Alt-J 10 Geschrieben 19. Februar 2010 Autor Melden Geschrieben 19. Februar 2010 ::::::::::::::::::::::::::::::::::::::::::::::::::::::::: :::::::::: END CONFIGURATION SECTION :::::::::::::::::: ::::::::::::::::::::::::::::::::::::::::::::::::::::::::: rem OC4J Command Shell Script rem rem Supports start, version commands if "%JAVA_HOME%"=="" ( echo Error: JAVA_HOME environment variable is not defined. echo We cannot execute java. goto end ) if NOT exist "%JAVA_HOME%\bin\java.exe" ( rem echo Error: Can not find java executable in %JAVA_HOME%\bin. echo Please make sure the JAVA_HOME environment variable is defined correctly. goto end ) if "%ORACLE_HOME%"=="" ( echo Error: The ORACLE_HOME environment variable must be set before executing this script. Set this to the directory into which you unzipped oc4j_extended.zip. goto end ) set CMD=%1% if /I "%CMD%"=="-start" ( goto start ) if /I "%CMD%"=="-shutdown" ( goto shutdown ) if /I "%CMD%"=="-version" ( goto version ) if /I "%CMD%"=="-help" ( goto help ) if /I "%CMD%"=="-?" ( goto help ) if /I "%CMD%"=="" ( goto help ) goto error rem rem ERROR Command rem :error echo. echo Error: The option '%CMD%' was not recognized. goto help rem rem HELP Command rem :help echo. echo Usage: oc4j.cmd [Options] echo. echo Options: echo. echo -start : start OC4J echo -shutdown -port ^<ORMI port^> -password ^<password^> echo : stop OC4J echo -version : display the version echo -help : display this message echo. goto end rem rem START Command rem :start if not exist "%SERVER_XML%" ( echo Error: Can not find %SERVER_XML%. goto end ) echo Starting OC4J from %J2EE_HOME% ... set CMDARGS=-config "%SERVER_XML%" -userThreads if "%2%"=="" ( goto oc4j ) else ( echo. echo Error: The option %2% was not recognized. goto help ) rem rem SHUTDOWN Command rem :shutdown if "%2%"=="" goto next if /I "%2%"=="-port" ( if "%3%"=="" ( echo. echo Error: You must specify the ORMI port value. goto help ) else ( set ORMI_PORT=%3% shift shift goto shutdown ) ) if /I "%2%"=="-password" ( if "%3%"=="" ( echo. echo Error: You must supply a password to use. goto help ) else ( set ORMI_PASSWORD=%3% shift shift goto shutdown ) ) :next if "%ORMI_PORT%"=="" ( echo. echo Error: You must specify the ORMI port using the -port switch. echo The port value can be found in %J2EE_HOME%\config\rmi.xml. goto help ) if "%ORMI_PASSWORD%"=="" ( echo. echo Error: You must specify the ORMI password using the -password switch. goto help ) echo Shutdown OC4J instance... set CMDARGS=%ORMI_URL%:%ORMI_PORT% %ORMI_USER% %ORMI_PASSWORD% -shutdown goto admin rem rem VERSION Command rem :version echo Getting the version of OC4J instance... set CMDARGS=-version goto oc4j rem rem execute oc4j.jar command rem :oc4j if /I "%VERBOSE%"=="on" ( rem echo Executing: %JAVA_HOME%\bin\java %JVMARGS% -jar "%OC4J_JAR%" %CMDARGS% echo. ) if not EXIST "%OC4J_JAR%" ( echo Error: Can not find %OC4J_JAR%. goto end ) "%JAVA_HOME%\bin\java" %JVMARGS% -jar "%OC4J_JAR%" %CMDARGS% goto end rem rem execute admin.jar command rem :admin if /I "%VERBOSE%"=="on" ( rem echo Executing: %JAVA_HOME%\bin\java %JVMARGS% -jar "%ADMIN_JAR%" %CMDARGS% echo. ) if not EXIST "%ADMIN_JAR%" ( echo Error: Can not find %ADMIN_JAR%. goto end ) "%JAVA_HOME%\bin\java" %JVMARGS% -jar "%ADMIN_JAR%" %CMDARGS% goto end :end @endlocal Zitieren
