ShineDaStar 10 Geschrieben 10. Januar 2010 Melden Geschrieben 10. Januar 2010 Hallo liebe Forengemeinde, ich habe nun einige Zeit damit zugebracht, meinen router ( cisco 892 ) etwas zu konfigurieren... Nun würde ich gerne Wissen, ob man die konfig in anbetracht von Sicherheit und Funktionalität auch so bedenkenlos verwenden kann, bzw. was verbessern könnte. Erstmal die konfig: Building configuration... % String too long to write to nvram (2147): Current configuration : 14757 bytes ! ! Last configuration change at 19:46:35 CET Sun Jan 10 2010 by Tobias ! NVRAM config last updated at 23:54:58 CET Sat Jan 9 2010 by Tobias ! version 12.4 no service pad service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec localtime show-timezone service timestamps log datetime msec localtime show-timezone service password-encryption service linenumber service sequence-numbers ! hostname router ! boot-start-marker boot-end-marker ! security passwords min-length 6 logging count logging message-counter syslog logging userinfo logging buffered 102400 logging console critical enable secret 5 . enable password 7 ! aaa new-model ! ! aaa authentication login default local aaa authorization exec default local ! ! aaa session-id common clock timezone CET 1 clock summer-time CEST recurring last Sun Mar 2:00 last Sun Oct 3:00 clock calendar-valid cef table consistency-check IPv4 auto-repair delay 15 cef table rate-monitor-period 10 ! crypto pki trustpoint TP-self-signed-3284086038 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate- revocation-check none rsakeypair TP-self-signed- ! ! crypto pki certificate chain TP-self-signed-3284086038 certificate self-signed 01 3 quit ip source-route ip arp gratuitous local ip arp incomplete retry 10 ip arp incomplete entries 2048 ip icmp rate-limit unreachable 10 ip icmp rate-limit unreachable DF 1 ! ! ip dhcp excluded-address 192.168.2.1 ip dhcp excluded-address 192.168.2.29 192.168.2.254 ip dhcp excluded-address 192.168.10.1 ip dhcp excluded-address 192.168.10.5 192.168.10.254 ip dhcp excluded-address 192.168.11.1 ip dhcp excluded-address 192.168.11.10 192.168.11.254 ip dhcp excluded-address 192.168.12.1 ip dhcp excluded-address 192.168.12.2 ip dhcp excluded-address 192.168.12.3 192.168.12.9 ip dhcp excluded-address 192.168.12.36 192.168.12.254 ip dhcp excluded-address 192.168.8.1 ! ip dhcp pool ASA host 192.168.8.2 255.255.255.0 client-identifier 0100.23eb.abbe.91 client-name TKGNASA01LTB01 domain-name painlan.local dns-server 192.168.8.1 default-router 192.168.8.1 lease infinite ! ip dhcp pool UC520 host 192.168.11.2 255.255.255.0 client-identifier 0100.270d.5d84.a0 default-router 192.168.2.1 dns-server 192.168.2.1 domain-name painlan.local client-name TKGNVPU01LTB01 lease infinite ! ip dhcp pool IPTV-Clients import all network 192.168.10.0 255.255.255.0 default-router 192.168.10.1 dns-server 192.168.10.1 lease 7 ! ip dhcp pool VoIP_Network import all network 192.168.11.0 255.255.255.0 dns-server 192.168.11.1 default-router 192.168.11.1 lease 7 ! ip dhcp pool Perimeter_Zone import all network 192.168.12.0 255.255.255.0 default-router 192.168.12.1 dns-server 192.168.12.1 lease 5 ! ip dhcp pool Lan2WAN.Interconnect import all network 192.168.8.0 255.255.255.0 default-router 192.168.8.1 dns-server 192.168.8.1 ! ! Zitieren
