 2009 er ist ein 2003 server ja wir hatten einige probleme mit den zonen und da kann gut sein das jetzt was fehlen tut. Zitieren Link zu diesem Kommentar
zahni 562 Geschrieben 29. Juni 2009 Melden Teilen Geschrieben 29. Juni 2009 Hier steht Troubleshooting Common Active Directory Setup Issues in Windows 2000 wie Du die fehlenden Einträge reparieren kannst. -Zahni Zitieren Link zu diesem Kommentar
