sebastian.f 10 Geschrieben 4. November 2009 Autor Melden Geschrieben 4. November 2009 Erstmal danke für die Hilfestellung, ich hab die Config jetzt nochmal angepasst und fahre nächste Woche wieder an den Standort. Kann bitte jemand kurz über die Config schauen und mir sagen ob das so passt? ! version 12.4 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname XXXXXXXXXX ! boot-start-marker boot-end-marker ! logging message-counter syslog enable secret 5 XXXXXXXXXXXXXXXX ! aaa new-model ! ! ! ! aaa session-id common ! crypto pki trustpoint TP-self-signed-2132275648 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-2132275648 revocation-check none rsakeypair TP-self-signed-2132275648 ! ! crypto pki certificate chain TP-self-signed-2132275648 certificate self-signed 01 quit dot11 syslog ! dot11 ssid XXXXXX authentication open authentication key-management wpa guest-mode wpa-psk ascii 7 XXXXXXX ! no ip source-route ip dhcp excluded-address 192.168.80.1 192.168.80.99 ip dhcp excluded-address 192.168.80.151 192.168.80.254 ! ip dhcp pool Pool1 network 192.168.80.0 255.255.255.0 domain-name XXXXXXXXX dns-server 217.237.151.97 217.237.151.161 default-router 192.168.80.1 ! ! ip cef no ip domain lookup ip domain name XXXXXXXXXX ! ! ! ! username admin privilege 15 password 7 XXXXXXXXXXX ! ! ! archive log config hidekeys ! ! ip ssh time-out 60 ip ssh authentication-retries 2 ! bridge irb ! ! interface BRI0 no ip address encapsulation hdlc shutdown ! interface ATM0 no ip address ip mask-reply ip directed-broadcast no atm ilmi-keepalive dsl operating-mode auto ! interface ATM0.1 point-to-point pvc 1/32 oam-pvc 0 pppoe-client dial-pool-number 1 ! ! interface FastEthernet0 description Netzwerkdrucker ! interface FastEthernet1 shutdown no cdp enable ! interface FastEthernet2 shutdown ! interface FastEthernet3 shutdown ! interface Dot11Radio0 no ip address ! encryption mode ciphers aes-ccm ! ssid XXXXXXX ! speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0 station-role root access-point bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 spanning-disabled bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding ! interface Vlan1 no ip address ip virtual-reassembly bridge-group 1 ! interface Dialer0 ip address negotiated ip mtu 1452 ip nat outside ip virtual-reassembly encapsulation ppp ip tcp adjust-mss 1452 no ip mroute-cache dialer pool 1 dialer-group 1 no cdp enable ppp authentication pap chap callin ppp chap refuse ppp pap sent-username feste-ip8/XXXXXXXXX@t-online-com.de password 7 XXXXXXXXXXXX ! interface BVI1 ip address 192.168.80.1 255.255.255.0 ! ip forward-protocol nd ip route 0.0.0.0 0.0.0.0 Dialer0 ip http server ip http access-class 23 ip http authentication local ip http secure-server ip http timeout-policy idle 60 life 86400 requests 10000 ! ip nat inside source list 1 interface Dialer0 overload ! dialer-list 1 protocol ip permit no cdp run ! ! ! ! control-plane ! bridge 1 protocol ieee bridge 1 route ip ! line con 0 no modem enable line aux 0 line vty 0 4 password 7 XXXXXXXXXX transport input ssh ! scheduler max-task-time 5000 end Vielen Dank Zitieren
Servidge 10 Geschrieben 4. November 2009 Melden Geschrieben 4. November 2009 An der Konfig gibt es auf den ersten Blick noch Verbesserungspotenzial. beim dialer0 steht "ppp authentication pap chap callin" danach steht aber chap refuse. Sollte also ein "ppp authentication pap callin" sein. oder wie im Beispiel von michael01 beides angeben. Der ip http server ist mit accesslist 23 gesichert. die existiert aber nicht in der Konfig. Wenn der http/https Zugriff nicht benötigt wird den halt mit "no" herunter konfigurieren. die vtys sind nicht mit mit einer acl abgesichert. Sollte noch hinzugefügt werden wenn dann der Router in Betrieb ist. Das mit dem "ip nat inside source list 1 interface Dialer0 overload" wird auch nicht funktionieren. Nutze anstelle der Dialer-list 1 eine passende Accesslist mit dem zu nattenden Netz. Zitieren
