Probleme mit DHCP
Hi Folks,
Habe gestern versucht bei einem Freund den DHCP Server zum laufen zu bekommen. Ich pack´s nicht ....zweifle gerade an mir selbst :cry:
Anbei die config
Vielleicht hat ja einer von euch einen rettenden Einfall.
thx _xymos_
Cisco_2621#sh run
Building configuration...
Current configuration : 7093 bytes
! No configuration change since last restart
version 12.3
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Cisco_2621
boot-start-marker
boot-end-marker
no logging on
enable secret 5 xxx
enable password 7 xx
no aaa new-model
ip subnet-zero
no ip source-route
ip cef
ip domain name SSH
ip name-server 10.0.1.250
no ip dhcp conflict logging
ip dhcp excluded-address 10.0.1.250
ip dhcp pool testDHCP
network 10.0.0.0 255.255.255.0
dns-server 10.0.1.250
default-router 10.0.1.250 255.255.255.0
no ip bootp server
ip inspect max-incomplete high 3000
ip inspect max-incomplete low 2500
ip inspect one-minute high 3000
ip inspect one-minute low 2500
ip inspect tcp idle-time 1800
ip inspect tcp finwait-time 30
ip inspect tcp synwait-time 120
ip inspect tcp max-incomplete host 250 block-time 5
ip inspect name IDS-SYSTEM udp
ip inspect name IDS-SYSTEM tcp
ip inspect name IDS-SYSTEM h323
ip inspect name IDS-SYSTEM ftp
ip inspect name IDS-SYSTEM realaudio
ip inspect name IDS-SYSTEM rcmd
ip inspect name IDS-SYSTEM icmp
ip inspect name IDS-SYSTEM fragment maximum 256 timeout 1
ip inspect name IDS-SYSTEM smtp
ip inspect name IDS-SYSTEM tftp
ip inspect name IDS-SYSTEM rtsp
ip inspect name IDS-SYSTEM http
ip inspect name IDS-SYSTEM sip
ip audit attack action alarm drop reset
ip audit po max-events 100
ip audit protected 10.0.1.0
ip audit smtp spam 300
ip audit name IDS-SYSTEM info action alarm
ip audit name IDS-SYSTEM attack action alarm drop reset
ip audit name IDS attack action alarm drop reset
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
ip mtu adjust
username xxx privilege 15 password xxx
interface FastEthernet0/0
description ADSL_Gateway
no ip address
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
fair-queue
interface BRI0/0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet0/1
description LAN
ip address 10.0.1.250 255.255.255.0
ip access-group all_from_ethernet in
ip nat inside
ip inspect IDS-SYSTEM in
duplex auto
speed auto
interface Dialer1
description connected to WAN
bandwidth 6016
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
ip audit IDS-SYSTEM in
encapsulation ppp
ip route-cache flow
ip tcp adjust-mss 1452
no ip mroute-cache
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
fair-queue
no cdp enable
ppp chap hostname xxx
ppp chap password 7xxxx
ppp ipcp dns request
ip nat translation timeout 300
ip nat translation tcp-timeout 300
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static tcp 10.0.1.6 80 interface Dialer1 80
ip nat inside source static tcp 10.0.1.22 24039 interface Dialer1 24039
ip nat inside source static tcp 10.0.1.6 7777 interface Dialer1 10900
no ip http server
no ip http secure-server
ip classless
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 10.0.0.0 255.0.0.0 Null0
ip route 172.16.0.0 255.240.0.0 Null0
ip route 192.168.0.0 255.255.0.0 Null0
ip dns server
ip access-list standard all_from_ethernet
permit 10.0.1.0 0.0.0.255
ip access-list extended from_inet_some_allowed
permit udp any any eq domain
deny ip host 255.255.255.255 any log
deny ip 10.0.1.0 0.0.0.255 any log
permit udp host 130.149.17.8 eq ntp any eq ntp
permit tcp any eq 10900 any
permit tcp any any eq www
ip access-list extended telnet_from_LAN_SSH-from_inet
permit tcp 10.0.1.0 0.0.0.255 any range 22 telnet
access-list 1 permit 10.0.1.0 0.0.0.255
access-list 15 permit 10.0.1.6
dialer-list 1 protocol ip permit
snmp-server community public RO 15
snmp-server community private RO
snmp-server location xx
snmp-server contact xxx
snmp-server enable traps snmp authentication
snmp-server host 10.0.1.6 public
line con 0
line aux 0
line vty 0 4
session-timeout 60
access-class telnet_from_LAN_SSH-from_inet in
exec-timeout 20 0
privilege level 15
password xxx
session-limit 3
logging synchronous
login local
transport input telnet ssh
ntp clock-period 17180202
ntp source Dialer1
ntp master
ntp server 130.149.17.8
end
Hi
Ich glaub dein Fehler hier
network 10.0.0.0 255.255.255.0 // sollte glaub ich network 10.0.1.0/24 sein
probier mal dies zu ändern.
ansontn mal debug ip dhcp server
und schaun was er dir so rausspuckt.
mfg
onedread
