Cisco 2611XM Adsl Problem
Hallo...
ich habe mir einen Router besorgt und komme nichmehr weiter..
Es ist ein 2611XM mit einer ADSL WIC over ISDN..
PVC 1/32 und 8/35 habe ich getestet..ohne erfolg...bekomme einfach keine IP über meinen Arcor Anschluss..
show run
Building configuration...
Current configuration : 1368 bytes
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface ATM0/1
description Arcor DSL
no ip address
no ip redirects
no ip unreachables
no atm ilmi-keepalive
dsl operating-mode auto
dsl enable-training-log
pvc 8/35
pppoe-client dial-pool-number 1
interface Dialer 1
mtu 1492
ip address negotiated
no ip redirects
no ip unreachables
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname 123456
ppp chap password 7 dgdfgh
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer 1
ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Router#show ip interface brief
Interface              IP-Address      OK? Method Status                Protocol
FastEthernet0/0      unassigned      YES NVRAM  administratively down down
ATM0/1                 unassigned      YES NVRAM  up                    up
FastEthernet0/1      unassigned      YES NVRAM  administratively down down
NVI0                     unassigned      NO  unset  up                    up
Dialer1                   unassigned      YES NVRAM  up                    up
Router#show interfaces atm 0/1
ATM0/1 is up, line protocol is up
 Hardware is DSLSAR (with Alcatel ADSL Module)
 Description: Arcor DSL _Modem_
 MTU 4470 bytes, sub MTU 4470, BW 736 Kbit/sec, DLY 690 usec,
    reliability 177/255, txload 1/255, rxload 1/255
 Encapsulation ATM, loopback not set
 Encapsulation(s): AAL5  AAL2, PVC mode
 23 maximum active VCs, 256 VCs per VP, 1 current VCCs
 VC Auto Creation Disabled.
 VC idle disconnect time: 300 seconds
Router#show dsl interface
ATM0/1
Alcatel 20166/20174 chipset information
               ATU-R (DS)                      ATU-C (US)
Modem Status:    Showtime (DMTDSL_SHOWTIME)
DSL Mode:        ITU G.992.1 (G.DMT) Annex B
ITU STD NUM:     0x01                            0x1
Vendor ID:       'ALCB'                          'BDCM'
Vendor Specific: 0x0000                          0x619D
Vendor Country:  0x00                            0xB5
Capacity Used:   90%                             86%
Noise Margin:     9.5 dB                         10.0 dB
Output Power:    13.0 dBm                        11.0 dBm
Attenuation:     11.0 dB                          7.0 dB
Defect Status:   None                            None
Last Fail Code:  None
Selftest Result: 0x00
Subfunction:     0xD0 (UR2)
Interrupts:      3895 (0 spurious)
PHY Access Err:  0
Activations:     1
LED Status:      ON
LED On Time:     100
LED Off Time:    100
Init FW:         embedded
Operation FW:    embedded
SW Version:      13.101
FW Version:      0xC166
                Interleave             Fast    Interleave              Fast
Speed (kbps):             0             6912             0               736
Cells:                    0                0             0           3380697
LOM Monitoring : Disabled
Please
Thx
Digi
Hi..
Ich habe schon etliche configs durch... ich brauche ne lösung in meine Config..
sorry aber das hilft mir so nicht weiter..Danke
evtl sieht es jemand auf anhieb..
Ich muss dazu sagen das ich relativer Anfänger mit Cisco Routern bin.
Vielen Dank
Digi
ob ein Soho oder ein 26er - die COnfig ist gleich - dort wird für Arcor auf jedenfall 1/32 verwendet - du kannst jetzt nur mit "Debug" anfangen - zu schauen wie weit du kommst - sprich PPPoE debuggen - Pap / Chap Debuggen. Was für nen DSL hast du - was für ein WIC ?
Hi...
DSL 16000 von Arcor und ein ADSL1 IDG (ADSL over ISDN)..aber daran wird es ja nicht liegen..
da
und
Cells: 0 0 0
sprich sync mit 6912....
mh...
Grüße
Digi
Folgende debugs sollten uns der Lösung näher bringen.
Erstmal nur:
debug pppoe packet
debug pppoe events
Du solltest dann sehen, ob du nur PPPoE Pakete sendest oder auch welche empfängst. Wenn du beides siehst, paßt der PVC.
Dann folgende Debugs, um die Authentifizierung zu überprüfen:
debug ppp authentication
debug ppp negotiation
Wenn du nicht klar kommst, poste mal die Debugs hier.
Hi...
leider passiert nix in der Ausgabe
Router#debug pppoe packet
PPPoE control packets debugging is on
Router#debug pppoe events
PPPoE protocol events debugging is on
Router#debug ppp authentication
PPP authentication debugging is on
Router#debug ppp negotiation
PPP protocol negotiation debugging is on
und dann ist es still
Grüße
Digi
aber gesynct hat es doch...siehe 1.Posting
habe nochmal etwas ergänzt...
und jetzt kommt etwas...
*Mar 1 02:42:39.557: IN PADS from PPPoE Session
*Mar 1 02:42:39.565: %DIALER-6-BIND: Interface Vi1 bound to profile Di1
*Mar 1 02:42:39.569: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Mar 1 02:42:41.680: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
*Mar 1 02:42:41.684: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
*Mar 1 02:42:41.861: PPPoE 1878: I PADT R:0030.8801.8fd0 L:000c.31ea.c321 1/32 ATM0/1
00 0C 31 EA C3 21 00 30 88 01 8F D0 88 63 11 A7
07 56 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ...
*Mar 1 02:43:01.889: PPPoE 0: I PADO R:0030.8801.8fd0 L:000c.31ea.c321 1/32 ATM0/1
00 0C 31 EA C3 21 00 30 88 01 8F D0 88 63 11 07
00 00 00 18 01 03 00 04 85 A2 B2 28 01 02 00 08 ...
*Mar 1 02:43:04.269: PPPoE 4145: I PADS R:0030.8801.8fd0 L:000c.31ea.c321 1/32 ATM0/1
00 0C 31 EA C3 21 00 30 88 01 8F D0 88 63 11 65
10 31 00 18 01 03 00 04 85 A2 B2 28 01 01 00 00 ...