Dr.Melzer 191 Geschrieben 19. Februar 2010 Melden Geschrieben 19. Februar 2010 Die Firma heisst Sun und die Software Java :D Das macht die Sache nicht besser... ;) Zitieren
Gulp 281 Geschrieben 19. Februar 2010 Melden Geschrieben 19. Februar 2010 Also mit einer Batch werden div. Dienste gestartet: rem Starten der Oracle DB echo Starten der Oracle DB net start OracleServiceBISE1DB net start OracleBISE1_DatabaseTNSListener net start OracleDBConsolebise1db rem Starten des Oracle BI echo Starten des Oracle BI net start "Oracle BI Server" net start "Oracle BI Java Host" net start "Oracle BI Presentation Server" D:\oracle\bise1\bi\oc4j_bi\bin\oc4j.cmd -start Die oc4j.cmd sieht wie folgt aus: @echo off @setlocal rem rem oc4j.cmd - batch file for invoking OC4J basic operations. rem rem Usage: oc4j.cmd [Options] rem rem Options: rem -start : start OC4J rem -shutdown -port <ORMI port> -password <password> rem : stop OC4J rem -version : display the version rem -help : display this message rem rem Copyright (c) 2004, 2005, Oracle. All rights reserved. rem ::::::::::::::::::::::::::::::::::::::::::::::::::::::::: :::::::::: START CONFIGURATION SECTION :::::::::::::::::: ::::::::::::::::::::::::::::::::::::::::::::::::::::::::: set ORACLE_HOME=D:\oracle\bise1\bi\oc4j_bi set JAVA_HOME=D:\oracle\bise1\jdk set J2EE_HOME=%ORACLE_HOME%\j2ee\home rem Any persistent arguments to specify at the JVM level can be set here rem By default this will be read from the operating system environment set JVMARGS=-Djava.library.path=D:\oracle\bise1\bi\server\Bin;D:\oracle\bise1\bi\web\bin -DSAROOTDIR=D:\oracle\bise1\bi -DSADATADIR=D:\oracle\bise1\bidata -XX:MaxPermSize=128m -Xmx512m %OC4J_JVM_ARGS% set CMDARGS= set VERBOSE=%VERBOSE% set ORMI_URL=ormi://localhost set ORMI_USER=oc4jadmin set OC4J_JAR=%J2EE_HOME%\oc4j.jar set ADMIN_JAR=%J2EE_HOME%\admin.jar set SERVER_XML=%J2EE_HOME%\config\server.xml Füge in der Zeile von oc4j.cmd: set JVMARGS=-Djava.library.path=D:\oracle\bise1\bi\server\Bin;D:\oracle\bise1\bi\web\bin -DSAROOTDIR=D:\oracle\bise1\bi -DSADATADIR=D:\oracle\bise1\bidata -XX:MaxPermSize=128m -Xmx512m %OC4J_JVM_ARGS% hinter -Xmx512m noch -Xrs hinzu ..... und versuche es erneut. Off-Topic:Liest Du eigentlich Links, die man hier postet? Grüsse Gulp Zitieren
Alt-J 10 Geschrieben 22. Februar 2010 Autor Melden Geschrieben 22. Februar 2010 Sry, für die späte Antwort. Aber das scheint es gewesen zu sein! :D Noch dem Logout läuft die Java-umgebung immernoch weiter. Jetzt klappt auch das starten als Dienst so wie es soll!!!! Tausend Dank! :jau: Zitieren
Gulp 281 Geschrieben 23. Februar 2010 Melden Geschrieben 23. Februar 2010 Sag ich doch ..... ;) Besten Dank für die Rückmeldung! Grüsse Gulp Zitieren
