Fehler bei Deinstallation Exch 2007
Hallo zusammen,
ich will SP2 für Exch 2007 installieren.
Auf meinem Hauptserver funktionierte auch alles. Auf meinem Backup-Server bekomme ich die Meldung:
"Exchange 2007 ist in einem inkonsistenten Zustand "
Beim Versuch Exchange zu reparieren bzw. zu deinstallieren
"R:\setup.com /mode:recoverserver ..." bekomme ich folgende Meldung:
12.01.2010 17:18:48] [0] **********************************************
[12.01.2010 17:18:48] [0] Starting Microsoft Exchange 2007 Setup
[12.01.2010 17:18:48] [0] **********************************************
[12.01.2010 17:18:48] [0] Operating System version: Microsoft Windows NT 5.2.3790 Service Pack 2.
[12.01.2010 17:18:48] [0] Setup version: 8.1.240.6.
[12.01.2010 17:18:53] [0] The following roles are installed:
[12.01.2010 17:18:53] [0] The local server does not have any Exchange files installed.
[12.01.2010 17:18:53] [0] Setup will use the path 'R:\' for installing Exchange.
[12.01.2010 17:18:53] [0] Setup will discover the installed roles from server object 'CN=xxxxxxx,CN=Servers,CN=Exchange Administrative Group (FYDIBOHF23SPDLT),CN=Administrative Groups,CN=XXXXXXXXX,CN=Microsoft Exchange,CN=Services,CN=Configuration,DC=XXXXXX,DC=de'.
[12.01.2010 17:18:53] [0] 'BridgeheadRole' is installed on the server object.
[12.01.2010 17:18:53] [0] 'ClientAccessRole' is installed on the server object.
[12.01.2010 17:18:53] [0] 'MailboxRole' is installed on the server object.
[12.01.2010 17:18:53] [0] The server is cluster type: 'None'.
[12.01.2010 17:18:53] [0] The requested cluster type: 'None'.
[12.01.2010 17:18:53] [0] The installation mode is set to: 'DisasterRecovery'.
[[12.01.2010 17:18:53] [0] Configuring Microsoft Exchange Server
[12.01.2010 17:18:53] [0] **************
[12.01.2010 17:18:53] [0] Setup will run the task 'install-msipackage'
[12.01.2010 17:18:53] [1] Setup launched task 'install-msipackage -logfile 'C:\ExchangeSetupLogs\ExchangeSetup.msilog' -targetdirectory 'D:\Programme\Microsoft\Exchange Server' -features 'Bridgehead','ClientAccess','Mailbox','AdminTools' -packagepath 'R:\exchangeserver.msi' -updatesdir 'R:\Updates' -PropertyValues 'DISABLEERRORREPORTING=1 PRODUCTLANGUAGELCID=1031 DEFAULTLANGUAGENAME=DEU DEFAULTLANGUAGELCID=1031 INSTALLCOMMENT="Installierte Sprache für dieses Produkt: German (Germany)"''
[12.01.2010 17:18:54] [1] Beginning processing.
[12.01.2010 17:19:09] [1] ProductCode is '24b2c164-de66-44fe-b468-a46d9d5e6b31'.
[12.01.2010 17:19:09] [1] PackagePath was set to 'R:\exchangeserver.msi'; normalizing to 'R:\exchangeserver.msi'.
[12.01.2010 17:19:24] [1] ProductCode is '24b2c164-de66-44fe-b468-a46d9d5e6b31'.
[12.01.2010 17:19:24] [1] Installing MSI package 'R:\exchangeserver.msi'.
[12.01.2010 17:20:05] [1] Ending processing.
[12.01.2010 17:20:05] [0] **************
[12.01.2010 17:20:05] [0] Setup will run the task 'DisasterRecovery-BridgeheadRole'
[12.01.2010 17:20:05] [1] Setup launched task 'DisasterRecovery-BridgeheadRole -DomainController 'XXXXXX' -updatesdir 'R:\Updates' -StartTransportService $true'
[12.01.2010 17:20:05] [1] [ERROR] Value cannot be null.
Parameter name: path1
Kann mir jemand mal einen Tipp geben?
Danke
Hallo flex001
Also da steht nichts dass auf dem "Backupserver" ein CCR laufen sollte.
Kann auch nicht gehen wenn da noch eine CAS Rolle installiert ist.
Was war denn das Problem das du jetzt mit setup.com /mode:recoverserver einen Server recoveren willst?
Gruss
fluehmann
Meinst du vielleicht SCR? Wenns wirklich ein CCR sein sollte, ist irgendwas an deiner Konfiguration nicht in Ordnung.
setup.com /mode:recoverserver ist ausserdem auch der falsche Weg für einen CCR - dafür gibts dann /RecoverCMS
mein Fehler, ich meinte SCR.
Das habe ich allerdings bereits wieder deaktiviert.
Ich habe eigentlich nur SP2 auf meinem ersten Server installiert und wollte das jetzt auf dem zweiten noch nachholen.
Was ich gerade gesehen habe war, dass alle Datenbanken auf dem zweiten Server in deinem "dirty state" waren. Ich habe sie alle mittels eseutil wieder in einen "clean shutdown" versetzt, aber das Problem besteht weiterhin.