ShineDaStar 10 Geschrieben 10. Januar 2010 Autor Melden Geschrieben 10. Januar 2010 ip cef ip domain retry 1 ip domain timeout 1 ip domain name routernet.local ip multicast-routing ip multicast cache-headers ip inspect log drop-pkt ip inspect L2-transparent dhcp-passthrough ip inspect max-incomplete high 4000 ip inspect max-incomplete low 2000 ip inspect one-minute high 40000 ip inspect one-minute low 40000 ip inspect udp idle-time 86400 ip inspect hashtable-size 4096 ip inspect dns-timeout 2 ip inspect tcp finwait-time 30 ip inspect tcp block-non-session ip inspect tcp reassembly timeout 120 ip dhcp-client forcerenew no ipv6 cef ! ! multilink bundle-name authenticated isdn switch-type basic-net3 ! ! username Tobias privilege 15 password 7 secure boot-config ! ! ! archive log config hidekeys ! ! ip tcp synwait-time 10 ip ssh port 2367 rotary 1 ip ssh version 2 ! class-map match-any Forbitten-Tasks match protocol kazaa2 match protocol bittorrent match protocol edonkey match protocol gnutella ! ! policy-map mark-forbitten-tasks class Forbitten-Tasks set ip dscp 1 ! ! ! ! interface BRI0 description ISDN Management and Backup interface no ip address encapsulation ppp shutdown isdn switch-type basic-net3 isdn termination multidrop isdn point-to-point-setup ! interface FastEthernet0 description MediaReceiver_1 switchport access vlan 2 spanning-tree portfast ! interface FastEthernet1 description MediaReceiver_2 switchport access vlan 2 spanning-tree portfast ! interface FastEthernet2 description empty shutdown ! interface FastEthernet3 description empty shutdown ! interface FastEthernet4 description Uplink to ASA for internal switchport access vlan 100 switchport protected ! interface FastEthernet5 description uplink to Perimeter Switch switchport access vlan 4 switchport protected ! interface FastEthernet6 description Uplink to UC520 PBX System switchport access vlan 3 switchport protected spanning-tree portfast ! interface FastEthernet7 description empty shutdown ! interface FastEthernet8 description Management Interface ip address 192.90.60.90 255.255.255.0 shutdown duplex auto speed auto ! interface GigabitEthernet0 description Host of Vif and Admin Connection to CPE ip address dhcp ip nat outside ip nat enable ip virtual-reassembly duplex auto speed auto ! interface GigabitEthernet0.7 description BoundIFace4Dialer1 encapsulation dot1Q 7 pppoe enable group 1 pppoe-client dial-pool-number 1 no cdp enable ! interface GigabitEthernet0.8 description IPTV-Network T-Home interconnect encapsulation dot1Q 8 ip address dhcp ip access-group IPTV in ip information-reply ip directed-broadcast ip pim sparse-mode ip nat outside ip virtual-reassembly ip igmp version 3 ip igmp mroute-proxy Vlan2 keepalive 1 no cdp enable ! Zitieren
ShineDaStar 10 Geschrieben 10. Januar 2010 Autor Melden Geschrieben 10. Januar 2010 interface Vlan1 description Internal Management Host allocation ip address 192.168.2.1 255.255.255.0 ip nat inside ip virtual-reassembly timeout absolute 1440 0 fair-queue ! interface Vlan2 description IPTV virtual access ip address 192.168.10.1 255.255.255.0 ip pim sparse-mode ip nat inside ip virtual-reassembly ip igmp helper-address 79.249.159.254 ip igmp version 3 ip igmp explicit-tracking ip igmp query-interval 15 ip igmp proxy-service ! interface Vlan3 description PBX VoIP System Interconnect bandwidth 2000 ip address 192.168.11.1 255.255.255.0 ip nat inside ip virtual-reassembly ! interface Vlan4 description Perimeter Network ip address 192.168.12.1 255.255.255.0 ip nat inside ip virtual-reassembly delay 10 ! interface Vlan100 description Hostlink to ASA Secured Net ip address 192.168.8.1 255.255.255.0 ip nat inside ip virtual-reassembly delay 2 ! interface Dialer1 description Dialer for Dialin VDSL$FW_OUTSIDE$ ip address negotiated ip access-group PUBLIC-VDSL in ip access-group 185 out ip mtu 1492 ip nat outside ip virtual-reassembly encapsulation ppp ip tcp adjust-mss 1452 