Kernel Stack Inpage Error - kann jemand was aus Minidump rauslesen?
Moin,
heute morgen hat mich mein PC mit einem Bluescreen geweckt - habe daraufhin den Minidump ausgelesen und folgendes angezeigt bekommen:
Kann jemand was daraus ablesen - hatte jemand was ähnliches und was soll ich am besten tun?
se !analyze -v to get detailed debugging information.
BugCheck 77, {1, 0, 0, b216c960}
Probably caused by : memory_corruption ( nt!MmInPageKernelStack+176 )
Followup: MachineOwner
1: kd> !analyze -v
* Bugcheck Analysis *
KERNEL_STACK_INPAGE_ERROR (77)
The requested page of kernel data could not be read in. Caused by
bad block in paging file or disk controller error.
In the case when the first arguments is 0 or 1, the stack signature
in the kernel stack was not found. Again, bad hardware.
An I/O status of c000009c (STATUS_DEVICE_DATA_ERROR) or
C000016AL (STATUS_DISK_OPERATION_FAILED) normally indicates
the data could not be read from the disk due to a bad
block. Upon reboot autocheck will run and attempt to map out the bad
sector. If the status is C0000185 (STATUS_IO_DEVICE_ERROR) and the paging
file is on a SCSI disk device, then the cabling and termination should be
checked. See the knowledge base article on SCSI termination.
Arguments:
Arg1: 00000001, (page was retrieved from disk)
Arg2: 00000000, value found in stack where signature should be
Arg3: 00000000, 0
Arg4: b216c960, address of signature on kernel stack
Debugging Details:
ERROR_CODE: (NTSTATUS) 0x1 - STATUS_WAIT_1
BUGCHECK_STR: 0x77_1
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: DRIVER_FAULT
PROCESS_NAME: System
LAST_CONTROL_TRANSFER: from 80512e28 to 804f9f43
STACK_TEXT:
ba52fd58 80512e28 00000077 00000001 00000000 nt!KeBugCheckEx+0x1b
ba52fd8c 8053fd86 0017b4e8 00000000 8ad2c638 nt!MmInPageKernelStack+0x176
ba52fda4 80540256 8a17b548 805cff72 00000000 nt!KiInSwapKernelStacks+0x16
ba52fdac 805cff72 00000000 00000000 00000000 nt!KeSwapProcessOrStack+0x7c
ba52fddc 805460ee 805401da 00000000 00000000 nt!PspSystemThreadStartup+0x34
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x16
STACK_COMMAND: kb
FOLLOWUP_IP:
80512e28 8a550b mov dl,byte ptr [ebp+0Bh]
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nt!MmInPageKernelStack+176
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4a784394
IMAGE_NAME: memory_corruption
FAILURE_BUCKET_ID: 0x77_1_nt!MmInPageKernelStack+176
DANKE und Gruß
Tobias
