maccros 10 Geschrieben 4. Januar 2010 Melden Geschrieben 4. Januar 2010 hallo zusammen Auf einem Cisco 876 kann die DSL-Verbindung nich aufgebuat werden. Hat dieses Problem schon jemand gesehen? Hat das mit der Leitung zu tun? debug atm events 000046: *Sep 1 03:29:18.860 PCTime: DSL(ATM0): 1: Modem state = 0x9 000047: *Sep 1 03:29:21.360 PCTime: DSL(ATM0): 2: Modem state = 0x9 000048: *Sep 1 03:29:23.859 PCTime: DSL(ATM0): 3: Modem state = 0x10 000049: *Sep 1 03:29:26.359 PCTime: DSL(ATM0): 4: Modem state = 0x10 000050: *Sep 1 03:29:28.866 PCTime: DSL(ATM0): 5: Modem state = 0x10 000051: *Sep 1 03:29:30.946 PCTime: DSL(ATM0): Received response: 0x22 000052: *Sep 1 03:29:30.946 PCTime: DSL(ATM0): Open failed: Req. min. rate + noise margin + PSD not possible on the line -- retrying 000053: *Sep 1 03:29:30.946 PCTime: DSL(ATM0): sleep 5 seconds 000054: *Sep 1 03:29:35.945 PCTime: DSL(ATM0): Send ADSL_OPEN command. 000055: *Sep 1 03:29:35.945 PCTime: DSL(ATM0): Using preferred open mode 000056: *Sep 1 03:29:35.945 PCTime: DSL(ATM0): Using ITU sync first for 5 secs, then ANSI/ITU sync alternatively for 2 secs 000057: *Sep 1 03:29:35.945 PCTime: DSL(ATM0): Using subfunction 0x0 000058: *Sep 1 03:29:35.945 PCTime: LOCAL:Max noise margin for power cutoff 31 000059: *Sep 1 03:29:35.945 PCTime: DSL(ATM0): GPCI[0] 0xA 000060: *Sep 1 03:29:35.945 PCTime: DSL(ATM0): GPCI[1] 0x2 000061: *Sep 1 03:29:35.945 PCTime: DSL(ATM0): GPCI[2] 0x2 000062: *Sep 1 03:29:35.945 PCTime: DSL(ATM0): GPCI[3] 0x0 000063: *Sep 1 03:29:35.945 PCTime: DSL(ATM0): Sent extended command 0x3 usw... Config interface ATM0 no ip address no ip redirects no ip unreachables no ip proxy-arp ip route-cache flow no atm ilmi-keepalive dsl operating-mode auto ! interface ATM0.1 point-to-point description Internet$FW_OUTSIDE$$ES_WAN$ pvc 8/35 pppoe-client dial-pool-number 1 ! ! interface Dialer0 description $FW_OUTSIDE$ ip address negotiated ip access-group 100 in no ip redirects no ip unreachables no ip proxy-arp ip mtu 1452 ip nat outside ip virtual-reassembly encapsulation ppp ip route-cache flow dialer pool 1 dialer-group 1 no cdp enable ppp authentication chap callin ppp chap hostname xxxxxxxxxxxx ppp chap password 0 xxxxxxxxxxx crypto map cagCMAP1 Gruess, maccros Zitieren
Wordo 11 Geschrieben 4. Januar 2010 Melden Geschrieben 4. Januar 2010 deb atm er deb atm ev deb pppoe er deb pppoe ev Zitieren
Servidge 10 Geschrieben 5. Januar 2010 Melden Geschrieben 5. Januar 2010 Mit welchem IOS bzw. wichtiger welcher DSL Firmware Version versuchst du dein Glück? Funktioniert an dem Anschluss denn ein anderes Modem? Zitieren
maccros 10 Geschrieben 5. Januar 2010 Autor Melden Geschrieben 5. Januar 2010 Anbei die Versionsangaben, die deb's haben nicht mehr als das oben gepostete ergeben... Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(15)T7, RELEASE SOFTWARE (fc3) ATM0 Alcatel 20190 chipset information Line not activated: displaying cached data from last activation ATU-R (DS) ATU-C (US) Modem Status: Showtime (DMTDSL_DO_OPEN) DSL Mode: ITU G.992.1 (G.DMT) Annex B ITU STD NUM: 0x03 0x1 Vendor ID: 'STMI' 'ALCB' Vendor Specific: 0x0000 0x0000 Vendor Country: 0x0F 0x0F Chip ID: C196 (0) DFE BOM: DFE3.0 Annex B (2) Capacity Used: 69% 96% Noise Margin: 15.0 dB 9.0 dB Output Power: 19.5 dBm 11.5 dBm Attenuation: 25.0 dB 16.0 dB Defect Status: None None Last Fail Code: None Watchdog Counter: 0x26 Watchdog Resets: 0 Selftest Result: 0x00 Subfunction: 0x00 (non-UR2) Interrupts: 124257 (0 spurious) PHY Access Err: 0 Activations: 1 LED Status: OFF LED On Time: 100 LED Off Time: 100 Init FW: init_AMR-3.0.014_no_bist.bin Operation FW: AMR-3.0.014.bin FW Source: embedded FW Version: 3.0.14 Zitieren