dialer pool 1 dialer idle-timeout 0 dialer persistent keepalive 1 no cdp enable ppp authentication pap callin ppp pap sent-username MeineKennung#0001@t-online.de password 7 MeinPw service-policy input mark-forbitten-tasks ! ip forward-protocol nd ip route profile ip route 0.0.0.0 0.0.0.0 Dialer1 ip route 87.140.255.0 255.255.255.128 MeineIP ip route 87.141.128.0 255.255.128.0 MeineIP ip route 193.158.34.0 255.255.254.0 MeineIP ip route 194.25.134.197 255.255.255.255 MeineIP ip route 194.25.237.4 255.255.255.255 MeineIP ip route 217.6.164.40 255.255.255.254 MeineIP ip route 217.6.164.42 255.255.255.255 MeineIP ip route 217.6.164.45 255.255.255.255 MeineIP ip route 217.6.164.46 255.255.255.254 MeineIP ip route 217.6.164.48 255.255.255.248 MeineIP ip route 217.6.167.128 255.255.255.192 MeineIP no ip http server ip http authentication local no ip http secure-server ! ! ip dns view default logging domain timeout 1 domain retry 1 dns forwarder 8.8.8.8 dns forwarder 208.67.220.220 dns forwarder 192.58.128.30 dns forwarder 193.0.14.129 dns forwarder 199.7.83.42 dns forwarder 192.33.4.12 ip dns server ip pim rp-address 79.249.159.254 ip nat translation tcp-timeout 3600 ip nat translation udp-timeout 3600 ip nat inside source route-map check->NAT interface Dialer1 overload ip nat inside source route-map check->NAT->IIPTV interface Dialer1 overload ip nat inside source route-map check->NAT->IPTV interface GigabitEthernet0.8 overload ! ip access-list standard Administrationsteam@deluxemails.com ip access-list standard Rack_UG_Slot1 ! ip access-list extended IPTV permit tcp any any established permit udp any eq bootps any eq bootpc permit udp any any gt 1024 permit udp host 193.158.35.31 any permit ip any 224.0.0.0 15.255.255.255 permit pim host 79.249.159.254 any permit igmp host 79.249.159.254 any permit icmp host 79.249.159.254 any deny ip any any log-input remark grand access list IPTV Network ip access-list extended PUBLIC-VDSL permit udp any eq domain any permit udp any any eq 5060 permit udp any any gt 1024 permit tcp any any eq 1723 permit udp any any eq 1701 permit udp any any eq non500-isakmp permit udp any any eq isakmp permit tcp any any eq 3483 permit tcp any any eq 9000 permit icmp any any echo-reply permit tcp any any established remark Access list for internet access permit udp host 192.53.103.104 eq ntp any permit udp host 192.53.103.108 eq ntp any permit udp host 195.145.119.188 eq ntp any deny ip any any log-input ! kron occurrence Reset-PPPoE at 5:00 recurring policy-list Reset-PPPoE ! kron policy-list Reset-PPPoE cli clear interface Dialer 1 ! Zitieren
ShineDaStar 10 Geschrieben 10. Januar 2010 Autor Melden Geschrieben 10. Januar 2010 logging history size 300 access-list 110 remark Management-Vlan access-list 110 permit ip 192.168.2.0 0.0.0.255 any access-list 120 remark Interlan.private.interconnect access-list 120 permit ip 192.168.8.0 0.0.0.255 any access-list 124 permit ip 192.168.10.0 0.0.0.255 any access-list 124 remark IPTV.Multicast.Access access-list 125 permit ip 192.168.10.0 0.0.0.255 any access-list 125 remark IPTV.Dialer1.Access access-list 126 remark VoIP-Network access-list 126 permit ip 192.168.11.0 0.0.0.255 any access-list 127 remark perimeter-net access-list 127 permit ip 192.168.12.0 0.0.0.255 any access-list 185 deny ip any any dscp 1 access-list 185 permit ip any any dialer-list 1 protocol ip permit priority-list 1 protocol ip high list 126 priority-list 1 queue-limit 4096 2048 1024 512 priority-list 2 interface Vlan100 medium priority-list 2 protocol ip high list 124 priority-list 2 protocol ip high list 125 priority-list 2 queue-limit 4096 2048 1024 512 priority-list 3 protocol ip high udp domain priority-list 3 queue-limit 4096 2048 1024 512 priority-list 4 interface Vlan100 medium priority-list 4 queue-limit 4096 2048 1024 512 priority-list 5 protocol ip medium tcp 441 priority-list 5 protocol ip medium tcp www priority-list 5 protocol ip medium tcp 143 priority-list 5 protocol ip medium tcp 993 priority-list 5 protocol ip medium tcp smtp priority-list 5 protocol ip medium tcp 465 priority-list 5 protocol ip medium tcp pop3 priority-list 5 protocol ip medium tcp 995 priority-list 5 protocol ip high tcp 37 priority-list 5 protocol ip high tcp 443 priority-list 5 protocol ip high udp 443 priority-list 5 queue-limit 4096 2048 1024 512 priority-list 6 protocol ip normal priority-list 6 queue-limit 4096 2048 1024 512 snmp-server community sicherheitRW snmp-server community viewlineRO snmp-server community location RO Rack_UG_Slot1 snmp-server community contact RO meine@me.com snmp-server trap-source Vlan1 snmp-server source-interface informs Vlan1 snmp-server location Serverraum U1 snmp-server contact meine@me.com snmp-server chassis-id Router snmp-server enable traps syslog snmp-server host 192.168.0.5 MeViewNet snmp-server host 192.168.0.5 MeAdminNet mac-address-table aging-time 3600 no cdp run ! ! ! ! route-map check->NAT->IPTV permit 10 match ip address 124 match interface GigabitEthernet0.8 ! route-map check->NAT permit 15 match ip address 126 match interface Dialer1 ! route-map check->NAT permit 20 match ip address 120 match interface Dialer1 ! route-map check->NAT permit 25 match ip address 127 match interface Dialer1 ! route-map check->NAT->IIPTV permit 10 match ip address 125 match interface Dialer1 ! ! ! control-plane host management-interface BRI0 allow ssh management-interface FastEthernet8 allow ftp http https ssh tftp snmp beep telnet tl1 management-interface Vlan1 allow ssh snmp management-interface Vlan100 allow ssh snmp ! ! control-plane ! banner exec ^CCC ADMINISTRATION ONLY!!!! All abuse will be logged and procecuded! No trasspassing beyond this point for unauthorized personal! ^C banner login ^C ___,------, ^C banner motd ^C Admin Conta^C ! line con 0 transport output telnet line aux 0 transport output telnet line vty 0 4 password 7 meinpw transport input ssh ! scheduler max-task-time 5000 scheduler allocate 4000 1000 scheduler interval 500 ntp update-calendar ntp server 195.145.119.188 prefer source Dialer1 ntp server 192.53.103.104 maxpoll 16 minpoll 8 prefer source Dialer1 burst iburst ntp server 192.53.103.108 source Dialer1 end Zitieren
ShineDaStar 10 Geschrieben 10. Januar 2010 Autor Melden Geschrieben 10. Januar 2010 (bearbeitet) Nun sollte die Config folgendes können: - Interface FastEthernet 8 ( ein WAN Interface ) soll als reines admin Zugang verwendet werden, so dass man es hinter der asa ins interne netz stecken kann, ohne sicherheitsbedenken - IPTV priorisieren - hier hängt öfters mal der stream, bzw. ton geht weiter, Bild freezed und es gibt starke artefaktbildung, Grobpixelung, dann geht es erst weiter. - Standard Firewall Inspection durchführen - VoIP Priorisieren - vom Gigabitethernet 0 sollte man das Modem erreichen können, das liegt im konfigurierten subnet, ich kann aber leider nicht drauf zugreifen, das sollte aber gehen - Über BRI sollte man sich via einer Telefonnummer zur Fernkonfig verbinden können Danke schonmal für eure hilfe. Ich versuche mir die Cisco Technik selbst beizubringen und wollte mir mal Rat von den experten und tipps zur Lösung selbiger einholen. Danke schonmal im Voraus.:) bearbeitet 10. Januar 2010 von ShineDaStar Zitieren