Wordo 11 Geschrieben 5. Januar 2010 Melden Geschrieben 5. Januar 2010 Von welchem Anbieter isn die Leitung? Zitieren
maccros 10 Geschrieben 5. Januar 2010 Autor Melden Geschrieben 5. Januar 2010 Swisscom (Bluewin). An einem anderen Standort funktioniert der Router mit derselben Konfiguration (So sind schon mindestens 50 Stk. im Einsatz). Ich weiss nicht mehr wo ich noch suchen soll, von Seiten Provider soll alles in bester Ordnung sein... Zitieren
Wordo 11 Geschrieben 5. Januar 2010 Melden Geschrieben 5. Januar 2010 Hast du die Moeglichkeit ein externes Modem anzuschliessen? Zitieren
maccros 10 Geschrieben 5. Januar 2010 Autor Melden Geschrieben 5. Januar 2010 Haben wir schon Versucht (Zyxel). Hat zuerst auch nicht geklappt, und später war plötzlich verbindung da... Zitieren
Servidge 10 Geschrieben 5. Januar 2010 Melden Geschrieben 5. Januar 2010 Das mit dem plötzlich da, sprich wenn es länger dauert als üblich läßt ja auf eine nicht ganz so optimale Leitung schließen. Andererseits da keine dedizierte DSL Firmware beim 876 verwendet wird und die embedded ja auch schon etwas älter ist könnte mal eine aktuelle verwendet werden. Die aktuelleren haben so einige Fehler im Zusammenspiel mit unterschiedlichen DSLAMS beseitgt. Wobei ich jetzt auch nicht sagen kann welche für das Netz von Swisscom (Bluewin) passt. Vielleicht kann der Netzanbieter da weiterhelfen, die Readmes zu den Versionen lesen oder einfach die letzten Versionen ausprobieren. Einfach mal bei cisco nach adsl_alc_20190.bin suchen. Bei mir an einem ADSL2+ Anschluss der Telekom lief eine 4.0.15 problemlos. Zitieren
Windowsbetatest 10 Geschrieben 5. Januar 2010 Melden Geschrieben 5. Januar 2010 Hallo, die vierer FW für das ADSL Modem hat bei vielen Router das Sync Verhalten stark verbessert (teilweise knapp 15% mehr Datenrate). In den 12.4(24)T1 und 15.0(1)M1 IOS Versionen ist diese FW gleich drin, probiere die doch mal aus. mfg Zitieren
daking 10 Geschrieben 7. Januar 2010 Melden Geschrieben 7. Januar 2010 Hallo, schon mal auf die Idee gekommen, dass die Provider Leitung einfach suboptimal ist und gefixt werden muss? Wenn es bei 50 Komponenten funzt und hier nicht - dann wird es wohl eher der provider sein - also hier Case + escalation. Open failed: Req. min. rate + noise margin LOCAL:Max noise margin for power cutoff 31 ==> no showtime @ adsl Der Provider "muss" hier einheitliche (es soll funzen) Qualität liefern - sonst wird bei jedem Problem eine andere Firmware verwendet und irgendwas optimiert. Dies sollte die Betreibarkeit des Netzwerkes aus Kundensicht nicht gerade optimieren.. cheers Zitieren
maccros 10 Geschrieben 12. Januar 2010 Autor Melden Geschrieben 12. Januar 2010 Inzwischen habe ich die 12.4(24)T2 eingespielt. Auch dies ohne Erfolg! "Das Teil nervt langsam :(" Ich werde mich nächste Woche mit einem Techniker des Netzbetreibers vor Ort treffen um das Problem gemeinsam anzugehen... Bis hierhin auf jeden Fall besten Dank für die Tips! Zitieren
